Grain filling question
Discussion in 'Luthier's Corner' started by archey, Nov 9, 2017.
  1. archey
    archey Senior Member
    998
    839
    Nov 28, 2010
    Probably a dumb question, but here I go. After filling the grain and wiping the excess off do I have to sand it? The filler has colored the mahogany a nice shade that I'd like to keep.
  2. Draxond
    Draxond Member
    68
    36
    May 27, 2015
    You should sand at least a little, purely to get a nice level surface for your finish. You don’t need to take it all off, but you’ll definitely want to smooth it out.
    archey likes this.
  3. AlexGT
    AlexGT Member
    44
    58
    Aug 4, 2014
    If you have used an oil based filler with aniline dye you schould not sand it.
    archey likes this.
  4. SlingBlader
    SlingBlader Premium Member
    310
    227
    Dec 7, 2013
    Hey Kenny, on my builds I sanded up to 220 before I grain filled. I applied my home-made filler and wiped off the excess with a squeegee and some cheese cloth. I went back and re-wiped/buffed lightly a couple of times over the next 20 minutes or so, to be sure that all the surfaces were nice and smooth. After that, I just hung them for a couple days to be sure everything was completely dry before I shot a light seal coat. It worked really well.
    Gary
    Joth and archey like this.
  5. archey
    998
    839
    Nov 28, 2010
    Thanks guys! The tricky part will be sanding the sharper edges and not making the color uneven looking.
  6. archey
    998
    839
    Nov 28, 2010
    jkes01, charisjapan, RAG7890 and 2 others like this.
  7. The Ballzz
    The Ballzz Senior Member
    1,450
    966
    Mar 28, 2013
    Very creative and nice work!
    Thanx 4 Sharin'
    Gene
    archey likes this.
  8. Skyjerk
    5,728
    6,590
    Feb 9, 2014
    Looks like the guy on the cover of "In the court of the crimson king" :)
    Nice job :)
  9. Draxond
    Draxond Member
    68
    36
    May 27, 2015
    As I mentioned, light sanding is the trick. Avoid any form of heavy pressure. A trick I’ve read before (probably here somewhere) is to use a coarse, rough fabric instead of sand paper. Burlap would be ideal. This will level the surface of wipe marks and bumps, but won’t take much filler off the level portions. Should help with those corners.
    And that carving is awesome. Better than I ever could’ve attempted.
    archey likes this.
  10. moreles
    moreles Senior Member
    2,711
    1,339
    Apr 16, 2011
    I'm with Sling Blader. I do the sanding before the filling. I do use oil based filler, which stains, and I absolutely do not stain afterwards. As Sling Blader described, it works really well to wipe. There's no sanding-through, and you get a nice even color and surface. Then you seal and finish, and sand as appropriate to that part of the process. And, OP, it's not a "dumb question." Grain filling is an area where we have many, many different products and techniques being used. People are rarely super-confident or feel like they've mastered it. I sure haven't. I've just found the method that feel best and works best for me. I've read about other, very different approaches that some use beautifully.
    archey likes this.
  11. archey
    998
    839
    Nov 28, 2010
    Got a pretty even looking color, except it chipped a bit off because I left the covers in and it dried. When I took them out a bit of the filler flaked off. Shouldn't be a big deal to put a touch more on that spot I don't think. Now I just need to stain the top and shoot some lacquer on it.
    https://imgur.com/EpqU6kZ
    pinefd and SlingBlader like this.
