Gibson ABR-1 question
Discussion in 'The Custom Shop' started by Have FUN, Apr 9, 2017.
  1. Have FUN
    Have FUN Senior Member
    1,391
    1,334
    Apr 27, 2011
    I switched the bridge on my Les Paul Tribute, I prefer ABR-1 bridge :)
    My question is : how to proceed to notch the saddles, what Tools should I use ? Thanks
  2. rlefty
    rlefty Premium Member
    748
    451
    Jun 14, 2013
  3. guitarjoem
    guitarjoem Double Platinum Supporter MLP Vendor
    497
    257
    Dec 15, 2014
    Yup. A dead blow hammer. Use the end of the string you are going to cut off. Lay it across the bridge in the correctly spaced spot and hit it with the hammer to create an indentation in the saddle. Works well.
    Blue Blood likes this.
  4. oachs83
    oachs83 Senior Member
    580
    337
    Feb 23, 2012
    I recently asked the same thing. What they said also if needed take a small needle file to deepen you only want about half of the string seated. Remember to use an old string to rub back and forth in the new notch to remove any burs.
  5. ARandall
    ARandall Senior Member
    11,783
    7,176
    Apr 16, 2012
    The hammer trick only works to locate the centre. You want a nice notch with a smooth clean end free of burrs so the string won't break nor be dulled by semi vibrations.
    guitarjoem and Blue Blood like this.
  6. Riffster
    Riffster Senior Member
    310
    180
    Apr 9, 2010
    I recently notched replacement brass saddles on a Epi and a standard small hammer worked well, I do have a dead blow hammer but did not use it.
    A single blow on every string worked well, not sure if I simply go lucky or what.
  7. Have FUN
    1,391
    1,334
    Apr 27, 2011
    Done , thanks
    Fredde_basf, RayTorvalds and The_Nuge like this.
  8. jimbob137
    jimbob137 Senior Member
    367
    83
    Oct 11, 2011
    Best thing to do after tapping in your grooves is grab an under string radius gauge, probably will be a 12. And file your string slots using nut files to match the radius of the fret board and then smooth off the saddles and so that the strings are no more than half way into the grooves that you've made and leave the saddles ultra smoothed off and buffed so the strings wont bind.
  9. ashbass
    ashbass V.I.P. Member
    654
    478
    May 3, 2007
    I use the hammer trick too. So does gibson. But be carefull not to hit it too hard as you can bend the screw that moves the saddle. A bent screw can make it hard to turn. It will alsow raise and lower the saddle depending on where the screw is left.
    I got this off of a new gibson guitar. Replaced it.
  10. judson
    judson Senior Member
    2,742
    2,659
    Jan 26, 2016
    i was thinking exactly that when watching that video but i am amazed at the same time how well the hammer blow works...
  11. moreles
    moreles Senior Member
    2,710
    1,337
    Apr 16, 2011
    It's amazing what a POS the Gibson ABR-1 really is. It's a decent overall design, but the execution is sloppy and the materials are inferior. Still, we're mostly stuck with it if you prefer to keep things stock. Using the dead blow hammer to create an indentation to position the string is definitely the way to go. Deeper notches and the like are, 99.9% if the time, done in ways that cause buzzing and deadening of tone and sustain. We sometimes need to file deeper slots to match string height to neck radius, but when I encounter this situation, I reduce the overall height of an individual saddle by taking off thr excess height. Then I do the deadblow move rather than filing a bad, deep groove.
  12. ashbass
    654
    478
    May 3, 2007
    ^me too. Enough tap to keep them from moving on the plain strings and a little file to smooth out the grooves on the wound strings. I keep them on top.
  13. valvetoneman
    valvetoneman Senior Member
    1,193
    699
    Aug 14, 2011
    I've done it both ways and i won't be deepening any saddles ever unless I absolutely have to, it caused too many problems for me, I ended up chasing a citar type noise for ages on the high strings
