ExNihilo Vintage Burst Build
Discussion in 'Luthier's Corner' started by ExNihilo, Jan 21, 2011.
  1. Mike K
    Mike K Senior Member
    127
    133
    Oct 30, 2011
    Where have all the build pics gone?
  2. ARandall
    ARandall Senior Member
    11,999
    7,460
    Apr 16, 2012
    He's probably changed his photobucket account. As soon as you do this the pictures can't be sourced.
  3. ExNihilo
    ExNihilo Senior Member
    1,628
    1,861
    Nov 21, 2008
    That's a good question. I have no idea what happened to my pictures. I haven't chnged anything...
  4. bhmcintosh
    bhmcintosh Les Pauls, Telecasters, and 12strings Premium Member
    390
    232
    Apr 20, 2009
    :eek: (*CRINGE*) I'm pretty sure we can all guess, and I'm equally sure we'd all be physically ill if our guesses were verified!
  5. dickjonesify
    dickjonesify Senior Member
    4,746
    4,619
    Apr 16, 2010
    Scott, it looks like Photobucket limits you not by how much space you're taking for your pics but by the amount of bandwidth used up by people viewing them(?). It says you need to upgrade to Plus.
    Lame Photobucket. :(
  6. buyusfear
    buyusfear V.I.P. Member
    781
    1,151
    Mar 10, 2008
    The bandwidth limit resets every month. Pics wil be viewable eventually.
    1 person likes this.
  7. Mike K
    127
    133
    Oct 30, 2011
    im about to build 4 flametops and this was my go to site. damn wanted those pics.
  8. marijnsloth
    marijnsloth Senior Member
    389
    259
    Jul 4, 2012
    The files received too much traffic, they'll be back up after the limit passes. Don't know for sure what the timeframe is, but I'm guessing a month.
  9. todd4946
    todd4946 Junior Member
    26
    3
    Jul 8, 2013
    Sorry if I missed it in the thread, but I didn't see how you cut the 4 deg. neck angle into the neck mortise (or on the heel). Did you use your box/hinge jig for the mortise? Thanks!
  10. Shandog
    Shandog Senior Member
    356
    209
    May 6, 2011
    Use the mortise template set on the 4 degree angle that's already on the body. If I remember correctly he used 2 tiny finishing nails on each side to hold it in place. The holes get covered by the fret board later You'll also have to use clamps and some scraps underneath to stabilize the template against the body.
    BTW... What happened to the Bartlett LP build sticky thread?
  11. todd4946
    26
    3
    Jul 8, 2013
    Thanks for the reply. I thought he routed the neck plane after the mortise and contours. Maybe I missed that bit, but that would work (route neck plane on body, then mortise, then contours). Thanks again
  12. todd4946
    26
    3
    Jul 8, 2013
    Woops, i stand corrected. :doh: you are of course correct - i went back and checked and the neck plane was routed first.
  13. Shandog
    356
    209
    May 6, 2011
    Neck plane/ pickup plane/ neck mortise/ pickup routes.
    Remember that the pickup routes are still follow the neck plane....but lay where you routed the body know as the "pickup plane".
  14. todd4946
    26
    3
    Jul 8, 2013
    Thanks again Shandog. Do you (or does anyone) know why the control cavity is routed at an angle? (Pg. 9) Is this required to seat the pots perpendicular to the carve and/or to make the pot holes perfect circles? I'd never noticed this detail before.
  15. Stephmon
    Stephmon Senior Member
    616
    777
    Dec 9, 2010
    The control cavity angle levels the clearance between the pots and the carve. It doesn't impact the shaft holes, as they are perpendicular to the pre-carve plane, rather than the carve.
  16. todd4946
    26
    3
    Jul 8, 2013
    Ah, I get it now, Thanks!
  17. gplayer
    gplayer Junior Member
    27
    18
    Apr 25, 2010
    I don't know if this is the way the carve template is supossed to look now or if someone else has posted the updated version already, anyways this is the one I'll be using if I can't find an updated version.
  18. ExNihilo
    1,628
    1,861
    Nov 21, 2008
    Yes, that is correct.
  19. RobStark
    RobStark Member
    30
    13
    Dec 4, 2014
    Can someone please help me understand? I keep hearing that you start your pickup plane where the fretboard ends but how do you know where the fretboard will end exactly as this stage in the build? I mean, sure I know that the fretboard meets the body around the 16th fret, but just placing the fretboard on the guitar at the 16th fret can't be all that accurate of a measurement right? How is is that one determines where EXACTLY the fretboard will end on the body? Do you have to have the neck and fingerboard finished at this stage in order to determine where to start your pickup plane????
    Thanks
  20. pshupe
    pshupe Senior Member
    3,388
    2,203
    Jan 19, 2012
    You should know the length of your fret board and you know the dimension from the nut to the 16th fret. Therefore you know the dimension from the edge of the body to where your fret board ends. Just mark a pencil line where that is and use the quote you included.
    Cheers Peter.
