Gibson Midtown pickup rings?
Discussion in 'The Custom Shop' started by seratone, Sep 21, 2017.
  1. seratone
    seratone Junior Member
    8
    0
    Apr 8, 2014
    Interested if the Midtown has pickup rings that would be same size as a Les Paul - I realize the top is less arched than, let's say a 335. I found a Midtown on Local classified but the bright white pickups rings and other accessories - I would prefer - need to be swapped out to black.
    Anyone know where you can get replacement rings for a Midtown?
  2. paruwi
    19,968
    26,633
    Dec 24, 2009
    The Midtown has a flat top
    MSB likes this.
  3. PierM
    PierM Black & Gold Premium Member
    2,851
    4,334
    Aug 19, 2016
    Rings code for the Midtown it's the same used for the USA Les Pauls, SG, Explorers etc etc..... since Gibson does not produce native arched rings. They are all flat. If the body is gently carved they can bend naturally around the shape of the belly. If the carve is extreme, then you may need to sand the ring bottom to follow the carve. In your case you have no problems at all, since top is flat and rings are flat.
    https://www.thomann.de/it/gibson_hu...?ref=search_rslt_gibson+pickup+rings_184777_1
    https://www.thomann.de/it/gibson_hu...?ref=search_rslt_gibson+pickup+rings_184771_4
  4. MSB
    MSB Senior Member
    1,650
    1,377
    Jan 21, 2015
    they're flat tops and any Gibson branded rings or "non arched" rings will work. I did this to my red midtown so it had black plastics
    paruwi likes this.
  5. seratone
    8
    0
    Apr 8, 2014
    Merci folks!
