HELP! Kluson Locking Tuner Install on 90's Epi Riviera
Discussion in 'Other Epiphones' started by stilwel, Jan 28, 2017.
  1. stilwel
    stilwel Senior Member
    160
    222
    May 19, 2009
    After months of searching I finally found an early 90's sunburst Epiphone Riviera to replace the one I let get away a few years ago.
    I bought a set of Kluson 3+3 Locking vintage keystone tuners to install on it. The bushings are a perfect fit. The hole mounting pattern lines up perfectly.
    The problem: the tuner post hole that the string is supposed to pass through is just barely visible above the top of the bushing. I can't get the strings through the holes!! The bushings are fully seated flush with the top of the headstock and I have the rear mounting screws snugged up so everything is tight.
    Anyone ever had this issue? It never occurred to me that the thickness of the headstock or post length could be an issue. I was more concerned with hole pattern and bushing diameter.
    KP11520 and kevinpaul like this.
  2. kevinpaul
    kevinpaul Senior Member
    17,663
    27,230
    Apr 7, 2011
    Can you drill a few millimeters to give you a little space for the strings to fit? I just installed locking tuners on an Epiphone and a set on a Fender. The height varies, the high ones are for the EAD stings and lower are for the thin treble strings GBE strings. Are your tuners like that?
  3. stilwel
    160
    222
    May 19, 2009
    Thanks for the reply.
    I looked to see if they are staggered height and they don't appear to be.
  4. stilwel
    160
    222
    May 19, 2009
    Obviously being 3 to a side, they will only fit on one side and not the other.
  5. Brians Evil Twin
    Brians Evil Twin Poophoria Sōtō Zen V.I.P. Member
    10,811
    27,558
    Apr 24, 2012
    Not much you can do but return them I'm afraid.
    They're meant for a thinner headstock it would seem.
  6. stilwel
    160
    222
    May 19, 2009
    So I ended up going with Gotoh Magnum Locking Keystone tuners. Longer posts and they installed easily. Look great too.
  7. KP11520
    KP11520 Senior Member
    6,437
    7,127
    Apr 11, 2014
    Good for you!
    I will most likely be installing the Thumb Wheel locking version of them on my JDM Les Paul Standard!
    Make sure the Nut is lubed with something long lasting and you'll never have tuning issues! :thumb:
  8. truckermde
    truckermde Senior Member
    14,204
    18,044
    Oct 21, 2012
    Great solution!
  9. stilwel
    160
    222
    May 19, 2009
    Imparting knowledge gained over this adventure...
    The Klusons are made for vintage guitars which have a 1/2" (12.7mm) headstock thickness. Modern guitars, in an effort to avoid headstock breaks are thicker, and closer to 17mm.
    Modern Epiphones require tuners with a minimum 20mm post length.
    http://g-gotoh.com/international/product/sd90.html
    http://g-gotoh.com/international/product/sd91.html
    SD90 is larger keystone buttons
    SD91 is smaller metal buttons
    MG is the magnum locking mechanism
    MG-T is the magnum locking with the "Traditional" rear-mounted thumbscrew
    Of course they also offer standard, non-locking versions.
    It's only a few bucks more to get the locking versions. I recommend them for Rivieras and Casinos, particularly if you have, or plan to install, a Bigsby vibrato.
  10. Rocco Crocco
    Rocco Crocco Senior Member
    6,573
    7,776
    Feb 8, 2013
    I have these thumbwheel Klusons on my PRS SE. They work flawlessly.
  11. KP11520
    6,437
    7,127
    Apr 11, 2014
    Thank You! Now there is no doubt these will be on my LP in the near future! :thumb:
    They look to have everything I'd ever want in a "Kluson" style!
