Firebird -"ish" build
Discussion in 'Luthier's Corner' started by pshupe, Nov 5, 2016.
  1. pshupe
    pshupe Senior Member
    3,312
    2,151
    Jan 19, 2012
    Actually I can see why they did it this way. If you think of how difficult it is to glue up and try and get those wings aligned properly at a different thickness, it kind of makes sense. They could have even tapered the wings and routed everything before gluing it up. The V groove ensures that the wings go on square and flush. They would just have to have a jig to make sure they were aligned front to back at the proper place. I believe the reason for most of the bursted paint jobs is to hide joint conditions. The same is true with the Firebirds. Those joints would be completely obscured by the dark burst, so I'm pretty sure it wasn't a feature.
    In a production environment it would be a pretty cheap prospect to make shaper tools to do that and it would save time in glue up and clamping. Unfortunately it is an expensive prospect to someone making one guitar. ;-) That bit was about $120. I'm hoping to make a few more. I'd like to make a replica of a '64 Firebird V with the correct wood at some point. This is just a hobby for me and I make guitars for friends and people I meet here as a way to get better at the craft and charge enough to pay for some cool tools etc. I'd never be able to afford the cool tools if I did this for a living but some day I may be able to retire into it as my products and production times improve. ;-) Thanks.
    Cheers Peter.
  2. TheHarleyMan2
    TheHarleyMan2 Senior Member
    578
    168
    Aug 26, 2010
    Now that looks about right on! Good job Peter! I just placed an order the same bit!
  3. BADMAN67
    BADMAN67 Member
    77
    71
    May 29, 2017
    Using a vee-joint creates a massively bigger surface area to apply glue. So much stronger than a butt joint. Awesome build!
  4. WezV
    WezV Senior Member
    316
    346
    May 17, 2016
    The traditional V join helps ensure the alignment is spot on. Its kinda important when joining a wedge shaped wing to the through neck, all with a consistent step front and back.
    A simple butt join works fine, as do untapered wings. It’s just less authentic, not less functional. If both joins are done perfectly the v joint may be marginally stronger, but a butt join us strong enough and easier to get perfect. I doubt there is much in it
    It’s how I have done my Firebirds. and they still look and feel like Firebirds. You still have to be extra careful with alignment though if you want those steps consistent.
  5. pshupe
    3,312
    2,151
    Jan 19, 2012
    Do you mean the step between the neck through and the wings? The V groove should take care of that. I have about 3/32" step on the front and back. I'm going to do a 1/8" round over with a template bit before I put the wings on, which should make it a nice consistent round over. I've made this one a little thicker than vintage because I want it a little body heavy so I can try and minimize neck dive.
    Yeah - I do not think there is any difference to speak of between many different construction methods. I wanted to go full vintage correct and perfect the construction so I can make a few closer to vintage specs down the road.
    Cheers Peter.
  6. WezV
    WezV Senior Member
    316
    346
    May 17, 2016
    I was referring to a butt join, it’s still a bit trickier than a normal butt join as you cant just level off any discrepancy after. It has to be bang on. I think I dowelled my last one... it was a while back.
    The V’s solve all that, even if it’s a sledgehammer/walnut scenario for the small workshop
  7. cain61
    cain61 Senior Member
    840
    224
    Sep 16, 2009
    Why not just use tongue and groove?
  8. pshupe
    3,312
    2,151
    Jan 19, 2012
    Yeah - you could use anything. T&G, dowels, biscuits, or even butt joint and machine afterwards. I'm sure now or even the past 20 or 30 years they probably had a system that would be much quicker, probably CNC. It would be interesting to know when they changed from that V groove. I have no idea what they do now. Could be set neck and completely machined body. Like I said with the burst finish I doubt you could see whether there is or isn't a joint.
    Cheers Peter.
    cain61 likes this.
  9. TheHarleyMan2
    578
    168
    Aug 26, 2010
    Well I got my router bit the 55* 110. Well I compared the bit with the V groove in my 1976 Firebird. I placed the but in center of the V groove and looking at the shaft of the bit compared to a straight edge on the mid body you can see from the picture that the shaft is not straight.
    Of course I am having to hold everything in one hand and take the picture with the other. I placed the bit blade straight with the wood that has not been touched from the clean break, (meaning no wood was damaged in that area from body or wing), and you can see the spacing between the lower bit shaft and upper bit shaft compared to the straight edge.
    Peter for what you are doing building a Firebird, no one would really care, because your V groove looks good enough for me or anyone else for that matter.
