Fretless Bass neck coating
Discussion in 'Luthier's Corner' started by fumblefinger, Sep 19, 2017.
  1. fumblefinger
    fumblefinger Senior Member
    1,184
    481
    May 10, 2012
    Anyone have a recommendation on an abrasion coating for a fretless bass fret board? I've heard CA and epoxy. Anything else someone has tried?
    Yes, I told him to quit using roundwounds...
  2. SlingBlader
    SlingBlader Premium Member
    255
    178
    Dec 7, 2013
    I've used epoxy with decent results. I love rounds on a fretless, don't be hatin'! :)
    mux164 likes this.
  3. D Rhinehart
    D Rhinehart Senior Member
    262
    126
    Dec 13, 2011
    I wonder if a 50 50 mix of poly and mineral spirits would work built up in mutiple coats knocked down then buffed ? easy to do and in multiple thin coats you should be able to keep a good control of the radius :wave:
  4. fumblefinger
    1,184
    481
    May 10, 2012
    Epoxy seems to be a consistent theme.
    I had one noted luthier tell me that the poly thing just wouldn't hold up very long. I've wondered about 2K? I don't know if it's really any harder than normal poly, but you wouldn't have to wait as long for it to harden.
    A friend/luthier insists CA works well. A little tricky to apply.
    It sounds like no matter what the material it's a royal PITA. Re-tape after each coat. Hope it doesn't sneak under the tape. Scrape the edge flat after each coat. Sand contour every two or three coats. Use at least half a dozen coats. After final sand, go through the compounds to buff it out.
    I'm pretty sure this customer doesn't have the cash for that much labor.
  5. Open_Book
    Open_Book Senior Member
    1,169
    668
    May 26, 2014
    Look into Jaco Pastorius' bass. IIRC he used a Marine Grade boat Varnish.
    Actually Pedulla were one company using something on their Fretless basses - you could email and ask what product it is - bottom of the page:
    http://www.pedulla.com/html/mvp_buzz.html
  6. LtDave32
    LtDave32 Sua Sponte Super Mod Premium Member
    26,623
    74,796
    Mar 19, 2010
    What I had read is that Paco used a marine epoxy, which is incredibly tough.
    But still, there was wear.
    The thing that worked well on a fretless bass that I did for a guy was to make the FB out of very hard wood, in this case wenge, and use semi-flat wounds for strings. They don't tear up the board as much as full round wounds. One of course loses a bit of highs when going from frets to fretless, but gains back a portion of them by using semi-rounds.
  7. Freddy G
    Freddy G V.I.P. Member
    10,071
    19,538
    Mar 18, 2007
    I've used CA. Yes...tricky to apply. I've also used West System epoxy and that's OK....but the best thing hands down was polyester clear coat. Way tougher and longer wearing than anything else I've used.
    fumblefinger likes this.
  8. WhiteEpiLP
    WhiteEpiLP Senior Member
    1,136
    785
    Nov 29, 2012
    Put an ebony board on it. Now i know thats probably not an option but my buddy has a fretless Godin with an ebony board with no wear yet after a few years. He uses flatwounds on that one though so that helps.
    I'd second that polyester resin is stupid tough, just dont get it anywhere you dont want it.
  9. fumblefinger
    1,184
    481
    May 10, 2012
    How many coats did you shoot Freddy? And what brand did you use, please?
    For sure, this customer can't afford a new fret board. I'm sure his inquiry is to find some way to stop the wear and still keep it playable at the lowest cost.
    Any thoughts on the longevity of some 2K?
  10. geoffstgermaine
    geoffstgermaine Senior Member
    378
    947
    Feb 7, 2013
    I've used West System 105 epoxy and System 3 Mirror coat. They're certainly a pain to apply with the long cure times. Generally most people will build a dam around the fretboard to do this (I did) I've seen people have issues where there was a small leak in the dam that was not apparent until after the person had determined things were good and left the epoxy to cure unsupervised. This resulted in a great mess.
    A polyester that you could spray would certainly be an excellent way to go for this.
  11. Freddy G
    10,071
    19,538
    Mar 18, 2007
    3 coats of Simtec polyester....way tougher than 2k
