Gibson Branded Pots Suck (A Rant)
Discussion in 'Gibson Les Pauls' started by Malchik, Sep 11, 2017.
  1. Malchik
    Malchik Senior Member
    1,132
    863
    Mar 28, 2012
    I have had such bad luck with Gibson pots. I have had three Les Paul Customs (two new) in the past few years and they all had scratchy pots. My new custom spec'd Les Paul Custom, a guitar that is only two weeks out of the factory, has two scratchy volume pots. It wasn't until practice that I had the volume to a point where the chatter became obvious. I have had Rickenbackers and cheap Ibanez's that have not failed in the pot department as much as Gibson has. Rant over.
    Rhust likes this.
  2. Leña_Costoso
    Leña_Costoso Senior Member
    733
    687
    Aug 28, 2017
  3. sk8rat
    sk8rat Senior Member
    10,214
    13,551
    Sep 28, 2014
    you could always swap them with 250k alpha pots :dunno:
    Bsthetech likes this.
  4. Kris Ford
    Kris Ford Senior Member
    4,754
    4,035
    Dec 17, 2011
    They should have not stopped using CTS early 1995ish..
  5. cybermgk
    13,620
    18,049
    Jul 7, 2011
    Um, considering what Rics cost, I would hope they had no issues.
  6. guidothepimmp
    guidothepimmp Senior Member
    585
    547
    Sep 8, 2012
    i did the Memphis factory tour in June, and unless i completely misunderstood, there appeared to be a station that put the pots together from the components, i couldnt get a view to see if they were in fact doing that, or if what they meant was they were putting the components together for the guy to solder the harnesses for quick installation.
    either way, i find my gibson pots to feel loose compared to the cts in my tokai or even to alpha pots..
  7. Malchik
    1,132
    863
    Mar 28, 2012
    The taper of the pots is pretty decent, they do feel loose to turn. Maybe I'll try some contact cleaner but I think I'll just install an RS Guitar Works harness.
  8. Frozen Rat
    Frozen Rat Member
    76
    116
    Mar 3, 2016
    I come across these threads from time to time: "Gibson pots suck, Gibson pickups suck, Gibson wiring sucks, Gibson tuners suck." If you bought the guitar to modify it because you're bored with just having a great guitar, admit it.
    C_Becker and efstop like this.
  9. Malchik
    1,132
    863
    Mar 28, 2012
    No, I didn't pay $7700 dollars for a guitar with scratchy pots and loose pickup selector. I custom ordered this guitar to my spec so I didn't have to do anything to it.
  10. matt@msscguitar
    matt@msscguitar V.I.P. Member MLP Vendor
    9,628
    6,486
    May 5, 2008
    I reasonably sure the Gibson branded pots were made for them by CGE.
    Either way, they are mediocre at best.
    Kris Ford likes this.
  11. chasenblues
    chasenblues Senior Member
    20,842
    30,929
    Apr 2, 2007
    I couldn't see Gibson building their own pots in house..More likely the second scenario.
  12. Malchik
    1,132
    863
    Mar 28, 2012
    I'm pretty sure all pots are now manufactured in East Asia.
  13. Guitaraxe
    Guitaraxe Senior Member
    738
    344
    Aug 22, 2015
    They seem to have the widest (+/-) tolerance % going.
  14. yamariv
    yamariv Senior Member
    1,341
    659
    Jul 26, 2015
    I was just noticing the same issue with my Standard's pots. I thought Gibson still used CTS but I guess I was wrong... My Bridge Volume pot already feels worn out an loose after a couple years of playing. Both Vols are scratchy too! All my other Guitars with CTS don't do this. I guess it's time to change out whole PCB board....kind of a pitty to pay over 3k for a guitar with cheap pots in it.....
  15. Leotis
    Leotis Senior Member
    890
    496
    Jul 4, 2014
    It depends on whether Gibson paid their suppliers on time or not. I have several friends that are current and former Gibson employees and I've heard more than one story about them putting cheap no-name pots, caps, tuners, etc on $2K-$4K guitars just to make quota when their regular suppliers had cut them off due to non-payment. These stories all reportedly occured during the last 5-7 years, btw...
    Inside Guy likes this.
  16. ido1957
    ido1957 Senior Member
    388
    266
    Jul 18, 2014
    $7700 is a lot of money. You have a warranty claim I suppose. Hope there's a local shop that will help you out, or contact Gibson I guess.
  17. GitFiddle
    GitFiddle Senior Member
    10,915
    13,515
    Jun 2, 2010
    I just replace them in all my LPs. Even my R7. Jonesy's 50s harness has never failed me. Gig with them all in five different LPs.
    I got this 65 Silvertone brand new for Christmas when I was a kid. Still have it. All original. Gibson mini-buckers. All the controls still work just like new. No scratch or crackle at all and I have never cleaned them.
  18. Malchik
    1,132
    863
    Mar 28, 2012
    So I flushed out all four pots with contact cleaner and spun the knobs about a hundred times each and still get a very audible crackle when turning the volume down from about two to zero. Also the neck treble scratches a lot, too. The only pot that seems to work is the bridge tone control.
  19. yamariv
    1,341
    659
    Jul 26, 2015
    So you're saying the contact cleaner didn't fix the problem?
    Tinpan likes this.
  20. EndGame00
    EndGame00 Senior Member
    734
    351
    Sep 1, 2013
    The push-pull pots on the Studios I tested felt cheap, it felt wobbly and almost no resistance when I roll off the volume...
    My biggest beef is definitely the PCB board, I'm thinking of ripping them out of my 50's Tribute and rewire them into 50's wiring...
    C_Becker and JohnInNJ like this.
