Gibson 1959 Explorer Replica build
Discussion in 'Luthier's Corner' started by Marn99, Sep 13, 2017.
  1. dcomiskey
    dcomiskey Senior Member
    115
    52
    Sep 19, 2016
    Wow. Never knew the build of the LPJ was so...crude.
    Marn99 likes this.
  2. Marn99
    Marn99 Member
    37
    7
    Sep 13, 2017
    I know right? I had the same thought!
  3. ARandall
    ARandall Senior Member
    11,337
    6,498
    Apr 16, 2012
    The build of most guitars from that era were crude.
    Marn99 and RAG7890 like this.
  4. Marn99
    Marn99 Member
    37
    7
    Sep 13, 2017
    It sure did work though! Just look at the telecaster, what with its bolt on neck and 2 to 4 piece bodies, easily one of my favorite guitars.
  5. jgriffin
    jgriffin Junior Member
    7
    6
    Aug 20, 2012
    I saw an SG Jr. where the tenon was roughly chiseled flat. They didn't bother to sand it flat before finishing.
    Marn99 likes this.
  6. alk-3
    alk-3 MLP Sponsor
    2,045
    3,221
    Jan 8, 2008
    The guards on explorers are cellulose nitrate. all Gibson guards that were multi ply were made from cellulose nitrate, and so were the truss rod covers.
    The side dots on all gibsons (including the white side dots on Jr's and explorers etc.) are also cellulose nitrate.
    Les paul binding is actually 2 ply, laminated with an invisible seam, but can be delaminated if you work at it. it is royalite which is a type of abs.
    Les paul neck binding was cellulose nitrate.
    back plates were all royalite abs as well.
    Marn99, RAG7890 and The_Nuge like this.
  7. replaburst59er
    replaburst59er Senior Member
    276
    36
    Apr 20, 2009
    Good day Tom!
    I have a question. What was the actual material type of the Gibson single ply PG material, tortoise shell like that of was on the LP juniors?
  8. Bill Hicklin
    Bill Hicklin Senior Member
    7,136
    9,098
    Nov 3, 2014
    That is incorrect. 50's Gibson pickguards were cellulose acetate butyrate (CAB). Body bindings were Royalite, an "alloy" of ABS and PVC.
    Marn99 likes this.
  9. Open_Book
    Open_Book Senior Member
    1,169
    668
    May 26, 2014
    Marn99 likes this.
  10. RAG7890
    RAG7890 Premium Member
    13,291
    19,968
    Jul 11, 2010
    Ouch, Joe Ganzler..........that brings back memories.
    :cheers2:
    Marn99 likes this.
  11. Bill Hicklin
    7,136
    9,098
    Nov 3, 2014
    I think the confusion may stem from the fact that Gibson flattop "tortoise" pickguards were indeed nitrocellulose.
    Marn99 likes this.
  12. Marn99
    Marn99 Member
    37
    7
    Sep 13, 2017
    Source for this info? No offense but I feel like mr. Bartlett might be right on this one, considering the multiply fender pickguards were all cellulose nitrate.
  13. alk-3
    alk-3 MLP Sponsor
    2,045
    3,221
    Jan 8, 2008
    I can assure you, you are incorrect on this one. the multi-ply guards made by Gibson through the 60's and maybe even into the 70's were cellulose nitrate. if you've ever worked with it, you'll note an immediate and pungent camphor smell that only cellulose nitrate has. Also, you'll note its very flammable. the inlays were also made from cellulose nitrate.
    The body binding on the les paul was ABS. the only part of a Gibson that was CAB to my knowledge (and I'm quite sure of this) were the strap buttons on the plastic buttoned 335's (and similar guitars) and the pickup rings on humbucker guitars, and the p-90 covers of the earlier guitars (pre '57).
    Like i mentioned, the truss rod covers are also made from cellulose nitrate.
    CAB is an injection molding plastic, rarely found in sheets (unless they are smaller sample sized sheets that are themselves injection molded).
    I have spent a great deal of time and expense looking into this, and can tell you with certainty that this is true.
    Marn99, RAG7890 and paulmarr like this.
  14. alk-3
    alk-3 MLP Sponsor
    2,045
    3,221
    Jan 8, 2008
    they too were cellulose nitrate. same as the side dots on a les paul neck.
  15. RAG7890
    13,291
    19,968
    Jul 11, 2010
    Yep Tom is correct, he did spend a lot of time & $$$ on this, that is for sure. :thumbs:
    Although “ejection” should be “injection”. :p :D
    :cheers2:
    Marn99 and alk-3 like this.
  16. Marn99
    Marn99 Member
    37
    7
    Sep 13, 2017
    Its been a while since I updated, but the CITES certified stump Brazilian arrived recently, here it is!
    RAG7890 likes this.
