[Help] Missing wire on humbucker pickup
Discussion in 'Pickups' started by lorenzo, Jan 24, 2012.
  1. lorenzo
    lorenzo Senior Member
    106
    16
    Dec 4, 2010
    Hello, guys!
    I bought a Wilkinson Humbucker pickup to use with push-pull pots on my guitar (reverse phase/coil split). Ocours that all the wiring diagrams I found for 4-wire pickups actually have 5 wires comming from each pickup - example: http://www.seymourduncan.com/images/support/schematics/2h_2v_2t_3w_2pp.jpg
    But my pickup have only 4 wires comming from it: http://www.vintagepretty.com/ebay/partscaster/paf4wire.jpg
    Where is the 5th?
    Thanks!
  2. AngryHatter
    AngryHatter Senior Member
    17,185
    13,096
    Jun 19, 2009
    My sheptones only had four.
  3. lorenzo
    106
    16
    Dec 4, 2010
    I believe one of the cables has the bare wire, but I can't see it on my pickups.
  4. rick13
    rick13 Senior Member
    748
    99
    Dec 18, 2007
    The bare wire is usually just soldered to the baseplate. If you don't have a fifth wire, you can always run a separate ground from the baseplate to common ground. One of your four wires will be also the ground wire for the bobbins.
    Rick
