Help needed for measurements on fanned fretboards...
Discussion in 'Luthier's Corner' started by Pesh, Dec 6, 2017.
  1. Pesh
    Pesh Senior Member
    285
    131
    May 4, 2015
    Hi all,
    I read earlier today a thread regarding a fanned fret Firebird build that one of our resident builders is currently undertaking.
    It got me thinking, as fanned frets is something I'd be looking at doing on a build in the future, about how measurements are made for these.
    With straight / regular frets, the centre-point is X-distance from the nut, and seeing as the fret is parallel to the length of the nut. If you have a measurement start point at the nut (call it point 'a') and a second point which will be the centre of the placed fret (call it point 'b'), this will be constant wherever you measure on the length of the fret and comparative point on the nut.
    However I noticed that with fan frets, there is potentially 3 measurements one could make to accurately place a fret, and given that almost all frets are at an angle to the nut rather than parallel, the bass end of a frets' a to b measurement will be different to the treble end of the frets' a-b measurement. Which is fine.
    The problem is, I don't know at what point you would measure the fret placement points.
    I've got a picture attached with the three measurement points I've considered. I'm using an example of a 25.5" scale on the bass side, and a 24.75" scale on the right-side. I've got a collection of the various measurements of fret placement from the StewMac fret position calculator.
    • The top drawing is where the a-b measurement is made along the lengths of a fretboard blank. If using this method, the various points for the 25.5" scale are plotted along one edge of the fretboard blank, and then the various points for the 24.75" scale are plotted against the other edge. The points are joined up so you get line placements for where the frets would be, but the exact start and end points aren't ever on the actual fretboard after shaping it (the pink line overlap).
    • The middle drawing is where the a-b measurements are made along the edge of a shaped fretboard (i.e. where you have set the fretboard width at the nut and 12th fret). Like the first drawing, the measurements are made along the edges to the nut position. However this, as far as I understand it, would result in different placements from the top drawing method, as the width of the piece of wood means you'll have a slightly different start and end point using this edge.
    • The bottom drawing is similar to the middle, but measures the scale from the nut to a point directly under the outermost strings. This would mean that the scale length measurements would be exact at the point where you fret a string. It's hard to tell this in the picture of the drawing, sorry - I used small paper, thick-nib pens. I couldn't have drawn this as quickly in something digital at the moment.
    Could anyone advise which of these methods to use, if indeed I should use any of them at all? perhaps I'm over-complicating things, perhaps there is a better method?
    I'm looking for some info from those of you in the know, those of you who have made such things happen in the past and how you did it.
    Thanks in advance!
  2. Ripthorn
    Ripthorn Senior Member
    1,415
    1,078
    Mar 7, 2014
    If I were you, I would go to the fretfind2d page, which will do all the math for you and you can export it in a number of files. It's how I do it, and I've done it for several builds.
    Who, Pesh and KnightroExpress like this.
  3. ARandall
    ARandall Senior Member
    11,325
    6,484
    Apr 16, 2012
    You have to find the path that the string takes....after all thats the bit that is playing the note and has to play in tune all the way along.
    Pesh likes this.
  4. KnightroExpress
    KnightroExpress Senior Member
    1,383
    1,366
    Sep 5, 2013
    +1 for Fretfind, it's a great tool for planning out multiscale fretboards.
    Pesh likes this.
  5. WhiteEpiLP
    WhiteEpiLP Senior Member
    1,136
    785
    Nov 29, 2012
    The problem with your idea is fanned fret guitars also have an angled nut. So 25.5 and 24.75 is a 3/4" difference, not much but a difference of 3/8th off 90° at both ends. So if the center point is the 12th fret it would be the straight fret and then you could just use the knowen measurements of the fret spacings for thise 2 scale lenghts marked fromthe center out both ways.
    Ultimately as lkng as you place the individual bridge saddles in the right place it should work.
    Of course this is all me thinking it out in my head having never done this and 5 beers in so what do i know. I could be way off.
    Pesh likes this.
  6. charisjapan
    charisjapan Silver Supporter
    1,292
    1,290
    Jul 10, 2011
    Hey @Pesh !
    Really, there is only one way to make a fanned fret guitar work, and that is using the two outboard strings. Anything else would sound really weird.
    My Limba 6 Multiscale is 628mm~648mm ... very nearly a Strat bass E and a Gibson treble e ... so about what you were using as your example. Mechanically, all you have to do is set those two lengths, then decide where you want the single perpendicular fret, then all the other things will be decided from there. That's what FretFind2 does, but also tells you the fretboard dimensions after you decide how much overhang you want on each side. I set my perpendicular at the 7th fret, as I like to noodle around in Bm. You can set it anywhere that you are comfortable with, also keeping in mind how much angle you will have at the nut and bridge for design and esthetic purposes. Remember also that you will need a bridge that accommodates what you want (Hipshot makes 11 degree and 18 degree), or use individual bridges (Hipshot makes those, too).
