Guitar Works - Country Rock Ballad Solo in D - Aeolian Mode - B C# D E F# G A
Discussion in 'Guitar Lessons' started by cefobe, Jul 1, 2017.
  1. cefobe
    cefobe Senior Member
    829
    244
    Dec 19, 2010
    Marcus Nalgaber - Guitar Works - Country Rock Ballad Solo in D - Aeolian Mode - B C# D E F# G A
    :cheers:
  2. huw
    huw V.I.P. Member
    3,525
    4,745
    Jul 13, 2007
    Two sharps?
    That's D major, not D aeolean. Did you mean B aeolean?
  3. JonR
    JonR Senior Member
    2,889
    2,572
    Sep 29, 2010
    Yep, sounds like solid D major to me. Nothing aeolian going on: no B aeolian, and definitely no D aeolian.
  4. cefobe
    829
    244
    Dec 19, 2010
    I am playing with 2 sharps in the tone of D, but of the 7 scales that has the Tone of D,
    using basically the 6th scale (mode).
  5. huw
    huw V.I.P. Member
    3,525
    4,745
    Jul 13, 2007
    I think there may be a language problem here, because that makes no sense at all. Sorry, but I can't work out what you're trying to say. :(
  6. cefobe
    829
    244
    Dec 19, 2010
    No problem, best regards :cheers2:
    huw likes this.
  7. JonR
    JonR Senior Member
    2,889
    2,572
    Sep 29, 2010
    This may well be a language problem, as huw says, but issues of terminology - even among English speakers! - are the source of most of the confusion about modes.
    "B aeolian mode" means the D major scale played so that B sounds like the keynote. (What you call the "tone" is what we all "tonic" or keynote.)
    IOW, it's a "B minor" sound.
    What you're playing sounds like D major, because D sounds like the overall keynote (coming from the backing at least). You may be accenting a B note in your lead lines, or using a pattern in which B is lowest, but it's simply accenting the 6th note of the key. That's not a modal effect. The chords are governing the modal sound, which is D ionian in this case.
    IOW, if you play B aeolian over a D major sequence, what it sounds like is - a D major sequence (with maybe an accent on the 6th). That may be a nice sound, but there is nothing "aeolian" about it.
    If the intention is to demonstrate B aeolian mode, you need a Bm chord to be central to the backing, confirming B as tonic (keynote). Then any pattern of D major that you play over it will sound like B aeolian mode.
    Apologies if you understand this distinction, but a lot of folks don't! ;)
  8. cefobe
    829
    244
    Dec 19, 2010
    Many thanks JonR for your interest, I understand, that´s OK. :cheers:
