fixing a crack in the surface?
Discussion in 'Luthier's Corner' started by bluecircle, Nov 21, 2009.
  1. bluecircle
    bluecircle Junior Member
    6
    0
    Oct 22, 2009
    Hi, everyone! I took my epi les paul on an airplane and when it came off it had a crack in the neck... :(
    I took it with me in th cabin as well, and there wasnt any turbulence and the pilot didnt do any stunts or anything like that. it was even in an skb case! :(
    but yeah anyways, donno how the crack got there but its there and was hoping to polish it out cuz the guitar does sound ok.
    any ideas on how to fix this up? attached are some pics.
    any help is appreciated (just please dont tell me to throw the guitar away :D)
  2. theodoropoulos
    theodoropoulos Senior Member
    294
    13
    Oct 31, 2009
    first of all loosen the strings.I supose it's the joint of the neck and the peghead,because the shape is kind of semi-circle.I would tighten the strings far from the normal to open a gab(carefull not to crack it),put Titebond and press it.Clear the area from glue.
    As far as the finish concerns,some expects will help you.You must first find ou what kind of finish it is.Probably Nitro.....I suppose you should sand the area with 2000 paper and then put a little finish with a gun and polish it.But i am not expert in that...
  3. bfcg
    bfcg Senior Member
    4,378
    175
    Dec 6, 2008
    Looks like it is the scarf joint.
    Do these Epi's have a warranty?
  4. diceman
    diceman V.I.P. Member
    29,932
    5,219
    Jul 5, 2007
    I'd think warranty as well. Hopefully you bought it from an authorized dealer and filled out the card. :shock:
    Theodor- Poly finish.
    I'd take it to someone to have it repaired if if isn't getting fixed under warranty. I'd also loosen the strings to 1/2 tension or less.
  5. FLICKOFLASH
    FLICKOFLASH V.I.P. Member
    24,788
    8,421
    Mar 18, 2007
    possibly the neck got stressed in its case.
  6. FLICKOFLASH
    24,788
    8,421
    Mar 18, 2007
    Is the finish black ?
  7. Nickpastar
    Nickpastar Member
    43
    0
    Apr 5, 2009
  8. Gothika777
    Gothika777 Senior Member
    870
    15
    Apr 23, 2009
    Polyfiller:naughty:
