Heavier Guitars Sound Thicker?
Discussion in 'Tonefreaks' started by Elkoki, Nov 18, 2018.
  1. mgenet
    mgenet Earth = Cheese Burger Silver Supporter
    11,210
    15,237
    Sep 18, 2010
    Nope. I talk to no one...
    uh...
    ehb likes this.
  2. mgenet
    11,210
    15,237
    Sep 18, 2010
    I'm waiting around for...
    cake.
    Don't tell Lt Dave.
    ehb likes this.
  3. vivanchenko
    vivanchenko Senior Member
    326
    123
    Jan 9, 2012
    The bassiest guitar I ever had was an SA series Ibanez which was only an inch thick and which was made of African mahogany. It resonated at low frequencies very well, so that I could feel it with my stomach and it was easily bassier than any of the full thickness Les Pauls which I ever played. So, my experience tells me no, a thinner guitar might be bassier and fuller sounding. Wood density and composition is very inconsistent and each plank cut from the same tree can resonate at different frequencies.
  4. Mookakian
    Mookakian Senior Member
    6,268
    2,389
    Jan 18, 2010
    Damn i realised i didnt answer the op... does more mass equal more low end... i think is the question?
    depends on where the mass is taken from, hollow out near the bridge and you get less highs, take a chop from the tail of the slab you get more highs... its not as simple as the op suggests...tone war starts now :peace:
  5. HogmanA
    HogmanA Senior Member
    1,017
    725
    Jan 2, 2009
    I just remembered - my brother had one of these (Ibanez GAX70). It sounded pretty good with all upgraded electronics, but was uncomfortable to play on a strap because of neck dive.
    So, we decided to add weight to the body in between the bridge and the edge of the body.
    We routed out a hole (on the back, obviously!) maybe about 1/2" deep, by 1"x3", and filled it with a 2lb lead sea fishing weight (by melting it and pouring it in).
    The guitar became much more playable on a strap.
    But did the sound change? Yes, it did! By a considerable amount.
    The sound became 'harder' - much more defined. Especially the treble component of the sound. It lost all 'transparency'. No where near as nice sounding. But, the extra definition and hardness has its uses.
    *edit
    which reminds me of something else - the topic of 'transparency'. Not talked about a lot (no where near as much as it should in my opinion).
    My main LP, before I upgraded the stock zinc hardware, was muddy, boomy but the most transparent guitar i have ever played.
    What does this mean in the real world?
    That I could fill a venue with my open backed 4x12 with a huge, lush sound (none of your boxy modern offerings!) while still seemingly providing space for everything else.
    Transparent. But, if you tried to take centre stage, it was too transparent. But it was a rhythm guitarists dream.
    Having to fill all roles, I relied exclusively on a treble boost and my guitar tone controls to reduce transparency.
    Not to be confused with a mere increase in treble - that is not what I am talking about.
    This transparency is also 'why' Les Pauls, and something Strats and even beloved Teles will never do.
    Since the days of cranked 100w stacks are over, I have stopped using treble boost, and instead achieve a similar result with smaller amps and more vintage correct hardware, especially the tailpiece on the same guitar.
  6. Matt_Krush
    Matt_Krush Senior Member
    991
    660
    Nov 5, 2014
    I get the biggest/thickest tones out of an Epiphone dot (semi-hollow body).
    Best sounding guitar in my lot (It has non factory Pick-ups) but is better sounding than my high-end Jacksons & Gibsons.
  7. guidothepimmp
    guidothepimmp Senior Member
    683
    718
    Sep 8, 2012
    I vote false. SG and ibanez S Classics or S Series can sound nice and beefy.. and theyre pretty skinny
    bulletproof likes this.
  8. Antigua
    Antigua Senior Member
    575
    185
    Oct 15, 2016
    Sustain owes to rigidity. If a heavier guitar sustains longer, it's because the extra mass happens to make it more rigid.
    And if by "thicker" we mean midrange, hollow and semi hollow body electrics seem to give a lot more midrange, while sold bodies sound more scooped in the mids.
    Jewel the Sapphire likes this.
  9. diogoguitar
    diogoguitar Member
    93
    53
    Aug 1, 2014
    law of diminishing returns... I had an ESP eclipse that was pretty light and good sustain, but I could feel the difference between that and my full thickness LP traditional
  10. Jewel the Sapphire
    Jewel the Sapphire Senior Member
    539
    688
    Jun 8, 2018
  11. ballou48
    ballou48 Member
    39
    28
    May 10, 2012
    Here we go again "into the black hole of subjectivism". All I know is that Billie Gibons uses a weight relieved LP with 8's and nobody can deny he gets the fattest nastiest tone in R&R.
