First Burst - Here We Go
Discussion in 'Luthier's Corner' started by Telzilla, Feb 13, 2018.
  1. Caretaker
    Caretaker Senior Member
    5,705
    3,619
    Mar 27, 2007
    You can wet sand to blend it.
  2. Telzilla
    Telzilla Member
    83
    42
    Oct 12, 2008
    Will that work even though I've got a coat of vintage amber, a coat of the orangeish color and then another coat of the vintage amber on top? Also, it's totally dry at this point.
    Thoughts?
  3. pinefd
    pinefd V.I.P. Member Premium Member V.I.P. Member
    9,206
    13,628
    Mar 23, 2007
    I don't have much experience doing hand rubbed bursts, and the experience I do have wasn't too successful...so I can't really offer any advice on how to fix the transition. All I'll add is that you do need to fix it somehow, or start over, because it just doesn't look too good the way it is now. And I have a feeling that if you were to add some coats of nitro on top of that, the way it is, it would just accentuate the problem transition areas.
    Big help, aren't I? :rolleyes:
    Frank
    Pieces en Regalia likes this.
  4. Caretaker
    5,705
    3,619
    Mar 27, 2007
    Wet sanding shouldwork. Ive done many burst finishes and i wet sand between each coat until satisfied.
    Use 2000 grit. Soak it in a glass of water until soft.
  5. emoney
    emoney Senior Member
    7,024
    3,191
    Jan 31, 2010
    Personally, I think you need a middle color to get that hard line out. I always start with the base, like you
    did say the Amber, then I mix in the outer color into about half the remaining Amber to get my
    "transition" coat, then I use the outer color. I actually go so far as to using 4 different colors for my
    bursts. Having said that, I think by using each color into the next one when mixing it, it makes for a
    better transition.
  6. ARandall
    ARandall Senior Member
    12,000
    7,462
    Apr 16, 2012
    Rub in some very diluted yellow dye on that border with swirls.
  7. Telzilla
    Telzilla Member
    83
    42
    Oct 12, 2008
    Here's where we are at this point, after a mix of wetsanding, 000 Scotch brite pad, and a couple more coats of various mixes of dye.
    Like I said, I think I'm going to spray some tinted reranch clear on it before clearcoats. Frankly, I'd like a little more orangey color on the edges, but I'm concerned about blending it in.
    Side Burns and madmusicltd like this.
  8. Telzilla
    Telzilla Member
    83
    42
    Oct 12, 2008
    I just keep fooling around with it, I guess this is a little darker
    Side Burns, jkes01 and smk506 like this.
  9. fretman_2
    fretman_2 Senior Member
    915
    559
    Apr 7, 2013
    Looks much better! Clear coat will bring that out even more I think.
  10. Telzilla
    Telzilla Member
    83
    42
    Oct 12, 2008
    Working on the headstock and I have a question: what do you do if the thing is really shiny but still has scratches. Here's a picture:
    So after many coats of lacquerr, I let it sit for about two weeks, then wetsanded with 1500 and 2000. Since then I buffed with medium and fine Stewmac rubbing compounds. As you can see, it's very reflective, but there are still some fine sctratches. Not sure they come through on the photo, and they're certsinly not very pronounced, but I'd rather not have them there. Especially when I get to the body.
    So, what would you suggest? Just keep buffing with the fine compound?
  11. pshupe
    pshupe Senior Member
    3,388
    2,203
    Jan 19, 2012
    Meguiers swirl remover is good for removing very fine scratches.
    Cheers Peter.
  12. Telzilla
    Telzilla Member
    83
    42
    Oct 12, 2008
    I have some Meguiar's scratchX, this stuff:
    Is that what you're referring to? Or is there something finer?
  13. pshupe
    3,388
    2,203
    Jan 19, 2012
    I have used the swirl remover and it works really well. You'd have to do a little investigating to see whether what you have is similar or possibly a different grit. You could always try a small patch on the back. It does say fine scratch remover but I can't say for sure whether that product is the finest they sell.
    Regards Peter.
  14. Telzilla
    Telzilla Member
    83
    42
    Oct 12, 2008
    I just did a little research, and it's not. First off Meguiars has a LOT of products and the numbering doesn't appear to make any sense.
    The original ScratchX was very fine (ie, low abrasive), but apparently that product has been discontinued, and the stuff I have, ScratchX 2.0, is more abrasive. Some of the meguiars stuff has a handy little arrow on the bottle to tell abrasiveness. I guess I'll go with that. For example:
  15. emoney
    7,024
    3,191
    Jan 31, 2010
    If, by chance, you've jumped the gun, so-to-speak, (I've been there/done that), you may find that the
    remaining scratches are because you left them there during the progression of sandpaper. Did you start
    with the 1500? Also, and you may have said somewhere I just missed it, but what are you buffing with,
    a wheel, hand buffer?
  16. Telzilla
    Telzilla Member
    83
    42
    Oct 12, 2008
    Yes, I started with the 1500, then moved on to the 2000.
    I started the buffing by hand (old cut up t shirt), but I also used these things I bought from Stewmac:
    You put them in a hand drill. I have two, separate ones for Medium compound and fine compound. I Got some Meguiars #9 over lunch (the stuff from above), and I'll try that by hand and see what that does.
  17. emoney
    7,024
    3,191
    Jan 31, 2010
    The minor grit may be why you're still seeing the scratches. I usually start with 400 and work my way up
    to 2000, even though I'm pretty convinced that I'm done at 1600. Routines and all. Each progression
    of higher grit is there to remove the scratches left by the paper before it. If there's scratches significant
    enough to see from 5-6' away, then I'm not so sure you can get those out, especially by hand.
    As a tip; I've had great success buffing out my finishes using an inexpensive Automotive Buffer that I
    purchase from one of the Big Box Stores. I think it was less than $30.00 and it's still going strong.
  18. Telzilla
    Telzilla Member
    83
    42
    Oct 12, 2008
    I see what you're saying, but if I never sanded below 1500, what made the scratches? The fact that they're a little bit circular makes me think they were from some stuff that got caugt under the sponges. I haven't had a chance to get out the swirl remover yet, but I'm hoping it will do the trick. Don't think you would see anything from 5'.
    I have a cheapo buffer- I think mine's from Harbor Freight. I'll probably break that out for the body.
  19. ARandall
    12,000
    7,462
    Apr 16, 2012
    When you sand initially you can often press down hard and create deeper scratches. Plus any folding of the paper or if its not been soaked can lead to deeper marks.
    1500 is very light to start sanding with. I rarely even with many years have a smooth enough top surface to start at 1200 for the final buffing. The initial grit should be such that you can effortlessly get it level in a short time.
    Skyjerk likes this.
  20. Skyjerk
    5,964
    7,079
    Feb 9, 2014
    I start at 800 myself