    Just go to http://www.ekips.org/tools/guitar/fretfind2d/ , decide your perimeters and print it out! Tape the 3 pages together, snip it out and you will have an exact representation of your fretboard, and can even check all the measurements with their very comprehensive list of every single fret/string intersection. With this you can visualize your future guitar! :)
    :cheers2:
    Pesh likes this.
  7. Pesh
    Pesh Senior Member
    285
    131
    May 4, 2015
    Thanks very much for the feedback on this. It was your limba thread that had me thinking about the problem and how to solve.
    I had designed a solution where the two scales, and therefore fret positions were measured using the outside edges of the shaped fretboard (example 2 from my crude drawings) but I can see how this would be flawed. Depending on the overhang of the fretboard the scales under the string would be shorter than what one might want, and it could also adversely affect bridge placement.
    I'm creating a new solution based on the fret finding tool for this one. I'm quite into designing things in CAD / CAM so I'm doing this in Fusion 360, so I can export carving / cutting into a CNC, or export the pattern into a laser cutter which I can use to trace lines with hand tools later.
    Thanks again!
  8. WezV
    WezV Senior Member
    218
    253
    May 17, 2016
    I use fretfind now, but it didn’t do fanned frets when I made my first few so have drawn them out manually a few times
    The important bit missing from your posts is the perp. The perp is the one straight fret that sits perpendicular to the centre line.. I like to have this somewhere between the 3rd and 12th frets.
    I start with the board already tapered and showing a clear centre line. I mark the fret positions down the bass side. Yes, you need to use a scale slightly longer than the chosen string scale length to account for the overhang( or slightly shorter when doing the treble side)
    Once the bass side is done i scribe the perp in place, let’s say it’s the 7th fret. At this point I have the 7th fret clearly marked right across the board and I have the other frets marked on the bass side only. I can then work backwards from the perp towards the nut on the treble side. Once I have a mark on both sides it’s simply a case of joint the dots.
    Just a few things to be aware of. Most printers/paper can not be relied on for accurate fret slotting. Use them as a guide only. Having multiple pages of fretfind numbers in front of you can be confusing.... make sure you are organised and tick off measurements as you go. Check, recheck and check again f doing this by hand
    Pesh likes this.
  9. charisjapan
    1,292
    1,290
    Jul 10, 2011
    Here's a screenshot of a multiscale in millimeters, 628~648mm. You have to click "multiple" in the scale length, and have all the inputs correct before it makes sense.
    I used a run-of-the-mill HP Officejet printer with nice paper, and the A4 PDF printouts were perfect ... I checked every node.
    Oh, yeah ... the perpendicular is set by clicking the (?) and getting a reference chart popup.
    Good luck!
    :cheers2:
    Pesh likes this.
  10. WezV
    WezV Senior Member
    218
    253
    May 17, 2016
    I am always nervous about it as neither the printer or paper manufactures would claim perfection for this task. You really need a decent plotter to guarantee dimensional accuracy
    Paper can change dimensions quite significantly
  11. charisjapan
    1,292
    1,290
    Jul 10, 2011
    Wasn't talking about the manufacturer's claims ... I measured with my own pretty nice tools, and the printout was spot-on. But I would not use anything without confirming it before actually cutting the slots ... which I did. Also, using excellent paper makes a big difference. :) Note that as I used the paper to set my jig, I cut through it ... I didn't have to worry about dimensional changes over time or season. I would certainly no recommend printing something in the summer and then waiting until using it in the winter! :fingersx:
    But all that is academic if you don't line up your jig correctly AND cut them to spec. The most accurate printout won't work if you set your jig incorrectly! With a multiscale (barring a custom-made jig made for multiscale or a CNC) every single fret must be carefully aligned, and it's real easy to get confused. ;) I was lucky, using an inkjet printout the end result was a fretboard that intonates every bit as well as any of my nice guitars.
    IWFM YMMV LS/MFT
    :cheers2:
  12. WezV
    WezV Senior Member
    218
    253
    May 17, 2016
    I think we are agreeing then. A useful guide, but not something you can just slap on without further checks
    geoffstgermaine and charisjapan like this.
  13. Pesh
    Pesh Senior Member
    285
    131
    May 4, 2015
    What I've done is indeed use all the data from FretFind and plotted the design into a CAM. I'm a bit of a buff with Fusion 360 and the AutoDesk lot, and I've got access to a laser cutter-engraver. The model plots the start and end points for all the fret lines, the exterior edge of the fretboard, and the nut, all at their correct angles, based on the FF output.
    The cutter has a very high accuracy, and will effectively give me pilot cuts for the lines I need to cut for frets and for the shape of the overall board.
    The board will have a 3mm overhang (I think that's enough? I'm away from all the guitars at the moment so can't measure!) and I'll be testing it out on something like a pine block first and making a false neck to check how it feels.
