Friedman be-od review
Discussion in 'Pedals' started by Mr Insane, Dec 23, 2017.
  1. Mr Insane
    Mr Insane Senior Member
    10,723
    5,694
    Dec 8, 2008
    I have a Phaez Power Train that is supposed to be based off the Friedman Pink Taco circuit.
    Sadly, it doesn't get that modern sound on it's own. I have to use an Overdrive to get the sound I'm after. I use a Fulltone OCD that gets it into the hard rock/metal territory.
    I went to Sweetwater HQ today to demo the Friedman BE-OD. I tried it with a Blackstar Artist 30 (blackstar's take on a low gain 6L6). With that amp, it sounded great. Heavy but defined. No flub. Was satisfied enough to buy it.
    Took it home to try with the Phaez. Was not a good match. Push the pedals gain too much past 8 o'clock and it just flubs out. Also hiss and noise was more than usual. I also tried it with my Hughes and Kettner, just lacked punch and depth.
    It might work okay with a Fender style amps, but didn't work for my application . I will be returning it tomorrow.
  2. Duane_the_tub
    Duane_the_tub Senior Member
    1,930
    3,204
    May 31, 2015
    Do you have a loop on the Phaez, or are you putting it in front?
  3. Mr Insane
    10,723
    5,694
    Dec 8, 2008
    No loop on the amp
  4. flamesarewicked
    flamesarewicked Senior Member
    571
    587
    Feb 12, 2013
    I’ve used mine through the front of a 100w JCM 2000 Head.. on the clean channel .. with the gain on the clean channel turned up to about 3/4... sounds great.. just a little noisy but that’s to be expected.
  5. bluefrog
    bluefrog Senior Member
    945
    228
    Mar 15, 2009
    I did not like the BE OD ! because of the lack of the mids ! I found it too scooped.
    The plexi mids were missing -for my taste!!!
    the Xotic SL had "it" by nature. so the BE went back.
  6. LenPaul
    LenPaul Premium Member
    2,914
    3,988
    Jul 13, 2012
    First thing I did with the BE-OD was turn the internal gain pot down by about 25 %.
    I wouldn't pass on this pedal till you've tried adjusting the internal gain pot .
    changes everything, for the better, in my option.
    needlespauls and freak like this.
  7. freak
    freak Silver Supporter
    4,062
    4,972
    Feb 20, 2012
    I have a BE-OD and run it through a fender dual reverb.
    glorious.
  8. needlespauls
    needlespauls V.I.P. Member
    6,232
    1,198
    Jan 14, 2008
    Yup...gotta dial in the internal trim-pot to your taste. Great pedal.
