Historic Changes '93-'07
Discussion in 'Historics & Reissues' started by guitaraddict, Apr 12, 2010.
  1. Jakub Stalmirski
    Jakub Stalmirski Member
    52
    3
    Feb 15, 2017
    2016 are long tenon ? i know they start doing R in serial number
    2016 update? anyone?
  2. Crotch
    Crotch Support MLP Veterans & Vendors Double Platinum Supporter Premium Member
    13,489
    21,686
    Jan 13, 2012
    Yes, long tenon. Same as 2014 models with different serial numbers. Start R9 XXXX instead of 9 XXXX
  3. LPaddicted
    LPaddicted Senior Member
    1,080
    717
    Jan 19, 2009
    2017, still no update on this thread ? :wave:
  4. Dilver
    Dilver Senior Member
    957
    1,371
    Apr 26, 2011
    Copied from the "other" LP forum...
    The 2017 specs that were leaked by Music Zoo earlier in the year stated that they were all (with the exception of the 60s) going with a 59 profile:
    "NAMM 2017
    New and exciting things are going down at the Gibson Custom Shop. Specs are being rearranged, necks and tops are changing shapes, and everything is lined up to come out fantastic. You can pre-order these guitars starting right now from The Music Zoo. Here is the low-down about what is coming out of the Historic division of the Gibson Custom Shop for 2017! Stay tuned for pictures as the guitars arrive in the store.
    Features of what we knew as 2016 Standard and True Historics are being condensed into one single series where all new 2017 Historic Reissue Les Pauls will feature:
    – The Carmelita top carve profile
    - All ’54, ’56, ’57, and ’58 Historic Reissues have ’59 neck profiles (there seems to be some discrepancy on this point)
    – All hide-glue construction and nitrocellulose lacquer finishes with aniline dye
    – True Historic parts including pickguard, pickup rings, switch washer, tip, knobs, pickup covers, and jack plate.
    – Historic accurate serial numbers (no “R” at the beginning of the serial)
    – Rolled Fretboard Binding
    – Solid Indian rosewood fretboard
    – Solid one-piece mahogany neck with Historic long neck tenon
    – Holly Headstock Veneer
    – Custombucker Pickups
    - Finishes include Antique Gold, Dirty Lemon (replacing Lemon Burst), Faded Tobacco, Iced Tea, and Washed Cherry
    - The street price for 1954 through 1958 Historic Reissue Les Pauls in both Gloss and VOS finishes are $4,699.
    - The street price for 1959 through 1960 Historic Reissue Les Pauls in both Gloss and VOS finishes are $6,499."
    Oddly enough, it's practically September and the Gibson web site doesn't seem to reflect any of this, still showing Standard Historics and True Historics and no mention of the Dirty Lemon finish (which is gorgeous BTW).
    bulletproof likes this.
  5. Pappy58
    Pappy58 Senior Member
    2,086
    4,107
    Dec 2, 2014
    Wast there a rumor/allegation that some 2016 "Rn" git's got TH plastics and PUP covers?
  6. Bigcat2017
    Bigcat2017 Member
    43
    36
    Feb 9, 2017
    Official 2018 changes:
    Pappy58 likes this.
  7. rockinlespaul
    rockinlespaul Oxblood Addict V.I.P. Member
    10,286
    10,441
    Aug 12, 2007
    Correct.
  8. rockinlespaul
    10,286
    10,441
    Aug 12, 2007
    See above Flick...
  9. rockinlespaul
    10,286
    10,441
    Aug 12, 2007
  10. PermissionToLand
    PermissionToLand Senior Member
    556
    267
    Sep 1, 2014
    Is there any info on Historic SGs like this? Have there been any changes at all? It seems like Gibson just threw SG fans a bone in 2000 and left it to languish for the next 18 years...
  11. DanD
    DanD Senior Member
    796
    844
    Feb 23, 2009
    Some'16 'RXXXXX' models are repurposed THs so some do have TH plastics.
    From whay I've seen from the late '16s and early '17s there were many repurposed guitars that were re-serialized THs with no other changes other than the serial number.
    The '15 TH '58 plaintops in both aged and unaged versions must have been a hard sell at TH pricing.
    I've seen quite a few R8 2XXX models that had seriously plain tops but had all the correct TH hardware and plastics.
    I've also noticed that the early '17s from 8 7001 to ~8 75XX have many repurposed TH R9s, CCs, and aged TH '58s.
  12. ezra1
    ezra1 Senior Member
    905
    627
    Mar 20, 2009
    Good to have this info.
    I sure like mine.
    Sct13 likes this.
