Help with a Doobie Brothers riff
Discussion in 'Guitar Lessons' started by Byron999, May 27, 2017.
  1. Byron999
    Byron999 Senior Member
    8,179
    8,671
    Dec 4, 2008
    The Doobie Brothers - "Don't Stop To Watch The Wheels"
    First, if anyone knows how this lick is played, could you please share. I've not found any lessons or tab for it.
    I've tried to figure this out for some time now (many moons). Its just too cool sounding.
    But, I need help. Maybe a team effort?
    Here is what I think is the tab. I think I'm getting close.
    Here is the intro, which is repeated through out the song.
    Here are a few mp3 files of the lick slowed down to a percentage of the original speed.
    https://soundcloud.com/byron999/doobie-bros-intro-riff-at-60-perecent
    https://soundcloud.com/byron999/doobie-bros-intro-riff-at-80-perecent
    https://soundcloud.com/byron999/doobie-bros-intro-riff-at-90-perecent
    Also, here is the song tempo at 85% of original
    https://soundcloud.com/byron999/dont-stop-to-watch-full-song-at-85-speed
  2. KP11520
    KP11520 Senior Member
    6,473
    7,214
    Apr 11, 2014
    Definitely sounds like Jeff (Skunk) Baxter's chops to me. He has a knack for interesting riffs, evident with his Early Steely Dan recordings. He's got his own timing if you asked me. Not always so straight forward.
    I'll check this out later!
  3. Freddy G
    Freddy G V.I.P. Member
    11,338
    23,646
    Mar 18, 2007
    the beginning is not right....first, it's an E bent a semitone to an F. You've got F-F#. Then your third note again is an F not an F#. Tabbing this out would take me all day...if someone else doesn't pipe in I'll just play it and video it....much easier for me!
  4. KP11520
    6,473
    7,214
    Apr 11, 2014
    I agree with Freddy on the beginning.....
    Sounds something like an E bent to an F, Hit the A on the first string and run it back.
  5. Byron999
    8,179
    8,671
    Dec 4, 2008
    Thanks for looking at this lick.
    Freddy, an example, slowly and at tempo would be much appreciated.
    I'll do the same if I can work any of these up to speed, at least up to 90%.
    Its been so beneficial trying to emulate this lick, its so rich in texture.
    :cool2: thanks Mr. Baxter , I know you'd understand :420:, and you wouldn't record it and then speed it up mechanically :slap:
    Looking at it further I've come up with version 2
  6. JonR
    JonR Senior Member
    2,889
    2,572
    Sep 29, 2010
    F bent to F# is how I hear it:
    Code:
    ---|--5--------------------|-----------------------
    -6b|7---7------------------|--------------------------
    ---|------7-5--------------|------------------------
    ---|----------7-5-3-4------|------3h5\-------------------
    ---|------------------5-3-0|--3h5-----1h3-----------------
    ---|-----------------------|1----------------------
        1     2     3     4     1     2     3     4
    ---|----------7-5-3-4------|------3h5--------------------
    ---|------------------5-3-0|--3h5-----3h5-----------------
        1     2     3     4     1     2     3     4
    The repeat is the same as first time except for the last two notes.
    The G on fret 5 on beat 3 could be the open 3rd string. The 4th fret note is held a little across the next beat.
    EDIT: posted at the same time as Byron999! Some disagreements, obviously. I stand by mine in terms of notes, although tab positions are debatable.
  7. Byron999
    8,179
    8,671
    Dec 4, 2008
    Thanks Jon, I'll play with your example today.
  8. Byron999
    8,179
    8,671
    Dec 4, 2008
    Okay, I think my ver 2 was so close, but one note was still missing.
    I added the open D and I really think this is it............:cool2::lol:
  9. Byron999
    8,179
    8,671
    Dec 4, 2008
    Version 3 got me closer, however one note was still wrong.
    Many passes are played with heavy attack, without the little delay he uses on some passes.
    By slowing the song 40 %, one can count the number notes he plays after the D string hammer on.
    This song is just too cool not to be in some ones play list.
    The tempo of this song is fast. Slowed down this that can color the technique, a slide sounds like bend, so listen to the original as well. The software to slow down the examples does a good job maintaining the correct pitch and allows distinction between a open string and its fretted note.
    Anyway, I do believe this to be correct , try it out.
  10. Byron999
    8,179
    8,671
    Dec 4, 2008
    Here is the Intro upto the chorus slowed to 40 percent.
    https://soundcloud.com/byron999/doobie-bros-riff-demo-at-40-perecent
    I use my index and little finger to play the first part down to the hammer on on the D string, and then miiddle /ring fingers for the 3h4 hammer on.
    add a little slide up to the 'a' string 3h5 hammer on.
    very cool sounding
  11. JonR
    JonR Senior Member
    2,889
    2,572
    Sep 29, 2010
    There's no G string after the F#, and the following D can't be the open string because the F# sustains across it. I also think the F# is picked, not hammered on.
    You're also missing the hammer-on to the final notes: 1h3 first time. (You mentioned the 3h5 second time, but both are worth putting in the tab.)
    I think you've improved on mine in a couple of other places though! Here's my latest guess:
    Code:
    -6b|7---7-3----------------|--------------------------
    ---|--------5-2-0----------|------------------------
    ---|--------------3-4------|------3h5\-------------------
        1     2     3     4     1     2     3     4
    ---|--------------3-4------|------3h5--------------------
        1     2     3     4     1     2     3     4
    Interestingly, the whole riff sits under the fingers better in a different tuning E-A-D-F#-B-E...
    That F# rings as if it's an open string. (That would also work if the whole guitar was down a half-step, but that makes the lick less intuitive in other respects.)
    It works well in open D, which puts makes that low 1st fret note on 3rd fret ... food for thought..... ;)
  12. JonR
    JonR Senior Member
    2,889
    2,572
    Sep 29, 2010
    Here it is in open D:
    Code:
    D ---|--7---0----------------|-----------------------
    A -8b|9---9---3--------------|--------------------------
    F#---|----------3-----0------|------------------------
    D ---|------------5-3---0----|------3h5\-------------------
    A ---|--------------------3-0|--3h5-----1h3-----------------
    D ---|-----------------------|3----------------------
          1     2     3     4     1     2     3     4
    D ---|------------5-3---0----|------3h5--------------------
    A ---|--------------------3-0|--3h5-----3h5-----------------
          1     2     3     4     1     2     3     4
    Maybe worth a try?
  13. Byron999
    8,179
    8,671
    Dec 4, 2008
    Thanks Jon, I'll play with that today. I appreaciate your input. The open tuning looks interesting.
  14. Byron999
    8,179
    8,671
    Dec 4, 2008
    Jon I think you are correct with the open D tuning.
    The only change is where to play that "A", the 6th note. Instead of 3rd String, 3rd fret, play the open A string. sounds spot on.
    Thanks for your help. I really appreciate it. I would have never figured it out.
  15. Byron999
    8,179
    8,671
    Dec 4, 2008
    Here is the lick tab I think most will evolve to with this lick.
    "Interestingly, the whole riff sits under the fingers better in a different tuning..."
    Jon, they do, here is the lick with 5th note and 6th (open A) notes played at the first hand position.
    This really makes the riff much easier to play at speed. I still slide up the F# (first note)
    Again, thanks for your help.
    Byron
