Firebird pickup problem
Discussion in 'Pickups' started by 74JMP, Aug 10, 2018.
  1. 74JMP
    74JMP Senior Member
    735
    613
    Jul 1, 2013
    I have some 90's Gibson FB pups that are missing the U Clips that latch on to the legs of the bas plate, that the height screw screws into. Called Gibson they were useless, told me to call stewmac who were helpful but had none. any ideas
  2. LtKojak
    LtKojak Senior Member
    4,076
    2,819
    Aug 26, 2009
    74JMP likes this.
  3. ARandall
    ARandall Senior Member
    12,297
    7,850
    Apr 16, 2012
  4. 74JMP
    74JMP Senior Member
    735
    613
    Jul 1, 2013
    Seriously, that's all you got to do is police message boards. FYI I'm trying to sell the pups and the fewer "issues" they easier they are to sell. Not everyone goes to the same boards, one never knows what a person has in their experience. Besides the nuts are .06 each from stewmac so I just can't order them alone. PS I will be making a post on my 74 LP here and the TGP ...so if you wish to complain again keep your eyes open for that cross post.
  5. cooljuk
    14,713
    19,843
    Mar 12, 2009
    You're not likely to find a factory part. I believe Gibson briefly used those clips as a way to continue using the otherwise obsolete baseplates with the large holes in the feet (if I'm thinking of the same part you are describing).
    What you want to do is get some thin sheet steel, cut/bend it into place, sand/polish the edges so you don't slice your fingers open, and drill/tap it for standard mounting screws (3-48 threads).
    It's a cheap project that doesn't require much skill and few tools. Soldering on nuts can work, but it's a little tricky for a novice and doesn't preserve originality.
  6. 74JMP
    74JMP Senior Member
    735
    613
    Jul 1, 2013
    That's a pretty cool idea, got me thinking if I can find one of a close size, just tap it for the 3-48
  7. LtKojak
    4,076
    2,819
    Aug 26, 2009
    The best solution would simply be to change baseplates. Those are currently available, don't cost much, and won't affect the p'up's aftermarket value.
  8. 74JMP
    74JMP Senior Member
    735
    613
    Jul 1, 2013
    Thank guys ..found a set of clips mircle I found some clips while looking for P90 covers, store was selling an SG pickguard classic with p-90's and that used the clips for bucks so for a great price . Price was cheap enough that I got the p90 covers I needed, and the clips so saved time and shipping so would have been about 10-15 bucks. I can part out the pick guard and the pups and make some money and save a hassle
  9. garybaldy
    garybaldy Senior Member
    1,777
    972
    Apr 10, 2011
    I'd love to see a picture of the clips that you have found. Thanks
  10. 74JMP
    74JMP Senior Member
    735
    613
    Jul 1, 2013
    DSC00336.JPG Here they are, hard to get a good shot, 6mm x 11mm IIRc
    garybaldy likes this.
  11. 74JMP
    74JMP Senior Member
    735
    613
    Jul 1, 2013
