ExNihilo Vintage Burst Build
Discussion in 'Luthier's Corner' started by ExNihilo, Jan 21, 2011.
  1. emoney
    emoney Senior Member
    6,936
    3,108
    Jan 31, 2010
    The key here is "around" I think. Sure, it might be off a 1/16th, even as much as an 1/8",
    but that much won't affect your p'up plane. Do as Peter suggested and measure after the
    16th fret and draw a line. Start there and go backwards until it no longer touches the body,
    which is usually right before the bridge/tailpiece. If your router still wants to dig in all the
    way to the bottom of the body, the strap button end, then you're putting too much angle
    in this plane. Mine usually work out around 1.2-1.4 degrees..ish.
  2. ExNihilo
    ExNihilo Senior Member
    1,604
    1,749
    Nov 21, 2008
    It's accurate enough. As long as you don't start the pickup plane underneath your fret board, you are OK. 1/16th-1/8th inch give or take is fine.
    You could also use your plans (Bartlett, StewMac, Catto etc.)
  3. nuance97
    nuance97 Premium Member
    2,124
    1,140
    Feb 26, 2009
    Yes to the above. You just need a rough approximation of the end of the fretboard, and from that add a little wiggle space so you can be positive you don't start it under the board. 1/8-1/2" would be fine. It's really not that critical. And don't get so hung up on the "1.2-1.4 degree" number. As long as you start your puckup plane somewhere near the end of the fb and end it somewhere beyond the bridge pickup then the geometry will work.
  4. RobStark
    RobStark Member
    30
    13
    Dec 4, 2014
    Thanks to all for the replies. Helpful!
  5. xroadie_jim
    xroadie_jim Senior Member
    535
    558
    Aug 29, 2011
    Beautiful work. He needs to do that car next...
  6. gplayer
    gplayer Junior Member
    27
    18
    Apr 25, 2010
    Here is the carve template I will use in case anyone wants to try, it is not my work so I'm not taking any credits for it it's just a re-traced version of Scott's carve template set that includes the second version with the straight lines as he mentioned a while ago, if this breaks any rules or is inappropriate in any way I apologize in advance, take a look and let me know if it needs any changes.
  7. kevin walsh
    kevin walsh Junior Member
    2
    0
    Sep 3, 2017
    Hi Jon,
    I too am new to this forum and I'm going to have a go at building my first guitar, a Les Paul. However I cannot find how to download Scott's templates. It may be that this and related posts are too old. If you managed to download them and you still have them can I get a copy from you please. Live in South Wales and am about to retire in 6 weeks time so looking forward to this project. Best regards. Kevin
  8. ARandall
    ARandall Senior Member
    11,302
    6,468
    Apr 16, 2012
    The pdf right above your post works for me.
  9. Brewdude
    Brewdude Senior Member
    866
    1,531
    Jun 26, 2014
    That may not be visible to new members... Kevin I'd suggest you start a new thread with maybe an introduction and try to get 5 or 10 posts so you are eligible to download files and get private messages from members. Or post your email address, probably obscured a bit to avoid spam (kevin at gmail dot com for example) and I can send you the carve PDF if you can't download it from above...
  10. kevin walsh
    2
    0
    Sep 3, 2017
    Many thanks I will do as you suggest.
