Explorers
Discussion in 'Other Guitars' started by Cygnus X-1, Dec 4, 2017.
  1. Cygnus X-1
    Cygnus X-1 Senior Member
    265
    223
    Feb 28, 2017
    I'm toying with getting an Explorer- shaped guitar.....anyone here who owns one have any info regarding the body shape? Is it awkward to play either sitting or standing? I'm a LP guy so that's what I'm used to.
    Thanks!
  2. mdubya
    mdubya Senior Member
    16,905
    26,334
    Jan 25, 2010
    IMO-the upper fret access and the way the neck extends out from the body is a revelation. I much prefer the neck joint on these types of guitars over an LP; SG, 335, Firebird, etc.
    That said, if the LP is all you know, you might not like the neck joint. Again, IMHO, the single cut neck joint is what gives the LP its unique tone. The Explorer should have a more focused midrange tone. I appreciate the LP tone, but I love the focused tone and playability of my SG, 335, Firebird, etc.
  3. Cygnus X-1
    265
    223
    Feb 28, 2017
    Thanks for your thoughts!
    mdubya likes this.
  4. penguinchit
    penguinchit Senior Member
    1,560
    1,719
    Jul 20, 2015
    My son tried out a couple Explorers this weekend. Said they were actually pretty comfortable to play sitting because of where it sits on the thigh and the giant wing that sticks up was a pretty good arm rest.
    I've never tried them because I just can't play an ugly guitar. Never played the SG either...
  5. BadPenguin
    BadPenguin Senior Member
    849
    578
    Jun 13, 2015
    My only complaint is that, like the SG, if you play it with your eyes closed, F, is not where it should be. :)
    endial likes this.
  6. Cygnus X-1
    265
    223
    Feb 28, 2017
    At the risk of sounding dumb- what do you mean?
  7. BadPenguin
    849
    578
    Jun 13, 2015
    It's the positioning of the neck. The headstock is slightly... ummmm... further away from the body then on a Paul. Sit with it, or an SG, and you can see the difference as compared with a Paul. Scale is the same, just in a different position.
    mdubya likes this.
  8. endial
    endial Senior Member
    2,364
    2,146
    Oct 23, 2014
    The neck seems to be (no, it actually is) located "further away" from you, as if the nut were "at D" instead of at E, so when you habitually go to E you somehow wind up a fret short and are in the F fretting area (if you're not paying attention, or, closing your eyes).
  9. Cygnus X-1
    265
    223
    Feb 28, 2017
    Interesting- thanks for the input
  10. HCRoadie
    HCRoadie Senior Member
    906
    649
    Sep 29, 2014
    I picked up an Epi Explorer last week. I have had zero issues transitioning from LesP playing. I play just as crappaly on both. I also have an Ibanez Iceman which is "sort of" explorer shaped. On that thing I am constantly off by a 1/2 step.
    mdubya and Cygnus X-1 like this.
  11. mdubya
    16,905
    26,334
    Jan 25, 2010
    Right. On an LP, the 7th fret is right under your nose. On an SG or 335, it's the 10th fret. On a reverse Firebird (and, I suspect, an Explorer) it is closer to the 12th fret.
    This influences the way you play to a certain degree. I find that to be a good thing; different guitars, different moods.
    If you like playing leads at the 12th fret, you will love the Explorer. :hippie:
    The_Nuge and Cygnus X-1 like this.
  12. Custom53
    Custom53 Senior Member
    3,561
    1,427
    Nov 15, 2009
    rclausen likes this.
