Gibson 496 R 498 T question.
Discussion in 'Pickups' started by Damiendunky, Jul 25, 2017.
  1. Damiendunky
    Damiendunky Junior Member
    17
    6
    Mar 22, 2017
    What would be good budget alternatives to these two pick ups?. Thanks.
  2. Dilver
    Dilver Senior Member
    833
    1,142
    Apr 26, 2011
    what's your budget?
    cooljuk likes this.
  3. ARandall
    ARandall Senior Member
    11,785
    7,178
    Apr 16, 2012
    Look at GFS pickups for cheap-end.
    Duncan Custom + 59n for mid/low priced
  4. cooljuk
    14,091
    17,954
    Mar 12, 2009
    Alternatives to change the sound away from those pickups while costing less or alternatives that sound similar to them but cost less?
  5. Dilver
    833
    1,142
    Apr 26, 2011
    Buy used.
    Eric R likes this.
  6. Damiendunky
    17
    6
    Mar 22, 2017
    Yes. Looked into Gibsons and with postage to Au too dear. Would buy 'used' also. Thanks all.
  7. Antigua
    Antigua Senior Member
    499
    148
    Oct 15, 2016
    It looks like you're going for a hotter set. This appears to be a killer deal http://www.byoguitar.com/Guitars/Eruption---Humbucker-Set__BYO-ERUPTION-SET.aspx Nickel silver base plate, possibly a wood spacer, if it follows the Blizzard of 59 set. That's the dirt cheapest I've ever seen a humbucker, let alone a set, with premium appointments. It looks like they're closely related to Tonerider, possible using the same parts or made at the same factory.
    Damiendunky likes this.
  8. Damiendunky
    17
    6
    Mar 22, 2017
    Thank Antigua looks like a good deal even the postage to Au is very good. Thanks again.
  9. C_Becker
    C_Becker Dat Gibson smell
    1,870
    1,753
    Jul 7, 2015
    496R and 498T is an unusual combination. The 498T is usually paired with 490R, while the 496R "belongs" to the 500T.
    I think buying used is your best bet in both cases, since a lot of people swap out their stock Gibson pups.
  10. Eric R
    Eric R Member
    42
    19
    Nov 22, 2016
    Have a 496R laying around. could help you on this.
