Headstock damage.
Discussion in 'Luthier's Corner' started by Jackangus, Sep 21, 2017.
  1. Jackangus
    Jackangus Senior Member
    352
    100
    May 27, 2014
    guitar.jpg Hi guys,
    My new Guild guitar fell out of the strap today and has damaged the corner of the headstock.
    I can only see the damage from the side and back. Luckily I can't see it from the front.
    It looks like it is only the finish it has cracked off, I can see the wood underneath.
    It does not look too flash and it sucks that it is such a new guitar.
    Is this worth getting a Luthier to fix? Can it ever look perfect again?
  2. Freddy G
    Freddy G V.I.P. Member
    10,830
    21,912
    Mar 18, 2007
    Depends entirely on the luthier's skill.
    northernguitarguy likes this.
  3. vetteman
    vetteman Member
    62
    101
    Apr 4, 2017
    I think I would either get that repaired, or if you decide to just live with it, drop fill with some thin super glue to stabilize the remaining edges.
    Ayrton and Jackangus like this.
  4. Jackangus
    352
    100
    May 27, 2014
    Would you class the damage bad or just a bit of cosmetic damage?
    I have always been lucky and never damaged my guitars before, apart from the odd little dent or scratch. nothing like this.
    Might need to get some strap locks.
  5. jkes01
    jkes01 Senior Member
    2,075
    954
    Jan 10, 2011
    Just cosmetic if that is the only damage it sustained.
    northernguitarguy and Jackangus like this.
  6. Jackangus
    352
    100
    May 27, 2014
    Yes, that is it.
    Sucks balls though, the guitar has such a nice finish. I will have to get someone to look at it.
    A little worried what they will charge though.
  7. ARandall
    ARandall Senior Member
    11,791
    7,183
    Apr 16, 2012
    That sort of repair is always costly despite the small size. Its the sort of repair that will be hard/impossible to get looking new again - especially as you will know where to look.
    I think you should get a quote/estimation on costs.....just so you know what it would have cost if you decide to live with the damage.
    On the other side....you have started the long journey of owning your guitar - with the first of many little dings.
    Jackangus and northernguitarguy like this.
  8. northernguitarguy
    northernguitarguy SWeAT hOg
    27,475
    44,720
    Feb 22, 2009
    Time to grab a 4-pack of Grolsch and get some beer washers over the strap pegs.
  9. pshupe
    pshupe Senior Member
    3,345
    2,170
    Jan 19, 2012
    Better get a 12 pack. These things are easy to lose! ;-)
  10. Freddy G
    10,830
    21,912
    Mar 18, 2007
    I would repair that. Looks like lacquer, not poly. So no I would not use superglue drop fill. The devil is in the colour match.
    mux164, Leña_Costoso and Jackangus like this.
  11. Al Walker
    Al Walker Senior Member
    1,128
    1,137
    Sep 14, 2014
    Strap locks are essential! What ever way you want to go. I dropped a brand new Strat on concrete and took a large chunk of finish off the lower edge. Every guitar got Strap locks after that!
    Jackangus likes this.
  12. Jackangus
    352
    100
    May 27, 2014
    I have some decent fret buzz after the headstock taking a hit.
    Could that fall moved the truss rod or something like that?
  13. jkes01
    2,075
    954
    Jan 10, 2011
    Definately possible. Look at the area on the back of the neck, just opposite of the nut and check for and stress cracks. Make sure there is no other damage. Could be a simple as a popped up fret or just a little more relief needed on the truss rod.
  14. Leña_Costoso
    Leña_Costoso Senior Member
    733
    687
    Aug 28, 2017
    +1 on NO superglue. Jeeze. I'm rather fond of the Mohawk liquid toners, and they mix well with lacquer. This will need a little artistry, for the color mixing.
    As for lacquer finish... that picture shows a Korean made Guild, if my eyes are catching the lettering right. that would be a poly finish, but.... its still repairable with lacquer for a fill/color and perhaps a bit of blending with clear final coats. It might be a good idea to use some clear shellac as a first coat, just for sticktion of nitro to the poly.
  15. Jackangus
    352
    100
    May 27, 2014
    Going to buy some of these and try them out.
    Nice cheap locks.
    Thanks.
  16. Jackangus
    352
    100
    May 27, 2014
    Just spoke to a Luthier and he suggests there is nothing he can do and just to leave it as is.
    Does this sound right to you guys? or should I get a second opinion?
    He stated that because it is poly, it would look worse or be a crazy price to fix.
  17. jkes01
    2,075
    954
    Jan 10, 2011
    2nd opinion.
  18. cmjohnson
    cmjohnson Senior Member
    1,570
    1,034
    Dec 13, 2012
    That's a very thick finish. Probably polyester. Not what you would call "easy" to touch up.
    Yeah, the label on the back says made in Korea. So it's not really a finish, it's more like a layer of hard plastic.
  19. Jackangus
    352
    100
    May 27, 2014
    I'm a little worried that if I do nothing it will possibly get worse over time. Maybe flake and crack.
  20. cmjohnson
    1,570
    1,034
    Dec 13, 2012
    Probably not. There's not likely to be any stress in the area between the wood and the finish that might make it crack off.