    I think maybe Gibson is using a metric V bit is what I am guessing.
    My 64 Firebird that I put off on resurrecting is packed up in storage as I am moving out of my domain and I can't compare it to that body yet unless I remove half my stuff in storage.
    Hopefully within a month I will compare it, cut out a scrap piece of mahogany and cut the V groove with this bit and do a comparison with the 64's V groove.
    Cheers
    Sorry the picture evidently rotated itself!
  10. pshupe
    3,312
    2,151
    Jan 19, 2012
    Yep. Looks a little angled. It could be a 60 degree bit. Frankly it could be anything. If they sharpened the bits the angle could have varied without hindering constructibility. Tools today sells shapers for 45 degree male and female. That is probably what Gibson used, not that angle obviously but, 2 shapers that would require one pass to do each operation. It’s definitely close enough for my current build. Thanks for the update.
    Cheers Peter.
    TheHarleyMan2 likes this.
  11. pshupe
    3,312
    2,151
    Jan 19, 2012
    Better get some pics on this page.
    I finally managed to get some time on this build last night. I thicknessed the body and the head stock and cut the neck profile. I also used a mdf template for the neck taper and the radius at the neck through where it meets the wings.
    Here as some progress pics -
    cutting out on the bandsaw -
    template applied and routed on the router table -
    some mock up pictures -
    Cheers Peter.
  12. TheHarleyMan2
    578
    168
    Aug 26, 2010
    NICE WORK Peter! Really coming together!
  13. pshupe
    3,312
    2,151
    Jan 19, 2012
    Thanks. It's amazing how light the neck through is now with all that wood shaved off. I'm contemplating not tapering the wings to keep the weight up to counteract neck dive. I believe this korina is super light. I have the 2 piece korina body for the other Futura and I bet it's half the weight of the black limba one. It will make control cavity and wiring channel pretty simple as well, which seems like a good idea. ;-)
    Cheers Peter.
    cain61 and TheHarleyMan2 like this.
  14. TheHarleyMan2
    578
    168
    Aug 26, 2010
    I was at Guitar Center the other day and saw a couple of new Firebirds, (NOT the Studio Model), I was looking at a tobacco burst one and I was looking at the body and wings where they join together! It appeared Gibson did away with the V groove if I am not mistaken from what I saw on this 2018 model. It had a straight across joint on both wings and body even though I could barely see the joint line but you can tell it was straight across.
  15. valvetoneman
    valvetoneman Senior Member
    1,182
    690
    Aug 14, 2011
    That looks great Peter, really want to make one of them next year
    I love limba, I just made a dc junior, it's light too probably under 7lb now, love the thing and should've made one years ago
    I did use a non traditional mojo dual foil which is great, it mounts directly to the body no cavity route
    Bloody great tone too
  16. pshupe
    3,312
    2,151
    Jan 19, 2012
    I used the headstock template to finish up the outside shape of the headstock. I made up another template for the inner veneer, but that will wait a while until I get it together for wood selection.
    I thicknessed the wings to the correct width. I used my jointer to take it down close then the thickness sander to get to the exact dimension. It fits pretty well.
    I marked top and bottom front so I can get the wings back on the correct side because I thickness each side differently to fit perfectly in the slot. They ended up within 1/128 of the thickness designed, so that's good. Next up figure out how to taper the wings.
    I should be able to taper with a shim on one side and send through my thickness sander. I think I will glue the wings on square and then use a template bit.
    Cheers Peter.
  17. pshupe
    3,312
    2,151
    Jan 19, 2012
    Thanks valvetoneman - Yeah the white limba is so light it's unbelievable. I have some black limba I bought and it's at least double the weight. I have a two piece white limba futura body cut out and it is crazy light. It will be interesting to see how this guitar plays.
    Cheers Peter.
  18. pshupe
    3,312
    2,151
    Jan 19, 2012
    So I tapered the wings today. It went very well. I ripped some hard maple and thickness sanded two strips both sizes and marked the wings with a Yellow pencil so I knew when to stop adjusting the thickness sander. The wings fit well now so I wanted to make sure I didn't make it any thinner at the body join. That's where the pencil marks came in.
    marked and shims added -
    Thickness sanded -
    done tapering -
    I will probably route the control cavity and wiring channel prior to glue up.
    Cheers Peter.
  19. cain61
    840
    224
    Sep 16, 2009
    Nice work, Peter. Just excellent.
  20. redking
    redking Senior Member
    2,003
    1,144
    Mar 17, 2010
    Another killer build Peter!!
