Historic Changes '93-'07
Discussion in 'Historics & Reissues' started by guitaraddict, Apr 12, 2010.
  1. guitaraddict
    guitaraddict Premium Member
    2,650
    1,308
    Jun 10, 2008
    Here's some good info that I found.
    1993
    * Historic Collection introduced. Models include; '54 Black Beauty, '56 Goldtop, '57 Custom Black Beauty/3 Pickup, '57 Goldtop, '57 Custom Black Beauty/2 Pickup, '57 Custom Black Beauty with optional Bigsby Tailpiece, '59 Flametop, '60 Flametop
    * First 25 Sunburst and first 15 Goldtops were painted by Tom Murphy.
    * Deep neck joint.
    * Thin Holly head veneer.
    * Silk screened les paul logo.
    * Correct pickup routing.
    * Les Paul classic aged inlay.
    * 57 Classic pickups.
    * Kluson replica tuners.
    * Vintage letter styled serial#.
    *"Historic collection" decal on the back of the headstock.
    * Indian rosewood fingerboard.
    *"AAAA" grade soft maple top.
    * Regular gibson usa brown case.
    * Regular early 90s style cherry sunburst.
    * Cherry sunburst and heritage darkburst"
    * Some models lack pickguard
    1994
    * Historic parts; only pickguard, pickup rings, trussrod cover.
    * Regular gibson usa white pearloid inlay.
    * "AAAA" grade soft maple top.
    * Darker transparent orangy cherry sunburst. (1994-1996)
    * First year for the R8
    * First 200 of 1994 painted By Tom Murphy
    *"Historic collection" decal still on the back of the headstock.
    * 1995-2002 both Eastern and Western Maple used for tops
    1995
    1996
    * "Flametop" R8 introduced in Buttersctch and Vintage Red finishes
    * R4 1996 up
    1997
    * ID micro chip in the neck joint.
    * Brass bridge saddles instead of steel bridge saddles.
    * "AAAAA" grade soft maple top.
    * Brighter transparent orangy cherry sunburst. (1997-199
    * Pickguard blueprinted and caused a gap, revealing improper placement of the bridge pickup
    * Brighter back cherry color.
    * Junior 57 1997 up
    * Junior 58 1997 up
    * Special 58 1997-2000?
    * Special 60 1997-up (when they discontinued the Special 58, they incoporated the SC into the Special 60)
    1998
    * R2 1998-2003
    * No pointers on knobs?
    1999
    * 40th Anniversary '59 RI - Painted and aged by Murphy (100 made?)
    * No R8 this year
    * COA began.
    * Thin body binding.
    * Thin lacquer finish.
    * "AAA" hard maple top.
    * new vintage taste cherry and darkburst.
    * Vintage style back red filler color.
    * Refined parts positions and neck shape.
    * Bridge pickup moved to its proper place
    * R9 Plaintop 1999-2000
    * Gibson Stops flame enhancing
    * Limited quantity of "Killer Top" R9s, "AAAAA" tops, stamped R9K in cavity
    2000
    * No R8 this year
    * Vintage lifton style brown case for R9/R0.
    * Lemon Burst, Tri Burst.
    * Black Custom Art Historic case. (TKL)
    * No COA.
    * No tortoise side markers.
    * Rounded fretboard inlays.
    * Heavyweight tailpiece.
    * '57 Classic PUP's.
    * Thick jack plate.
    * Thick switch plate/washer.
    * Fine-knurl switch nut.
    * Amber knobs.
    * Gibson label potentiometers.
    * Orange drop capacitors
    2001
    * R9 production limited to 500 units US, 1000 worldwide due to "parts constraints"
    * Custom Authentic models introduced (broken-in finish, aged hardware, Grovers)
    * Dickie Betts '57 Goldtop introduced (limited edition of 114)
    * R8 returns with a flametop
    * Thin neck binding.
    * New round edged pearloid inlay. (2001-2002 only)
    * Vintage style mid jumbo size frets.
    * New thick jack plate. (2001-2002 only)
    * Aluminum tailpiece.
    * Tortoise side markers
    * Very bright red sunburst.
    * Faded Tabacco, Iced Tea, Washed Cherry.
