Headstock damage.
Discussion in 'Luthier's Corner' started by Jackangus, Sep 21, 2017.
  1. fumblefinger
    fumblefinger Senior Member
    1,184
    480
    May 10, 2012
    Just to play it safe you could wick some thin CA around the cracks to stabilize it.
  2. Jackangus
    Jackangus Senior Member
    352
    100
    May 27, 2014
    What is CA?
  3. jkes01
    jkes01 Senior Member
    1,903
    813
    Jan 10, 2011
  4. frankr442
    frankr442 Junior Member
    10
    1
    Oct 30, 2015
    If it's poly (polyurethane I assume), can't you use a drop of gloss polyurethane with an artists' brush to touch up the chip?
  5. Jackangus
    352
    100
    May 27, 2014
    Not as far as the luthier thinks.
    He thinks it will look worse.
  6. kakerlak
    kakerlak Senior Member
    1,348
    423
    Feb 5, 2014
    I'd leave it alone. The bright side (assuming you're right-handed) is that it's on the underside of the headstock, where you'll never see it in normal playing conditions.
    Jackangus and northernguitarguy like this.
  7. northernguitarguy
    northernguitarguy SWeAT hOg
    26,086
    41,241
    Feb 22, 2009
    You're welcome! Good beer, too. Unless you go wild like Steve Vai, those will do the trick. The harder they are to get on, the harder it will be to have them slip. If your strap is decent thick leather, expect some success.
  8. moreles
    moreles Senior Member
    2,397
    991
    Apr 16, 2011
    Hmmm.... opinions vary. I'm surprised that a luthier would not feel able to do a decent color match and physical restoration. Restorers match colors all the time and this one's pretty generic. I would not hesitate to fix this if it were mine. On the other hand, though, a bad repair is horrible -- worse than the original damage -- and this is just cosmetic anyway. I always fix stuff because I can, but if I didn't want to spend money or couldn't find a confident repai person, I'd happily leave it as is, or at most seal it w/ shellac.
  9. kiko
    kiko Senior Member
    826
    823
    Jul 16, 2015
    Buy a strap lock and just leave it. It's just cosmetic.
  10. Jackangus
    352
    100
    May 27, 2014
    Do i need to worry about the exposed wood?
    I have contacted another luthier and awaiting their call. I don't mind spending some money to get it fixed.
    I found it a little strange the other guy could not do anything. I'm guessing he was not confident enough.
  11. guidothepimmp
    guidothepimmp Senior Member
    551
    477
    Sep 8, 2012
    i suspect luthier 1 said what he said because he figures it is not worth the effort or time, note.. his effort or time.. i know a luthier who sometimes passes on this kind of work because
    1. he doesnt enjoy it
    2. he would charge crazy money for it
    3. he would simply say it is part ofthe mojo
    4. doessnt affect integrity of the instrument.
    so above is all good andwell, except it isnt about the luthiers wants, it is about yours as a customer. so long story short, prob the kind of luthier i avoid.
    northernguitarguy and Jackangus like this.
  12. Jackangus
    352
    100
    May 27, 2014
    Sounds about right.
    I have come across a few luthiers who only want to dance to the beat of their own drum.
    The trouble is luthiers are few and far between, which means they can pick and choose their work. And charge crazy money too.
    guidothepimmp likes this.
  13. fumblefinger
    1,184
    480
    May 10, 2012
    In defense of the luthiers, they are in business to make money as well as keep the instruments playable. Sometimes it just isn't worth doing what is necessary for a given instrument. Unless it's a special (family heirloom, "had it for 40 years", etc) situation, every luthier who's been in business for any length of time turns down work on a regular basis. Can it be filled and color matched? Absolutely! Are you willing to spend $500+ for someone who knows what they're doing to accomplish this? (Fill the area, sand it flat, run 4-8 test color matches, tape the guitar and shoot the color and clear, level sand and buff) Probably not. Economics generally dictate the level of work.
