Help identifying late 80's Gibson pickups
Discussion in 'Pickups' started by depuis1899, Jul 18, 2017.
  1. depuis1899
    depuis1899 Senior Member
    130
    23
    Feb 24, 2014
  2. ARandall
    ARandall Senior Member
    11,328
    6,484
    Apr 16, 2012
    They have many of the signs to show they could be.
    But the first period of the 498/490 used baseplates similar in look.......and the bottom one looks like there is a separate neck and bridge spacing which the Shaw never had.
  3. DarrellV
    DarrellV Make the Switch for the Better! Silver Supporter Premium Member
    10,955
    14,197
    Nov 1, 2016
    Right, and although not exclusively, a lot of Shaws used brass coil mount screws.
    AR is of course correct in the identical pole spacing, that's what mine have.
    Could we get an Ohm reading? That would help.
    No ink stamp, yes it's not a deal breaker I get it, but didn't the earliest ones have a long hand date stamp and then coded date?
    Later they morphed into PU490's. Maybe that's these?
    Going on just the pics my 2 cents is not Shaws...
    I've been wrong before.....
  4. depuis1899
    130
    23
    Feb 24, 2014
    Thanks to you all for the input already.
    Ohm reading is weird somehow...Neck is 8.24 ( which is normal ) but bridge is 14.21 . My dad and I checked a couple of times, same results.
  5. mrfett
    mrfett HJ Lover Premium Member
    1,219
    956
    Aug 25, 2013
    readings rule out Shaws, I'd agree with PU490s (precursors to the 490R/498T set).
  6. LtKojak
    LtKojak Senior Member
    3,945
    2,556
    Aug 26, 2009
    That's an early 490R/498T.
    HTH,
  7. depuis1899
    130
    23
    Feb 24, 2014
    thanks everyone for their help !
    Much appreciated !
    Are these worth anything ? I have no use for them at all to be honest...
  8. DarrellV
    10,955
    14,197
    Nov 1, 2016
    The only ones I've ever heard of being this high were the Bill Lawrence models...
    @LtKojak just for my own info are you saying the 490/498T series were wound this hot as well?
    Thanks!
  9. ARandall
    11,328
    6,484
    Apr 16, 2012
    ^ Yes, 498T is 13-14k
    The fact that a 490R is reading high too means the bridge reading comes back to what I'd describe as being regular.
    No real value - this is the pickup where they lost the plot for mine. Or tried to be modern. Either way they got it pretty wrong for many.
    mrfett likes this.