    * Lifton case is standard for R9/R0
    * COA standard
    * Limited run of Brazilian board R9's given to award dealers. About 50 guitars in the 9 1203 to 9 1250 range all but 6 of them aged by Tom Murphy
    * 38 Official Brazilian R9's
    2002
    * Genuine Kluson tuners for the early units.
    * Improved tuner bushings
    * More accurately shaped fingerboard inlays
    * Non-wire ABR-1 bridge for the early units.
    * Amber tophat knobs
    * CTS pots
    * Owners Card (listing name, serial number and the dealership), Certificate of Authenticity, Reissue Strap, an Embroidered Les Paul Swatch and a Custom Care Kit.
    * Burstbucker type 2 & 3.
    * Inlay material changed to swirly plastic, corners sharpened. (only R9/R0, later for all models)
    * Vintage style thin jack plate. (only R9/0, later for all models)
    * Vintage style thin toggle switch washer. (only R9/0, later for all models)
    * Vintage color toggle switch knob. (only R9/0, later for all models)
    * Vintage style CTS pots and oil caps. not bumblebee. (only R9/0, later all models)
    * Dark deep cherry sunburst.
    * R7 gets Bursrtbuckers
    * Left handed Historics get side dots added to the underside of the neck
    * Custom Authentic loses Grovers
    * 8 Official Brazilian R9's
    * 5 Guitar Center R0 models built (listed as "LPR0PTKBNH1 LP 60 Plaintop")
    2003
    * Brazilian boards installed from January through May as follows:
    ** of 4 3001-4 3150 35 of these were R4 Custom Black Beauties = 115 BRW R4s
    ** of 7 3001-7 3707 220 of these were R7 Customs, 4 GTs were 02 specs, 28 were Juniors = 455 BRW R7s
    ** of 8 3001-8 3256 31 of these were Juniors = 225 BRW R8s
    ** of 0 3001-0 3163 50 were G0s, 20 were Specials = 93 BRW R0s
    ** R6s and R9s Do not share with other models, so all 148 R6s and all 674 R9s are BRW.
    * Price drop on R8s and R9s
    * Truss rod cover moved away from nut
    * Headstock shape changed
    * Tuners arranged to be inline
    * Bumblebee Caps
    * Return to wired ABR
    * Madagascar rosewood fingerboard.
    * Eastern hard maple top
    * "AA" grade eastern hard maple top.
    * R9 flametop becomes less flashy due to increased use of Eastern Maple
    * R8 returns with a plain top
    * Burstbucker type 1 & 2.
    * Gold knobs instead of previous vintage amber knobs.
    * Corrected tuner positions. "V" intead of "l l" way.
    * Transparent orange to regular red cherry sunburst.
    * "i"dot on gibson logo moved to the correct position.
    * Inlays changed to swirly plastic, sharp corners on remaining models
    * Special run of "Stinger Series" guitars. Music Machine "Stingers" have Brazilian Rosewood fretboards
    * 50 Guitar Center R0 models built
    2004
    * Cloud 9 chambered models introduced in limited quantities
    * Jimmy Page signature model introduced; 25 Murphy aged guitars signed by JP, 150 Murphy aged unsigned models, 870 Custom Authentic non-Murphy aged guitars produced, run complete in 2007
    * New custom shop black case.
    * "AAA" eastern hard maple top.
    * Silk screened logo moved to the correct location.
    * Short Truss Rod Screws the right size
    2005
    * TR screws return to the wrong size
    2006
    * VOS finish with aged hardware introduced
    * CS begins using Plek machine used for dressing frets and cutting nut slots
    * Real vintage looking maple top grains/figures.
    2007
    * Brighter back red filler color.
    * Real honduran mahogany.............
    * 50th Anniversary Goldtop 157 to be built
    2001: there was a run of Brazilian R9s in the range 91203-91250 (91201 and 91202 only come up as Les Paul Classics for me). within this range, the following numbers do NOT have Brazilian Rosewood according to my info: 91236, 91230, 91220, 91217, 91215, 91214, 91210, 91209, 91207, 91206.
    Also, 911007 comes up as an R9 with brazilian.
