Gibson Les Paul Std 2018 Fretboard Fissures
Discussion in 'Gibson Les Pauls' started by Selendia, Nov 25, 2018.
  1. Selendia
    Selendia Junior Member
    8
    14
    Nov 25, 2018
    Dear all,
    I recently bought a brand new Gibson Les Paul Standard 2018 MB.
    First of all I am very happy with this guitar, but I'm slightly concerned about some small fissures in the fretboard directly in front of the nut.
    What do you think? Is this acceptable or can this lead to some serious problems in long-term?
    Thanks!
    Jewel the Sapphire likes this.
  2. shupe13
    shupe13 Senior Member
    1,781
    1,200
    Mar 8, 2013
    From what I see, light sanding would remedy this, especially if you really like the guitar.
  3. Macronaut
    Macronaut Silver Supporter
    1,211
    1,137
    Nov 23, 2016
    I had something very similar in the same area on my 2017 Standard. I did a little very, very light sanding (more of a buffing) then applied some Fret Doctor and it looks great. That was about 2 years ago and I just checked it again to see if it may need more FD but, it still looks great. Actually, even better than the day I did the work.
    It should be an easy fix. Careful not to over do it.
    scozz likes this.
  4. scozz
    scozz Senior Member
    3,816
    4,578
    Sep 3, 2007
    This is good advice....I’ll stress very light sanding with very fine sandpaper, or maybe 0000 steel wool.
    And I definitely recommend Fret Doctor....great stuff for fingerboards. Use this sparingly also.
  5. dodona
    dodona Junior Member
    25
    17
    Dec 29, 2011
    check out fretboard oil.
    LocoTex and Mockbel like this.
  6. Mockbel
    Mockbel Senior Member
    2,593
    2,535
    Nov 2, 2015
    Before sanding I would just remove strings and treat it along with the rest of fretboard with some oil... it may be just cleaning thing
    Frogfur and LocoTex like this.
  7. Selendia
    8
    14
    Nov 25, 2018
    Thanks for your helpful tips!
    I followed your advice to apply some fretboard oil and it looks at least better now. Do you think this is just a "blemish" or do you think there's a risk the fissures are getting bigger?
    I also recognized that the nut slots of the low E and A string are slightly too wide, you may see it on this picture, but I'll also post a better one when I'm back home.
  8. endial
    endial Senior Member
    2,471
    2,311
    Oct 23, 2014
    I'm sorry Selendia, I just don't see "fissures" as you call them. Maybe the grain gets a little rough there but even if that were the case, there's not a whole lot of wear abuse in that area. Do you do string bends in the first fret off the nut? I think this is being way overthought, and somebody needs their OCD to be put in check for a minute.
  9. DarthPaul
    DarthPaul Senior Member
    186
    424
    Dec 20, 2016
    I believe that OCD accounts for 75% of the QC complaints. We are over-scrutinizing our instruments.
    MP4-22, Geronimo, C_Becker and 3 others like this.
  10. Selendia
    8
    14
    Nov 25, 2018
    Well, that's what I wanted to hear! ;-) Indeed I'm a very perfectionist person...
    Geronimo and endial like this.
  11. scozz
    scozz Senior Member
    3,816
    4,578
    Sep 3, 2007
    Not to start another dilemma with you guitar but the low E string looks a little too close to the edge of the fretboard imo. Looks like the nut slot is cut a little too close to the edge.
  12. Selendia
    8
    14
    Nov 25, 2018
    As announced the pictures of the nut...
  13. Guitpicky
    Guitpicky Senior Member
    177
    222
    Apr 11, 2017
    Cheezits rice! Endial just talked him off the ledge and you're taking his place :)
    Looks fine to me, I think it's just the angle in that pic
  14. Cjsinla
    Cjsinla Senior Member
    3,638
    2,921
    Jul 7, 2014
    That’s a bigger issue than the fretboard. Those slots should not be that wide. You might need a nut job. (I know.....)
  15. endial
    2,471
    2,311
    Oct 23, 2014
  16. scozz
    scozz Senior Member
    3,816
    4,578
    Sep 3, 2007
    Yup, I agree...a new nut is needed.
    You might be right, but the string looks a bit too close to the edge of the fingerboard to me in that first pic. :hmm:
    A new nut will remedy both of these issues. :cool2:
    (Didn’t mean to put you back on the ledge @Selendia :D)
  17. Les Paul John
    Les Paul John Senior Member
    471
    785
    Jun 26, 2018
    You have to measure things out, could be the spacing on the string saddles on the bridge are wrong. Given you've stated the distance in between the E and the A is wider than it should be. Is it also at the saddles on the bridge?
  18. kakerlak
    kakerlak Senior Member
    1,818
    865
    Feb 5, 2014
    Fretboard looks great from the pics you posted. Last two nut slots are obviously way too wide. Are you running super thin strings on it?
  19. yamariv
    yamariv Senior Member
    1,455
    766
    Jul 26, 2015
    OP, can you point out exactly what "Fissures" you are referring to on your fretboard? All I see is rosewood that looks completely normal? I'd call myself OCD and I don't see anything :dunno:
  20. GunMonkeyINTL
    GunMonkeyINTL Senior Member
    171
    226
    May 10, 2015
    I’m betting that what the OP is talking about is the way the openess of rosewood grain shows up against the hard contrast of the white nut. I’ve got a couple coarse-grained fingerboards that it appears more noticeable on, and I’ve seen some that were kinda roughly cut so it looked almost like splinters were missing.
    Unfortunately, the photos provided were focused further up the board, so the area they’re asking about is a little blurry, but you can see one grain-opening or splinter (whatever be it) just to the treble side of the third string in the second pic:
