Fanned Fret Firebird build
Discussion in 'Luthier's Corner' started by WezV, Nov 21, 2017.
  1. WezV
    WezV Senior Member
    353
    408
    May 17, 2016
    Not just for the alliteration, this will be my 7th fanned fret 6 string build. I really like the clarity you get when the bass strings are slightly longer. Many build fanned frets just for ERG's to give those extra low strings some definition, but the same benefit can occur on 6 strings too.
    My first fanned fret about 12 years ago was a through neck les paul with a 25-26" fan... quite subtle but sounded awesome. I have 2 with 25-27" fan's which work great. this one will sit somewhere in between at 25-26.25"
    the real revelation, fanned frets really suit the firebird design.
    the first quick sketch
    the influence for the other choices
  2. WezV
    WezV Senior Member
    353
    408
    May 17, 2016
    the pickups
    a full size sketch
  3. WezV
    WezV Senior Member
    353
    408
    May 17, 2016
    some wood and parts
    and a flamed ebony fretboard all marked out and ready for slotting
  4. KnightroExpress
    KnightroExpress Senior Member
    1,388
    1,380
    Sep 5, 2013
    Cool! Looking forward to this one!
  5. WezV
    WezV Senior Member
    353
    408
    May 17, 2016
    i still haven;t slotted the board, but i have double and triple checked all my measurements so should get it done in the next few days
    was thinking about using a 6-way blade switch on this, but it would mean making the body thicker than a normal FB
    and the gretsch style pickup rings fit quite nicely too, but they are only cosmetic so i won't make a decision on them till its nearly done
    geoffstgermaine likes this.
  6. geoffstgermaine
    geoffstgermaine Senior Member
    385
    948
    Feb 7, 2013
    Looks great! You’re right - fanned frets really seem to work with the Firebird design.
  7. archey
    archey Senior Member
    990
    834
    Nov 28, 2010
    I like where your head's at. This will be really cool!
  8. ARandall
    ARandall Senior Member
    11,732
    7,083
    Apr 16, 2012
    Maybe "Fanned Fret Firebird Frenzy"
    WezV likes this.
  9. WezV
    WezV Senior Member
    353
    408
    May 17, 2016
    The board got slotted last night
    obviously i have a super complicated jig for this
    i am not recommending this method, there are loads of better ways to do it I am sure... but it works for me. I spent a long time checking and scoring the fret measurements on the board so I use a piece of steel with a known straight edge as my saw guide.
    The important bit is to make sure its all aligned and solid, but it doesn't take much longer than slotting a normal board in a fret slotting jig
    the next stage will be to double check everything one last time before proceeding
    dickjonesify likes this.
  10. ARandall
    11,732
    7,083
    Apr 16, 2012
    You can be surprisingly low-tech with the setup as long as the slots can be reliably sawn.
    WezV likes this.
  11. judson
    judson Senior Member
    2,683
    2,581
    Jan 26, 2016
    i have ebony boards on two lps and they are great, i would love to have one on my FB
    this is off to a good start..i am sure it will kick ass
    WezV likes this.
  12. WezV
    WezV Senior Member
    353
    408
    May 17, 2016
    Yeah, I think this is my 6th multiscale and at least 4 have had boards slotted this way. I am confident in the method because I know I take the time to make it work.
    It has been a while as I have been focusing on slightly more traditional builds.
    Next step will be the weird headstock angle, which is also easier to do than it is to describe.
    I did a normal fretted FB1 with ebony board - it works well. Its the thing I get asked to make again, more than any other guitar
    Also, this guitar will not stay in the UK when done. not using rosewood makes more sense when its possible.
    judson, truckermde and pshupe like this.
  13. pshupe
    pshupe Senior Member
    3,335
    2,168
    Jan 19, 2012
    Wow - that's a nice FB. How did you join your wings? I'm currently working on a build that I want to duplicate the vintage construction, which had a groove cut in the neckthrough and then a V shaped for the wings to match up. The fanned fret build looks awesome as well.
    Cheers Peter.
  14. WezV
    WezV Senior Member
    353
    408
    May 17, 2016
    I’m not doing the V join... but I will be interested to see how you approach it. I can’t think of a way that is easy to do with the kit I have available.
    I used some dowels on the fb1 to ensure the alignment was right. Will likely do the same here unless I can think of an easy way to do the v joint
  15. WezV
    WezV Senior Member
    353
    408
    May 17, 2016
    time to start this one properly.
    I am starting to think about inlay and moving away from my initial plan of simple dots
    A firebird VII would have custom style blocks, which may be a bit of a head scratcher on a fanned fret
    they fit straight, but fall under the frets
    angling them to follow the frets really highlights the weird size differences you get with custom blocks
    the solution may be to angle them like that, then resahpe them so the sides follow the frets and fretboard edges????
    the other solution is to use some traps instead - standard traps don't look too bad simply angled.
    I also have the neck blank all planed up. I am going one peice, but adding CF reinforcement to the neck for stability. If it was getting a natural finish I would laminate instead
  16. pshupe
    3,335
    2,168
    Jan 19, 2012
    Taper the inlays to be parallel to the fret slots. It’ll look like you gave it some thought. Otherwise, even if you decide they look good, others may think you rushed it.
    Looks good.
    Cheers Peter.
  17. WezV
    WezV Senior Member
    353
    408
    May 17, 2016
    a quick play in paint shows you may be right
  18. geoffstgermaine
    385
    948
    Feb 7, 2013
    From my favourite bass builder:
    I think they look best in your mockup in paint. Dingwall further alters from standard blocks as they are tapered from the treble to bass side of the fretboard to match the fret taper at each position. It's more exaggerated on the 37" to 34" fan on the Dingwall compared with what you're doing so it may not change the look that much if you were to explore doing something similar.
  19. WezV
    WezV Senior Member
    353
    408
    May 17, 2016
    I think you are right, that will work well. The main issue for me is Gibson blocks always look to be oddly sized, but we are used to it. The even sizing on the Dingwall works well
  20. ARandall
    11,732
    7,083
    Apr 16, 2012
    Gibson essentially has blocks of the same size. Its like that with the traps too. 2 large ones 2+ 2 mediums then 3 smalls. The gaps to the frets of course get smaller and smaller.
