[Help] Volume Pedal placement for 2 amps.
Discussion in 'The Squawk Box' started by gibsonislove, Feb 23, 2012.
  1. Syrus
    Syrus Senior Member
    2,690
    1,600
    Sep 8, 2011
    Stereo pedal will set volume for both amps at the same time. That might be difficult if you switch amps and get a volume drop/raise.
    He can also use a volume pedal per amp and one master volume in front of AB box.
    This might also be nice, http://www.singlecoil.com/docs/ab.pdf
    As simple pedal like that can cost something like 20 dollars if you are a bit handy. Its to easy not to try.
  2. onioner
    onioner Senior Member
    2,252
    875
    Sep 12, 2010
    I think this is what he wants, as both amps are running together.
    I think this is what he doesn't want, as it will boost the input signal.