  12. jimijam33
    jimijam33 Member
    32
    53
    Nov 9, 2015
    The best sounding (and loudest) guitar I've ever played was an original '58 Les Paul (weighing well over 10lbs). It was factory refinished in 1961 (sunburst) revealing an off center maple top seam. Amazing experience for sure..
  13. korus
    korus Senior Member
    1,091
    401
    Apr 10, 2007
    Sustain owes to resonance. It happens when, mostly by chance, resonant frequencies (actually, frequency ranges) of metal hardware and wood parts happen to overlap with certain overones the guitar string's vibration consist of.
    You can have exactly the same wood used to make 2 or more guitars of the same model, with exact same dimensions, exact same hardware parts and exact same electric parts. And setup exactly the same to 1/128 of an inch. These guitars can be selected so they have same weight eg no more than 1/2 ounce of difference for lightest and heaviest of several 9 lbs LPs. We all know they will have a difference in tone and sustain.
    If we were to measure all the mechanical properties of every mahogany back of the body and every neck and every maple top, prior to using them for building these guitars, they would measure the same, within 1-2% variance. Therefore, the resultant rigidity of all samples would be also the same - within 2-4% variance.
    But tone and sustain differs among them. The cause is simple. The wood is a natural material, result of living things growing. It's internal structure is irregular, unlike man made homogenous materials. That variance in structure results in variance of resonant frequencies. Different resonant frequencies result in different level of absorbtion/resonance of various overtones that create guitar tone/timbre, and that also causes different duration of certain overtones, which we call - different sustain. And parts used have same rigidity.
    The simplest proof is the way longest sustaining notes change the tone the most, from attack to final decay. The relative level of overtones change. Some overtones do not create resonance and they die faster. Those supported by resonance last longer. Hence, tone changes. It is usually called 'bloom' on stock original LPs. It has nothing to do with pickups. Original PAFs have no bloom on Rx and $10k replicas. Stock originals have bloom with Seth Lovers.
    The reason why stock original electric solidbody electric guitars have longer sustain than modern made replicas is different hardness of alloys used for making hardware, back then and now. Original gardware is made of softer alloys. Softer material has lower resonant frequency. Lower resonant frequencies favor lower overtones. Lower overtones carry more energy. Lower overtones are closer to resonant frequency of wood used. More energy and closer frequencies create greater resonance. We detect it as louder acoustic, primary tone of solidbody electric. Greater resonance make string (certain overtones, not all) vibrate longer, so we detect greater sustain.
    It is not complicated as it might seem. There are indeed some terms not common in everyday colloquial English, but they all describe some real life phenomena, and are not abstract and hard to comprehend like theories on structure of universe or structure of matter. Ask any physicist(s), using these terms - symphatic vibrations, overlap of resonant frequency ranges, short standing vibrations of particular overtones in resonance range, absorbtion reduced because of resonance resulting with prolonged overall duration of vibration, altering relative level of overtones in resultant tone being different timbre - he/she/them will get interested and listen. And then confirm it is a valid explanation of physical phenomena at hand, consistent with reality perceived.
    Beware of oversimplification. Illusion of inclusion is good cause, but an obsolete obstacle in solving problems or finding valid explanations.
    boola1, NINFNM and HogmanA like this.
  14. PierM
    PierM Premium Member
    4,296
    7,823
    Aug 19, 2016
  15. freebyrd 69
    freebyrd 69 Premium Member
    11,316
    20,157
    Sep 29, 2011
    So according to what you are saying, no modern Reissue that I own will sustain or bloom notes like a vintage guitar of the same model? Because if that's what that long, drawn out statement is claiming, that's bullshit. If I misinterpreted your statement, I apologize, but otherwise, see the above "bullshit" meter provided by Pier M.
  16. garybaldy
    garybaldy Senior Member
    1,827
    1,041
    Apr 10, 2011
    Love the Tele clip and your Epi tone.
    Elkoki likes this.
  17. splatter
    splatter Senior Member
    4,872
    4,052
    Sep 26, 2009
    I have found it to be just the opposite .
    the thinner mahogany guitars sound darker than the thicker
    freebyrd 69 and bulletproof like this.
  18. Elkoki
    Elkoki Senior Member
    503
    169
    Mar 4, 2015
    Thanks, I really liked the tone of that EPI, but I sold it like an idiot. It sounded so nice! I used it on this video too for some $15 Amazon pickups
  19. Bobby Mahogany
    Bobby Mahogany Senior Member
    21,548
    31,928
    Feb 25, 2012
    Nothing speaks tone like an Epiphone with a trio of 2 x 6's!
    :facepalm:
  20. charlie chitlins
    charlie chitlins Senior Member
    3,002
    2,609
    Feb 8, 2011
    The most surprising sounding guitars I've played have had hefty necks.
    Body mass doesn't seem to make much difference.
    YMMV
    It's a given, to many bass players, that added headstock mass helps cure dead spots.
