First pedal, what should I know?
Discussion in 'Pedals' started by JonCanfield, Feb 2, 2018.
  1. JonCanfield
    JonCanfield Platinum Supporter Premium Member
    1,816
    4,793
    Aug 15, 2017
    I’m intrigued with the Electro Harmonix Canyon pedal. I’ve never owned or used a pedal before. For now it’s going into a Fender Mustang GT, but later probably something like a Champ.
    Anything I should be aware of, extra things to buy? General wisdom?
    Thanks!
    bulletproof and scooter500 like this.
  2. scooter500
    scooter500 Senior Member
    313
    102
    Mar 30, 2014
    I want that pedal too, but what do you want to do that your current amp - guitar combo can't deliver enough of?
    Rich likes this.
  3. JonCanfield
    1,816
    4,793
    Aug 15, 2017
    If I go with the Champ, ther is nothing beyond volume. This looks to have good reverb and Trem along with looper. The shimmer looks pretty interesting as well. The Mustang isn’t a bad amp, but changing parameters is kind of a pain, and it just doesn’t have that the sound
  4. freak
    freak Silver Supporter
    4,117
    5,100
    Feb 20, 2012
    distortion? Not sure what type of sound you are after?
  5. JonCanfield
    1,816
    4,793
    Aug 15, 2017
    Well I can't type worth a damn sometimes. That was supposed to say that tube sound
  6. Mike J.
    Mike J. Senior Member
    197
    213
    Mar 3, 2008
    The one thing you should know is:
    If you start buying pedals this one won’t be your last one ☝️
    Rich, bulletproof, rtTX and 5 others like this.
  7. JonCanfield
    1,816
    4,793
    Aug 15, 2017
    Well, you can't expect it to sit there all lonely now, can you. :rofl:
  8. frozenotter
    frozenotter Prominent Member (Has a) Premium Member
    2,247
    4,083
    Mar 21, 2016
    Just keep in mind that we are living in a time where there are sooo many of the "same" pedals using different marketing, packaging, paint and chassis themes, etc. Don't fall for all this because it will cost you dearly. :)
    Rich and JonCanfield like this.
  9. Thumpalumpacus
    Thumpalumpacus Senior Member
    75,945
    185,883
    Nov 28, 2010
    If you're using batteries for power, unplug your cables after each playing session, and keep a spare on hand. It's better to go with a wall-wart, though.
    Rich, bulletproof, Who and 1 other person like this.
  10. Side Burns
    Side Burns Senior Member
    816
    1,026
    Aug 28, 2013
    @OP
    The Canyon is a cool pedal. I was dead set on an analog delay, but the canyon looked too cool
    + For extras, i got the mxr tap tempo switch.
    - the delay should go in a loop or after the distortion depending where you get ur dirt from.
  11. tzd
    tzd Senior Member
    5,622
    3,466
    Oct 21, 2011
  12. scooter500
    313
    102
    Mar 30, 2014
    Sweet Baby by Joyo. Only a few smackers.
    Have you seen the shows? You might watch Andy from Reverb.com or That Pedal Show or Shane.
  13. Jymbopalyse
    Jymbopalyse Senior Member
    2,372
    4,716
    Oct 3, 2016
    I was in your predicament a few years back except I didn't even know which peddle I wanted to get first. OR what effects I needed to achieve specific tones.
    I ended up getting a ZOOM G3 which has a plethora of effects. It allowed me to experiment with a ton of effects for cheap, and refine and define specifically what I'm looking for in a "boutique" or specialized, peddle. Not a second of regret.
    Today, for the price of the Crayon you are looking at, Line6 has a M5 multi effect unit that can cover many different effects. It's a cheap way to experiment with different effects and not break the bank.
    JonCanfield likes this.
  14. JonCanfield
    1,816
    4,793
    Aug 15, 2017
    Thanks @Jymbopalyse
    I'm actually looking at the Canyon not the Crayon, but I'll take a look at this as well.
  15. Roxy13
    Roxy13 Senior Member
    3,703
    13,584
    Dec 27, 2017
    This! I had none for 37 years and was perfectly ok with that. Now pedals are becoming like potato chips around here and I had to buy a One Spot to run them all and am now building a pedal board.
    bulletproof, JonCanfield and Mike J. like this.
  16. Duane_the_tub
    Duane_the_tub Senior Member
    2,015
    3,403
    May 31, 2015
    Canyon is a great first pedal. Lots of very cool ambient-type sounds you couldn't possibly get from just a guitar and amp.
    I would just play around with it for a while first, and see not only how much you like it but how much you actually use it. Pedals are indeed a slippery slope; they're expensive, there are hundreds upon hundreds of different ones on the market, it's easy to get sucked in and starts GASsing for one and quite honestly, many of them are underwhelming and even disappointing once you finally get them.
    freak and JonCanfield like this.
  17. efstop
    efstop Senior Member
    2,464
    5,181
    May 30, 2015
    I just read this and laughed out loud. I played for 50 years and never had one single pedal. In the last year, I bought 17, a DI/cab simulator and a power supply/tuner. My Digitech Trio is no longer lonely. I built an acrylic board, but it only holds ten pedals. Rather than built a behemoth board, I may build a box o' cubbies to store them. I ain't even gonna try to hook up 20 pedals :Ohno:
    JonCanfield, bulletproof and Roxy13 like this.
  18. Roxy13
    3,703
    13,584
    Dec 27, 2017
    Lol! I got a Trio in January and then had to get a looper last month. Eek!
    JonCanfield, efstop and bulletproof like this.