    2002: 8 R9s, in the range 92038-92045
    2003:
    1954 Reissue, ranging from 43001-43150
    -within this range of numbers, 37 are '54 Black Beautys
    -43001-43006 are 1-pickup '54 Goldtops that went to Dave's Guitar in WI. i am assuming these got BR
    1956 Reissue, ranging from 63001-63148
    -the only exception here is that number 63126 does not exist as far as i can tell
    1957 Reissue, ranging from 73010-73707
    -numbers below 73010 either have 2002 specs (73001, 73005, 73006, 73007), are prototypes (R7:73004; LP Junior: 73002, 73003) or do not exist
    -within this range, 231 are 2 or 3 pickup '57 Black Beautys
    -26 are LP Juniors
    -73431-73438 do not exist
    1958 Reissue, ranging from 83001-83256
    -83001-83008 are prototypes (83001-83004, 83007, 83008), and 2 of these are LP Juniors (83005, 83006). 83009 is a quilt top R8 that went to Guitar Center
    -within this range 29 are LP Juniors
    -1 is a korina explorer
    -83046, 83047, and 83087 do not exist
    1959 Reissue, ranging from 93001-93674
    -93001-93006 are prototypes
    -93008 has 2002 specs
    -3 are korina Flying Vs
    1960 Reissue, ranging from 03001-03163
    -03001-03010 are prototypes (except for 03007 (not a proto) and 03002 (2002 specs)), and 2 of these are LP Specials
    -it appears that 03007 DOES have BR
    -within this range, 21 are LP Specials
    -48 are non-Historic GC '60 LPs, none of which have BR
    Gary Rossington SG
    -13001-13075 have Brazilian Rosewood
  2. planks
    planks Senior Member
    15,039
    6,233
    Feb 16, 2010
    Great collection of info! Thanks :thumb:
  3. shtdaprdtr
    shtdaprdtr Senior Member
    3,095
    249
    Oct 30, 2008
    My 01 R8 still had black side dot markers.
  4. markguitar
    markguitar MLP Sponsor
    1,031
    2,522
    Mar 31, 2007
    There are a good number of details that are WRONG in the list of details above. I think it may be the same as what was listed on the Gibson Forum and it was wrong then.
  5. jomo
    jomo V.I.P. Member
    11,047
    1,498
    Apr 23, 2008
    I knew that. :thumb:
  6. Tim Plains
    Tim Plains Senior Member
    12,532
    7,808
    Feb 11, 2008
    Right or wrong, 2009 info. :)
    1959 LP Specs
    Without question, 2009 has been one of the most exciting years in Gibson production history. In celebration of the 50th anniversary of the 1959 Les Paul, Gibson has retooled many of their production processes in an unprecedented effort to tweak the specs of the historic Les Paul line even tighter to replicate the original guitars.
    With over 30 spec changes, a few specific changes really stand out to me:
    1. Neck shape.
    New drafting technology allowed for the development of new 59 neck profile by digitally mapping original examples of this “holy grail” guitar. The neck retains the same thickness as previous years but there is now less “cheek” or “shoulder” on the necks. The result is a neck that really fits well in your hand. It is a substantial, yet graceful neck that gives has a slight hint of a soft V, especially when playing in first position.
    2. Nylon 6/6 nut. This is a change the vintage purists have requested for years. Gibson used different material for nuts over the years ranging from bone to nylon, plastic, and most recently, Corian. While Corian is an excellent nut material, nylon 6/6 was the material used in the 1950s and provides both a visual and mechanical difference. The blue/white color of nylon 6/6 is something that sends a thrill down the spine of the vintage guitar freak, (count me in). It also provides a natural lubrication factor which helps guard against strings binding up in the nut slots.
    3. Mahogany to rosewood and maple ratio. Close examination of vintage examples reveal that while the overall dimensions of recent historic Les Pauls have been correct, the fingerboards and maple tops have been slightly too thick and the mahogany backs and necks slightly too thin. Fingerboards and maple tops are now thinner and the mahogany has been beefed up to make up the difference. We are not talking huge numbers here, maybe just the thickness of a couple of business cards. But when you think of the amount of surface area on a maple top, that is a lot of real estate!
