Fractal used for Real Amp Design!!!
Discussion in 'Amp Modeling' started by nicolasrivera, May 13, 2017.
  1. nicolasrivera
    nicolasrivera Senior Member
    19,580
    10,690
    Dec 3, 2008
    Wanted to share something i find pretty amazing, an amp designer using Fractal to virtualy design a analog tube amp for production. I'm talking about the Carol Ann Triptik 2.
    here is what the designer said in a TGP thread:
    When I designed the Triptik 2 model, this was done in reverse. It was proto-typed as a model in Axe long before it was a physical prototype. I saw value in testing the concept first, kind of used the Axe as a first level design / audio test tool. It worked tremendously well and certainly shortened the design timeline quite dramatically and with much less expense. While this toolset is not available through the user interface, Cliff is a close friend of mine and made some suggestions to the original Triptik model that I took on board and drew up a schematic. He then modelled it in the Axe using the original Triptik has a foundation.
    https://www.thegearpage.net/board/index.php?posts/23945706/
  2. Its Luke
    Its Luke Senior Member
    789
    564
    Dec 31, 2012
    Huh...
    That is interesting.
    Thanks for sharing Nico
    nicolasrivera likes this.
  3. matthew bear
    matthew bear Senior Member
    4,356
    4,970
    Nov 9, 2008
    that's pretty wild!
  4. frankv
    14,535
    12,949
    Aug 25, 2011
    It's almost like why bother. Just use the AXE.
    lakeburst likes this.
  5. mmd
    mmd Senior Member
    2,435
    2,358
    Sep 24, 2012
    Well, we both know WHY....there are dudes that would rather lose their arms than use a modeler. Plus, if the CarolAnn dude can still sell the amps, why not? Lol....
  6. Liam
    Liam V.I.P. Member
    5,951
    2,403
    Nov 19, 2007
    This had occurred to me last year as a possibility, and really glad to hear someone has successfully used it. A bit if me says "why bother?", but I'm betting I do another gig with a small combo before my number is up. I've modelled my Princeton Reverb in the Axe FX, wonder if that will result in me changing the amp at all? (And I really can't remember every change I made to it in the last 35 years).
    Liam
  7. NeubyWanKaneuby
    NeubyWanKaneuby Senior Member
    1,412
    524
    Jun 21, 2008
    Why climb Mt Everest? Cuz you can.
    That's usually my answer when people ask "why (anything)?" :p
  8. Liam
    Liam V.I.P. Member
    5,951
    2,403
    Nov 19, 2007
    My Uncle Gordon has a great explanation. "It will be an adventure!"
    It's why I got into Fractal amp modelling, it's why I got into modifying tube amps and effects pedals, and it probably explains a whole lot of the weird life I have led alongside messing with guitars and amps.
    Liam
  9. Rocco Crocco
    Rocco Crocco Senior Member
    6,587
    7,800
    Feb 8, 2013
    That's pretty cool. there are a couple amps in Helix that are Line 6 originals... probably based on one actual amp or another, but are really their own animal. A few of them are outstanding. It never occurred to my to use modeling as a tool to build the real thing. pretty amazing.
  10. cybermgk
    13,655
    18,134
    Jul 7, 2011
    mwuhahahaha, the worm has turned.
    AllTheSound likes this.
  11. lakeburst
    lakeburst Senior Member
    384
    443
    Apr 17, 2016
    back engeneering from back engeneering
