Good tube source?
Discussion in 'The Squawk Box' started by rockinlespaul, Dec 2, 2017.
  1. sonar
    sonar Senior Member
    2,869
    1,955
    Sep 10, 2008
    Nonsense.
    Most modern power tubes are more than adequate for the job. Believe it or not some sound really good. And once you get a good 12AX7 (either new or old) it'll last for years, sometimes longer than the player.
    This really is about tone chasing tube rollers. And most tube rolling is based on a bunch of myths and unqualified hype. It took me a lot of time and money to figure that out. Sure, a Mullard EL84 would be optimal for your all original, 1962 AC30, but for an Orange Tiny Terror? It would make little difference to use old tubes when considering the ratio of price to any "improvement" in tone for most modern amps.
    My personal preference for old 12AX7/7025 tubes has to do with my bad luck with modern pre's and microphonics. Tone "improvement" is mostly marginal and varies too much to definitively say one brand is better than another brand with old pre tubes. I've had RCA 7025's and Mullard 12AU7's from the same respective batches sound different.
    Other old glass 9 pin pre's popular in guitar amps (12AU7, 12AT7, etc) are still readily available at good prices.
    Again, once I get a good 12AX7 (new or old) they stay in the amp unless they go microphonic. I have 50 year old 12AX7's still running in 50 year old amps I've owned for 20+ years.
    I miss the old RCA 6L6's, but no way I'm paying that kind of money when there are pretty kick *ss sounding new 6L6 variants like the Tung Sol 7591A.
    ac/dcfan87, fleahead, frankv and 2 others like this.
  2. Thumpalumpacus
    Thumpalumpacus Senior Member
    76,014
    186,241
    Nov 28, 2010
    Agreed, the differences between most tubes are very subtle, and very dependent on the amp itself.
    northernguitarguy likes this.
  3. frankv
    frankv Have You Ever Lost A Love? Double Platinum Supporter V.I.P. Member
    14,551
    12,996
    Aug 25, 2011
    This could be the first time I actually agree with Sonar. And I do agree having rolled more tubes then most of you guys. Most likely anyway. You would be hard pressed to tell a difference... NOS vs Brand new.
  4. Classicplayer
    Classicplayer Senior Member
    2,388
    1,414
    Sep 6, 2007
    You misunderstood. I meant paying the money for today's tubes and not searching and tone chasing prior production tubes.
    Classicplayer
  5. fett
    fett Double Platinum Supporter
    7,551
    6,208
    Jan 21, 2012
    I love anything that has tubes. You name it. I bought a Berlant reel to reel tape recorder. Why? Because it was delivered to me locally. $175. The deck is useless. However, it came with two tubed mic pre-amps. It was made in '50's? I actually tested each one with headphones and a big mic. They worked. Were the tubes up to snuff? The only way to check is having a mutual conductance tube tester. I have two. The stock tubes were tested and were weak. Back to why I collect tubes. I knew I had a 6x5 somewhere. I needed a 12bh7. I bought two online. I found box of tubes I bought years ago. Yikes!!!! I found all of them in spades. Back to old v new tubes. The guys that sell them will give you test results. Tha
  6. Z2112
    Z2112 Gold Supporter
    812
    1,131
    Dec 24, 2012
    I agree with others on here. Save your money for other things.
    I have a good friend that is very well versed in building and repairing amps and has boxes of nib vintage tubes.
    I built an Allen Accomplice 40 watt amp kit. He invited me over so we could fire it up together.
    The kit came with tung sol 6l6's and EH 12ax7's .
    Spent most of the day playing it and rolling tubes. He has a lot better ears than me.
    He would have given me any tube that I thought made an improvement.
    Left with the original kit tubes intact except a vintage 12AT7 for the reverb. To our ears it slowed down the reverb and smoothed it out.
    Thumpalumpacus likes this.
  7. yamariv
    yamariv Senior Member
    1,402
    716
    Jul 26, 2015
    NorthernGuitarGuy, since you're in Canada, PM me if you are in need of any NOS or ANOS tubes. I have a local guy who has pretty fair prices. I've pretty much filled my lifetime supply so I can share the info :naughty:
  8. KP11520
    KP11520 Senior Member
    6,473
    7,215
    Apr 11, 2014
    Fred,
    If the NOS coveted tubes get cost prohibitive (And no doubt, they will) Look into new Genalex Gold Lion EL84s and 12AX7s. If you need more than one EL84, at least you can get them matched and balanced. I doubt you'll get that with coveted NOS. There are premium priced tubes, but not insane like what you're hoping for. They bloom real nice and you'll never look back. Probably not a Metal tube though.
    Hope this helps!
    rockinlespaul likes this.
  9. northernguitarguy
    northernguitarguy SWeAT hOg
    28,624
    47,770
    Feb 22, 2009
    Thank you, my friend!
    yamariv likes this.
  10. akuster777
    akuster777 Member
    97
    111
    Sep 8, 2016
  11. needlespauls
    needlespauls V.I.P. Member
    6,233
    1,202
    Jan 14, 2008
    Not to be difficult, but I slightly have to disagree on a specific topic in your post. The Orange Tiny Terror. I had one, thought it was a great little amp. I had a Korean version I recall. Stock tubes. Sounded really good. I lucked into a vast supply of old pulls from a ham radio guy. Oh my god the difference in changing the preamp tubes to old old RCA’s that tested off the charts was in-credddddible!! To the point of no return. Sounded so much better. Later sold that orange...got a key city 20 combo. The stock shaugang 12ax7b’s sounded great in that amp. Tried my rca’s, Westinghouse, ge’s Etc and it actually didn’t sound as good. So on that not I then also agree. Some amps work better with certain tubes.
    Classicplayer likes this.
  12. ac/dcfan87
    ac/dcfan87 Senior Member
    1,889
    1,428
    Feb 5, 2013
    I haven't been a part of this discussion but this post just sounds rude.
  13. rockinlespaul
    rockinlespaul Oxblood Addict V.I.P. Member
    10,380
    10,565
    Aug 12, 2007
    I found a decent place, thanks Rudi.
    Until I decide what to go with, I went ahead and picked a few things from my dwindling stash.
    I went with two JAN 12ax7s and a old Mullard 7025. Went with a matched pair of nos Tesla's(not JJs), and a EH for the rectifier. It was all I had. I'm very happy with the results.
    RAG7890 likes this.
  14. rockinlespaul
    10,380
    10,565
    Aug 12, 2007
    I just acquired a few RFT 12ax7's from a old forum brother. I'll have to give them a whirl. Pretty happy with the amp right now as it is however.
  15. rockinlespaul
    10,380
    10,565
    Aug 12, 2007
    It's ok, let him think he's important lol.