    4. Wireless abr-1 bridge. The return to the wireless abr-1 is further improved by a complete retooling of the bridge to much tighter tolerances. The saddles sit tight in the slots. This, coupled with the absence of the retaining wire, means there is less sympathetic vibration of these parts when the guitar is played and that results in better tone transference.
    The list
    2009 R9 Changed Features:
    Nylon 6/6 nut
    Improved ABR-1 bridge (no-wire, tighter tolerances)
    Historically correct nickel-plated brass bridge saddles
    Correct alloy saddle adjustment screws
    Bridge height-adjusting thumbwheels are now thinner
    Neck profile changed - now has less "shoulders"
    Audio taper CTS pots
    50s wiring
    Pickup routes adjusted so that pickups will be parallel to the strings
    Top carve changed to be closer to several original '59s that were scanned
    Body perimeter change - slightly tighter in waist, cutaway area refined to be more like originals
    The maple cap is very slightly thinner, the mahogany body is very slightly thicker
    The fingerboard is slightly thinner
    The step from neck heel to back of body is taller and more correct
    The taper of the "maple window" under the binding in cutaway is more accurate
    The maple spline (filler strip) in the tenon is more accurate
    The edge radius on the backside of the body is tighter (less rounded)
    The "mustache curve" of the headstock top has been flattened slightly
    The control cavity plate has been relocated, has the correct side taper, and now uses the correct ABS plastic
    The pickguard shape has changed slightly
    The pickguard bracket and screw have been changed
    The truss rod cover has been reshaped to be more accurate
    The serial number location is slightly lower and more correct
    Dial pointers are less sharp
    The strap button screws are longer
    The jack hole is now the correct 1" diameter
    The toggle switch nut has more correct knurled pattern
    Shawn Lutz, Sct13, w.izzy and 2 others like this.
  7. JOE DEW
    JOE DEW Banned
    53
    1
    May 14, 2008
    Year-by-Year History of the Historic Les Paul Collection - Les Paul Forum
    :slash: the wrong one is this one on LPF by "donerectrong".
    but the ones on Gibson Forum are correct and the Gibson Official.
    and its the first, done by me in 2007 for the Gibson Custom Shop Forum.
    :thumb:
  8. JOE DEW
    JOE DEW Banned
    53
    1
    May 14, 2008
  9. JOE DEW
    JOE DEW Banned
    53
    1
    May 14, 2008
  10. JOE DEW
    JOE DEW Banned
    53
    1
    May 14, 2008
    :cool: hello mr.tonebone, pickin happy on burny everyday? joe.
  11. JMV
    JMV Senior Member
    15,444
    15,837
    Mar 21, 2009
    Now that's interesting. I just bought a 2000 R8 from Grinning Elk. Surely they existed in 2000. :hmm:
  12. GrinningElk
    GrinningElk MLP Vendor
    2,110
    1,927
    Feb 13, 2009
    Here's the back of the headstock- will call Gibson to confirm.
  13. JMV
    JMV Senior Member
    15,444
    15,837
    Mar 21, 2009
    Thanks, Ray! I know you guys are the real deal!
  14. JMV
    JMV Senior Member
    15,444
    15,837
    Mar 21, 2009
    And Gibson confirmed! It's a 2000 R8. :dude:
  15. xgoredeathx
    xgoredeathx Member
    37
    0
    May 13, 2010
    So did the 09 and newer R8s receive the same changes as the R9?
  16. jmfreeland
    jmfreeland Junior Member
    16
    0
    Jun 6, 2010
    bump. just picked up an 09 R7 and would be curious to know what changes took place for this guy.
  17. JOE DEW
    JOE DEW Banned
    53
    1
    May 14, 2008
  18. luckyfield
    luckyfield Member
    47
    2
    Feb 5, 2009
    I love the logo....GIBSON BANZAI!!!
  19. cooljuk
    14,396
    18,950
    Mar 12, 2009
    Can anyone fill in the gaps between 2007 and now? I read about the 2009 changes, but what about 2008 and 2010? It would be good to have this all in one place.
  20. LPaddicted
    LPaddicted Senior Member
    1,079
    714
    Jan 19, 2009
    May we have information concerning 2008 reissue ?
