Guitar kit/bridge placement issues
Discussion in 'Luthier's Corner' started by CaseyD, Dec 30, 2017.
  1. CaseyD
    CaseyD Junior Member
    12
    2
    Dec 30, 2017
    280F27DD-70B1-4F93-BD02-5581105DE133.jpeg Hello everybody I’m new to the Page And need some advice. I am putting together a Les Paul Junior guitar kit and I’m having some trouble getting my measurements set to drill for the bridge. The scale length is about 24 inches, however on that measurement it looks like the bridge needs to be almost in the pick up cavity for the scale length to be right. It’s more than likely the kit itself that’s off. So my question is if I set the bridge a little further away will that greatly destroy any hopes of proper intonation? Also, I’d like the Bridge to be offset, so where on the bridge would I measure to be at the scale length? I was thinking the center of the bridge would be at 24 inches leaving the low E a smidge lower and the high E a smidge higher. Thanks for any help in advance.
    I’ll try to include a picture of where the scale is in relation to the body/pickup cavity
  2. Freddy G
    Freddy G V.I.P. Member
    10,712
    21,564
    Mar 18, 2007
    about 24"? Please give an exact measurement from the nut to the dead center of the 12th fret
    dickjonesify and CaseyD like this.
  3. CaseyD
    12
    2
    Dec 30, 2017
    It looks like it’s 12 to 12&1/16
  4. Bobby Mahogany
    Bobby Mahogany Senior Member
    19,458
    27,577
    Feb 25, 2012
    DO NOT DRILL until you know exactly where to.
    Otherwise your guitar WILL NEVER BE IN TUNE.
    CaseyD likes this.
  5. CaseyD
    12
    2
    Dec 30, 2017
    Absolutely, definitely not taking it lightly.
    Bobby Mahogany likes this.
  6. pshupe
    pshupe Senior Member
    3,334
    2,166
    Jan 19, 2012
    Looks like 12 3/8”, which would make 24 3/4” which is a very common scale. Measure 24 3/4” from the nut and place the bridge there. Do not drill. Get a trapeze or other tailpiece and intonate low and high E and then drill.
    Regards Peter.
  7. Freddy G
    10,712
    21,564
    Mar 18, 2007
    You know you are supposed to measure to the center of the 12th fret fretwire right? You measured to halfway between the 11th and 12th frets. That shows a really fundamental lack of understanding of what you are trying to do. We'll walk you through it.....
    deadlyweasel, dickjonesify and CaseyD like this.
  8. CaseyD
    12
    2
    Dec 30, 2017
    Lol, yes Freddy. You’re 100% correct. I’ve never done this before. I’ve been researching and nobody was very specific as to where exactly on the 12th fret. Makes a lot more sense now that it actually goes to the fret wire itself. I’m going to have help from a friend who’s worked on plenty of guitars before, So I’m not doing it completely alone. Im just snowed in and wanted some initial info from people who specialize in this.
  9. Sunburstman
    Sunburstman Senior Member
    243
    56
    Jun 23, 2009
    Casey, go to stewmac.com and look at there fret scale calculator.
    CaseyD likes this.
  10. cmjohnson
    cmjohnson Senior Member
    1,540
    1,021
    Dec 13, 2012
    Here is what I have always done and I've never missed.
    This applies to a Tune-O-Matic bridge type.
    Measure from the point the nut touches the fingerboard to the peak of the 12th fret.
    Double this measurement.
    Add 1/8 inch.
    At this point, draw a line across the body, perpendicular to the centerline axis of the fingerboard. Now, place your bridge on this line and mark the centers of the studs on the line.
    Now, increase the distance from the nut to the BASS side stud center by 3/32nds of an inch. At the same time, decrease the distance from the treble side stud center by 3/32nds of an inch.
    Draw a line thru these adjusted stud locations. This is exactly the line you want your bridge studs to be placed on. Recheck the stud spacing and recheck that this location has the strings centered up nicely on the fingerboard. (Put strings on the bridge, just the outer two, to check this. They don't need to be anchored down or anything.)
    This method has never failed me.
    Double nut to 12th fret length, add 1/8", rotate bridge to add 3/32" scale length to bass side and subtract 3/32" scale length from the treble side.
  11. CaseyD
    12
    2
    Dec 30, 2017
    Thanks everyone. Measuring to the actual fret itself changed everything. 24&3/4” is the scale length. CMjohnson that seems like a fool proof way to set it off center. I have a tunomatic I can test it on before I drill for the wraparound (I’ll make sure to measure the difference if any where the strings come off the bridges on both).
    Thanks sunburst man for the stewmac advise. That place is a gold mine
    dickjonesify likes this.
  12. Sunburstman
    243
    56
    Jun 23, 2009
    Hi CaseyD! Glad I could help, can't wait to see it finished!!!
  13. warprider
    warprider Senior Member
    199
    162
    Jan 31, 2011
    What kit do you have there?
    We might be working on the same one.
  14. CaseyD
    12
    2
    Dec 30, 2017
    Hey, to be honest I’m not sure. Could be a musoo. Seems to be a decent quality kit.
  15. CaseyD
    12
    2
    Dec 30, 2017
    So, it took a lot longer to finish than expected but it is done save for some fret dressing. Seems like the pick up cavity is cut a little closer to the neck than usual but I’m happy with it.
  16. pshupe
    3,334
    2,166
    Jan 19, 2012
    That's a little strange as your initial post was the PUP cavity was too close to the bridge. You measured 24" first, correct? You should be only 3/4" farther, which IMO would be a good location. What happened?
    Guitar looks great BTW.
    Cheers Peter.
  17. CaseyD
    12
    2
    Dec 30, 2017
    Thanks! My initial measurement was off. After some deliberation I decided on the stoptail/bridge combo as I figured it would be a safer bet getting the bridge placement right with my lack of experience. Turned out just fine in the end with everybody’s help.
  18. pshupe
    3,334
    2,166
    Jan 19, 2012
    As long as you got it intonated properly that's all that matters. I'd still like to know how your bridge location went from at the PUP route edge at 24" to about 2" - 2 1/2" further away if it was a 24.75" scale length? The wraparound bridge can be a little tricky but if you use a trapeze tail and locate prior to drilling it's actually quite easy. The trapeze just mounts where you would have a strap button anyway, so the hole is re-used.
    Looks like a nice finish. Was it rattle can? Did you grain fill prior to finish?
    Cheers Peter.
  19. CaseyD
    12
    2
    Dec 30, 2017
    I can’t explain the bridge placement myself, it worked at that angle/spot. I started at scale and adjusted until both E’s were in tune in the spots they need to be. I saw the trapeze trick but could acquire one in time.
    The finish process was an opaque wheat furniture stain, black wood filler, lemon yellow dye and poly. Sanded between coats and in that order. I was trying to get a pale mustard finish.
  20. pshupe
    3,334
    2,166
    Jan 19, 2012
    That's the way I do it as well. Where ever it needs to be. I generally measure the scale length mark a line twist a bit and then use a temporary trapeze to string up E and e then open and fretted within a couple of cents and it usually works perfectly. The hardest part is usually trying to get the stud spacing right. I've gotten better on that and the last few I have done have fit on the studs perfectly.
    Great job on the finish. I thought it looked like black grain filler. I just did the same thing on a build of mine. I really like that look. Congrats.
    Cheers Peter.
