Faber bridge Q:
Discussion in 'The Custom Shop' started by Blue Blood, Sep 29, 2017.
  1. Blue Blood
    Blue Blood Senior Member
    418
    150
    Dec 11, 2010
    Hi,
    Have any members here tried the Faber ABRN bridge as replacement to the Nashville ?
    Considering bridge options on my older Gibson ES-335, & while it does sound pretty good now (bone nut ,locking Grover's, pickups) the B & hi E hit the back of the bridge.
    I'm considering either ABRN or going full Monty with posts & regular ABR.
    Thanks & happy friday !
  2. Dilver
    Dilver Senior Member
    525
    472
    Apr 26, 2011
  3. The_Nuge
    The_Nuge Senior Member
    1,732
    1,144
    Dec 12, 2010
    I've got the Fabers on my Firebird and Hamer Korina V - excellent bridges!
    They brighten up the sound and add "twang" in my ears, so make sure you're after that!
    Blue Blood likes this.
  4. Blue Blood
    418
    150
    Dec 11, 2010
    Are those Faber iNserts ?
  5. The_Nuge
    1,732
    1,144
    Dec 12, 2010
    Yes!
  6. 1981 LPC
    1981 LPC Senior Member
    2,078
    1,354
    Dec 8, 2010
    If only this forum had a search option.
    blackat likes this.
  7. Blue Blood
    418
    150
    Dec 11, 2010
    The search function works well.
    When I read thru (most of) the threads, they all ALSO had changed out the studs for Faber's iNserts.
    I'm asking about using the ABRN with my existing Nashville studs.
    Thanks
  8. Teebs76
    Teebs76 Member
    52
    89
    May 15, 2017
    I have outfitted every Nashville equipped guitar I ever bought with a Faber bridge. Can't say enough about the quality. I use the ABRN studs in the Nashville inserts. Easiest way with no mod to the guitar. Looks great, feels great and sounds great. This has also allowed you to lower the tail piece.
  9. Blue Blood
    418
    150
    Dec 11, 2010
    Very cool, thanks Teebs76 !
    Teebs76 likes this.
  10. 1981 LPC
    2,078
    1,354
    Dec 8, 2010
    In that case definitely get the iNserts. Nasville bushings & studs have a sloppy fit. Faber is rock solid. Good for intonation and tuning stability.
  11. MSB
    MSB Senior Member
    1,137
    632
    Jan 21, 2015
    Would you be opposed to decking the tailpiece and top wrapping?
    I've had good luck with the PLT stuff. I've had a few faber offerings and while they're nice, not really worth the money imo. If you go inserts, just cross your fingers Gibson drilled the holes parallel to each other
  12. Blue Blood
    418
    150
    Dec 11, 2010
    Some good comments, definitely back up why so many in other threads change the studs along with the bridge. Thanks !
  13. Pleximan
    Pleximan Premium Member
    377
    313
    Aug 9, 2013
    You can't go wrong with Faber. I've had a Faber ABR-1 on my 59 les paul replica since day one. It's still rock solid and keeps my action where I want; while keeping me in tune. Get one of the Nashville conversion ones.
