Fryette Power Station
Discussion in 'The Squawk Box' started by El Kabong, Sep 25, 2015.
  1. El Kabong
    El Kabong Senior Member
    5,770
    7,583
    Aug 12, 2013
    Yeah... that works! Did your Bassman come with Jensens? How do those compare with the Greenbacks?
  2. Six Gun
    Six Gun Senior Member
    1,024
    1,457
    Jun 24, 2012
    I have both the old Jensens P10R
  3. Rick Maxwell
    Rick Maxwell Senior Member
    111
    128
    Feb 6, 2013
    Thanks fit the info!!!
  4. homenote
    homenote ROCKSTAR INC (T.M) V.I.P. Member
    2,877
    1,243
    Jan 15, 2010
    Just took a look at the site and it looks like they are sold out. Anyone know how long its been?
  5. Six Gun
    1,024
    1,457
    Jun 24, 2012
    Wow, I'm so happy I got mine. I cannot play very much but when I have a few minutes that allows me to play I really enjoy it. When this happens you will see people selling them for 800.00 on ebay, or auction bidding wars.
  6. homenote
    2,877
    1,243
    Jan 15, 2010
    Well, i used to own a Alex and it was fantastic so no biggy, I ll just go that direction if they are out for to long. :thumb:
  7. homenote
    2,877
    1,243
    Jan 15, 2010
    I never could gel with the FT.
    Had a 'wet blanket' feel/sound to it, to me.
    On the PS's, are you guys bringing down yer speakers to match the drop in volume, at all? like if normally a 4 12, using 2 12, 25 or 35 watters?
    Matty, I bet if you only used 2 of those black backs when attenuating 1/2 down or more, would be perfect!
  8. El Kabong
    5,770
    7,583
    Aug 12, 2013
    I ain't... my favorite speaker with the PS right now is the one in my King Snake... and since it has 10/60/100 watt options the speaker is pretty much good to go at any volume. The PS sounds equally as well through the greenbacks, creamback and alnico blue I run it through... but for now the KS has been getting the bulk of the play time. :cheers:
    1 person likes this.
  9. Matty
    Matty Senior Member
    8,132
    11,428
    Dec 14, 2010
    If I can't get a 4x12 quiet enough I'll just plug into my THR. Or use headphones.
  10. homenote
    2,877
    1,243
    Jan 15, 2010
    :hmm: What is a THR?
    My point/question about using 1/2 the amount of speakers has more to do with preserving feel and the speakers breaking up the same way they would with the amp at its 'sweet spot if you aren't attenuating.
    Dimed Marshall with a 4-12 (blackbacks) would = Dimed Marshall with the volume, attenuated down 1/2 way using 2-12 blackbacks. :hmm:
    If we cut the volume down by 1/2 w the attenuator, it only makes since to match the inefficiency of half the speakers to get the same thing as a end result, right? (not a perfect match or exactly 1/2 but generally speaking with the sweet spot of course varying in location)
    This always seems to be left out, of all the attenuator discussions, for some reason- and I just thought I would get yalls input on it.
    When I had the fluxtone it operated from a similar principle (dropping the magnet strength) but im not talking about dropping volume as much as matching up the 'already lower attenuated volume' with the less efficient speakers or less speakers to wind up w the exact same things (as close as possible) to the overall un attenuated experience, from the same rig at lower volumes. I would think it would be almost exact, minus some headroom.
    To clarify a little, i am speaking more in the context of 'stage volume' live, not necessarily bedroom levels.
  11. El Kabong
    5,770
    7,583
    Aug 12, 2013
  12. homenote
    2,877
    1,243
    Jan 15, 2010
  13. Matty
    Matty Senior Member
    8,132
    11,428
    Dec 14, 2010
    I don't find a hell of a lot of difference between a 1x12 and a 4x12 at low volumes. :hmm:
  14. joesatch
    joesatch Senior Member
    4,104
    2,721
    Apr 3, 2009
    i keep seeing these online and i'm confused as to what it is.Is it an amplifier or a load box or an attenuater or a cab simulator. is it stereo? is it a poweramp? WTH is it?
  15. El Kabong
    5,770
    7,583
    Aug 12, 2013
    amplifier... yes
    load box... yes
    attenuator... yes
    cab simulator... no
    stereo... two speakers out capability, so I guess that would be a yes
    poweramp... yes
    So basically its a power amp and attenuator in one. It also has an effects loop and the ability to select input impedance and output impedance for mixing and matching your current cabs. It also has some unique EQ abilities... :cheers:
  16. Riffraff12571
    Riffraff12571 Senior Member
    720
    902
    Aug 3, 2011
    I'm 99.9% sure this is a no too but that's not a bad thing. You could use this as one half of a stereo rig buy using it with an amp that has an efx loop with a stereo reverb or delay in it and run one side into the return of that amp and the other into the return of this.
    You guys are giving me G.A.S. :D I've got so many vintage amps that would benefit with one of these.
  17. Brutus
    Brutus Senior Member
    575
    577
    Jun 22, 2010
  18. El Kabong
    5,770
    7,583
    Aug 12, 2013
    They've been out of stock for quite a while now... I wonder what's up with that... :hmm:
  19. IronWeso
    IronWeso Senior Member
    2,050
    1,453
    Jan 12, 2008
    I'm going to sell mine in the next couple of weeks for anyone interested
  20. El Kabong
    5,770
    7,583
    Aug 12, 2013
    I've heard there is an updated version slated for release which addresses the issue of the volume knob being too sensitive when attenuating higher wattage amps... that was a big problem and I'm glad they addressed it.
