Help me wrap my brain around 2 cabs and a Vintage Orange
Discussion in 'The Squawk Box' started by your idol, Mar 14, 2018.
  1. your idol
    your idol Senior Member
    11,870
    21,465
    Apr 17, 2010
    I typically use a Rockerverb MKIII and its clear as day. 1 16 ohm cab...16 ohm jack. 2x16 ohm cabs 8ohm jack for each cab.
    I just bought a 75 OR80 today...not as clear. 2 jacks. Easy enough. Then theres the switch on the head...do I leave it at 16 ohms or do I kick the switch to 8ohms under the impression that it sets both outputs to 8 ohm like the dual outs on my rockerverb? B3C2DC84-90CB-4173-9232-80D030148683.jpeg 10284F82-ADD1-4E3A-8C95-20589D1A180A.jpeg
    Harmony and northernguitarguy like this.
  2. Mike_LA
    Mike_LA Senior Member
    250
    401
    Feb 25, 2011
    I found a slightly better pic of the back
    northernguitarguy and your idol like this.
  3. Big John
    Big John bigger is better V.I.P. Member
    7,357
    6,776
    Mar 18, 2007
    OP, see if you can carefully remove that tape residue. There might be a "4" hiding underneath it.
    your idol and northernguitarguy like this.
  4. northernguitarguy
    northernguitarguy SWeAT hOg
    29,166
    49,095
    Feb 22, 2009
    My bet is the two jacks are wired parallel. So, if I'm right, two 8 ohm speakers would need to be set at 4ohms, and two 16 ohm speakers set for 8.
    Good to hear you're alive and kicking, Brian!
    THDNUT and your idol like this.
  5. Thumpalumpacus
    Thumpalumpacus Senior Member
    76,014
    186,252
    Nov 28, 2010
    Both speakers hooked up? Put the switch to 8.
    Wondered where you've been, bud.
  6. your idol
    11,870
    21,465
    Apr 17, 2010
    Thanks for the help fellas its nice to see ya’ll. Ive been busy. Fixing my life. Moved just outside Nashville a week ago so Im settling in and spending way too much on gear.
  7. northernguitarguy
    29,166
    49,095
    Feb 22, 2009
    That's awesome. A man spending too much on gear is a fortunate dude. Great to hear!
  8. your idol
    11,870
    21,465
    Apr 17, 2010
    442FF86B-FAA7-482D-9892-E615950F4BBF.jpeg Broke... but fortunate
    Im supposed to sell my Rockerverb mkIII to recoup for the OR80 but the more I play the more I want both. 1 cab each? Maybe a/b the heads? Maybe 2 more cabs? Maybe a 612?
    My wife is going to stab me while I sleep. All I know is that after this experience I need an attenuator!! Holy hell is this thing LOUD!!!!!
  9. Thumpalumpacus
    76,014
    186,252
    Nov 28, 2010
    Glad to hear the good news, brotha -- don't be a stranger!
  10. jojo
    jojo Senior Member
    1,478
    952
    Sep 27, 2009
    Grats on the OR 80 !!! I always wanted one, but they are hard to find :) I did have a 75 OR 120 that was WAY too loud. ( and I play in a REAL loud band ) Also, keep in mind those old orange amps were not made to be run at modern US Wall voltages. Many people have issues with this popping fuses etc. They need to be run at about 106-108 US volts typically. Get a Variable Power Transformer and step the volts down if you have this issue.
    your idol likes this.
