Gibson Les Paul 101
Discussion in 'Gibson Les Pauls' started by Tim Plains, Jul 1, 2009.
  1. SkunkWorks
    SkunkWorks Senior Member
    662
    54
    Feb 5, 2010
    September 25, 2006 for my Chambered Standard...
    http://www.mylespaul.com/forums/gibson-les-pauls/87875-ngd-2006-standard-ebony.html
    http://www.mylespaul.com/forums/gib...-opinion-asap-pending-purchase-chambered.html
  2. NettoCPS
    NettoCPS Junior Member
    4
    0
    May 24, 2016
    I need some info on this Les Paul Alpine White I just got.
    I see Its a CS52314 so it would be 2005 and the numbers of it made right? The certificate says it's hand-built by the historic plant so I'm confused about being a historic or not. I also see two "tops" on the back and in the front of the guitar is that correct? Can someone help me out with more info. I don't know much about Les Paul's. Thanks.
  3. Tim Plains
    Tim Plains Senior Member
    12,531
    7,805
    Feb 11, 2008
    It is a 2005. CS5 could also be a 2015 but they have different certificates.
    It's not a historic. That's just the name of the Custom Shop.
    The two-piece top is normal. I think the common belief is that Customs have one-piece mahogany bodies but it's hard to tell since most are painted over. I guess it's possible that some have two-piece bodies. If you see a line going down the body, then it must be.
  4. Jjungema
    Jjungema Junior Member
    10
    0
    May 28, 2016
    awesome info thank you!
  5. NettoCPS
    4
    0
    May 24, 2016
    Thanks for the Info
    For what I can see here its one piece. Its a great guitar, but only whish Gibson would put bettter electronics in it, gibston pots on a custom shop guitar is so ****ty cost saving option in my opinion.
    Is it worth upgrading to the RS kit with the CTS Pots and the .22 an .15 Uf caps?
    Thanks (Sorry to ask this but dont) know much about electronics.
    Thanks
  6. HardCore Troubadour
    HardCore Troubadour Senior Member
    8,423
    6,284
    Nov 17, 2012
    I wonder where Gibson gets those ****ty pots from???
  7. Spiderbob
    Spiderbob Junior Member
    4
    2
    Aug 13, 2012
    Thanks for the awesome thread!
  8. DaddywantsaBatmobile
    DaddywantsaBatmobile Junior Member
    21
    20
    Apr 25, 2017
    Fantastic info and learned a lot just from this one thread. Just bought my first LP, so this 101 has just filled my head space very nicely. I now have a 2010 Studio Ebony 60's Tribute, with a dodgy output jack and strings are 10's methinks (bit too heavy for my fingers). It's the one with P90 Pups and the 'worn' look and it sounds like a dream. Good entry level for my first I thought, just needs a slightly better set up to make me happier. So first job, I am now gonna drop a string size and fix the jack. I don't mind the small issues, cause the guitar was a steal. One thing, although the seller threw in a HC it's too big, so what is a better case to look out for in the UK on a budget? Or should I just go to a local GC and try some? (Not too many in my city tho).
  9. Dick Banks
    Dick Banks Senior Member
    547
    647
    Apr 27, 2017
    After looking at the weight-relieved x-ray on Tim's OP (excellent photo!), it seems to me that there isn't much "weight relieved" in those 9 little holes. Half a pound maybe? But more likely a better balanced guitar is the desired outcome...
  10. garybaldy
    garybaldy Senior Member
    1,724
    925
    Apr 10, 2011
    Try Gear4music. I got a nice SG case with a mock croc skin look from them.
  11. Gerald Gates
    Gerald Gates Junior Member
    1
    0
    Nov 22, 2017
    I had a re-fret from Terry Parker at Terry Parker Customs on my r-9 about 6 months ago and one of the frets is loose.
    Should I contact him t repair or just glue it myself?
  12. HardCore Troubadour
    8,423
    6,284
    Nov 17, 2012
    contact him, that should not happen.
  13. holmcross
    holmcross Junior Member
    7
    0
    Dec 28, 2016
    Late to the game, but I was under the impression Traditionals were neither weight-relived nor chambered.
  14. Les Paul Newb
    Les Paul Newb Senior Member
    965
    664
    Jul 3, 2012
    That started with the 2014 trads, I believe. Could be 2013. In any case, it's becoming more common. Even the 2018 Classics are non weight relieved.
  15. RokkaRolla
    RokkaRolla Member
    89
    13
    Jan 8, 2014
    Hi guys, I'm interested in buying this 2012 Les Paul Classic. Does it have 9 holes or chambering?
    I also wonder when Gibson dropped specific s/n on Classics and brought back Les Paul Model to headstock.
    Thank you!
