[HELP] Noise problem on Guitar Rig 5
Discussion in 'Recording Studio' started by zz133zz, Feb 9, 2014.
  1. zz133zz
    zz133zz Junior Member
    5
    1
    Feb 9, 2014
    First of all, sorry if i post the thread in a wrong section
    I have a Epiphone Zakk Wylde Signature Bullseye MIK w/ EMG 81/60 (upgraded from HZs) on it and i play this guitar with Guitar Rig 5 but I got a noise problem on it when i tried to change the preset to the metal/High Gain stuff...
    It's sounds like white noise even when I turn the guitar volume down :shock:
    FYI I plug the guitar only using a Aux cable (kinda stupid :doh:) with a 1/4" to 3.5 mm converter that comes with my headphone (not a cheap one) through the 'line in' input on my onboard soundcard
    So where's this problem coming from? cable or what? :confused:
    and i actually wanna change the cable to Planet waves American Stage and buy a converter to plug it in to my computer but will it sound as supposed to sound?
    Thanks.
  2. lucidspoon
    lucidspoon Senior Member
    4,333
    5,223
    Mar 31, 2008
    It's the soundcard. Your aux in doesn't have a preamp necessary to get the volume to a point where the software can use it. You need and audio interface with a preamp.
  3. zz133zz
    5
    1
    Feb 9, 2014
    thanks for your reply
    what if i replace the cable to instrument/guitar cable and plug it in to the computer with a converter? will it solve the problem or i have to buy the audio interface to solve this problem?
    if so, what is the best audio interface for guitar recording under $100?
    audio interface are a bit pricey here anyways, due a tax...
  4. lucidspoon
    4,333
    5,223
    Mar 31, 2008
    Just changing the cable won't hangs the fact that you don't have a preamp. Aux in is expecting a line level signal. Your guitar is instrument level which is too low. A cheap mixer with instrument inputs and a line out might work to plug into the aux in. But not 100% sure.
    This is pretty popular: PreSonus AudioBox USB | Sweetwater.com
  5. zz133zz
    5
    1
    Feb 9, 2014
    okay dude
    Thanks, i'll take that Audio Interface :thumb:
  6. Telepaul
    Telepaul Junior Member
    23
    7
    Feb 5, 2014
    in case you didn't order that yet, the m audio m track has more features for less of a price, midi i/o and mono/stereo switching
  7. zz133zz
    5
    1
    Feb 9, 2014
    Actually i've got the Focusrite 2i2 instead of Audiobox USB :laugh2:
    and I liked it especially the build quality :dude:
    1 person likes this.
  8. user xyz
    user xyz Senior Member
    108
    41
    Jan 22, 2013
    That's the Ticket--Best Bang for the Buck Audio Interface.
    I have the 18i6 and with GR 5 it sounds Phenomenal!! :slash:
  9. KP11520
    KP11520 Senior Member
    6,422
    7,107
    Apr 11, 2014
    Whatever Audio Interface you get, make sure the mic input preamps also accommodate High-Z inputs (Electric Guitar and Bass)
    Then you'll be good to go.
    Both Presonus and Focusrite are very good, but I'd give the edge to Focusrite.
    Good luck!
