es rim glue
Discussion in 'Luthier's Corner' started by Flyin Z, Sep 16, 2017.
  1. Flyin Z
    Flyin Z Member
    41
    1
    Jul 22, 2017
    I was going to use titebond original to laminate the 3- ply maple rims of about .050" thick each. I thought about using hide glue but afraid it will harden up before I get everything clamped. Perhaps fish glue will work. This is my first attempt. Any advice?
  2. Freddy G
    Freddy G V.I.P. Member
    11,340
    23,650
    Mar 18, 2007
    titebond.....without question
  3. Open_Book
    Open_Book Senior Member
    1,180
    683
    May 26, 2014
    Cascamite is a very cheap UF glue and is used by some for such lamination applications as the open time is much longer. It dries rock hard like Hide glue, too. Its something else worth considering.
  4. moreles
    moreles Senior Member
    2,874
    1,517
    Apr 16, 2011
    With experience, any of those glues would work, but the safest and most reliable for those of us who do not build all the time and who do not have a personal preference would be Titebond, as Freddy says. I can't think of any downside to using it in this case, and it should work really well. Enjoy your build!
  5. Open_Book
    1,180
    683
    May 26, 2014
    Nothing unsafe or unreliable about cascamite and its a boon for someone without experience because of its longer open time.
  6. Freddy G
    11,340
    23,650
    Mar 18, 2007
    I have to agree. I only mentioned titebond only because it's the easiest to use and procure.
  7. Open_Book
    1,180
    683
    May 26, 2014
    I'm not against Titebond Freddy. Its just the OP mentioned using Hide Glue (you know that old story for the tonez...) and its open time. Cascamite is like the Fishglue (only better) of Hide glue with its open time when it comes to newbies and clamping.
  8. Flyin Z
    Flyin Z Member
    41
    1
    Jul 22, 2017
    What is this polyeurethan glue that I hear about? is it like two part epoxy?
  9. The Ballzz
    The Ballzz Senior Member
    1,481
    987
    Mar 28, 2013
  10. Joth
    Joth Senior Member
    165
    50
    Dec 22, 2012
    How are you shaping the rims and clamping them to their final form? Will their shape after laminating be slightly reworked and rebent when put into the form when glued to the centre block?
    Last year I did a complete rebuild on a 62 ES345 that completely fell apart http://www.mylespaul.com/threads/es345-overambitious-restoration.368366/ and I spent some time looking at the original glues to see what failed and what survived:
    a) the top and back plates were in perfect laminated condition and showed no deterioration of the glues anywhere, I am assuming this was the more moistureproof PF glue
    b) the side rim lamination glue totally failed and that's the first sign that the guitar was in trouble, the sides just peeled away from itself
    c) the side to top kerfing and centre core/spruce layer glues all seemed the same as the sides and all had dried out and powdered, these seemed to be the UF glue
    d) the fretboard to neck joint, and the neck heel to body core joint were in perfect condition, and these were hide glue. The holly to headstock face was also perfect, and I believe I had reglued the headstock ears early on, so that was probably UF.
    My recommendation would be to use the titebond1, because although the UF has a great long open time, I find it a bit brittle for the bending of it into its final form, the UF could crack up a bit within the laminations when doing this.
    In the rebuild of the 62, I used hide glue on the kerfing to side rim joints, and hide glue again gluing the spruce into the top and back plates (basically I tried to use hide glue as much as possible) then used UF to glue the top and back onto the body and rims, because you really need the long open time for that process, do not try to use titebond or hide glue for that, it will skin over too early.
    For the side rim cutaway joints to join the body core, you MUST (or really should) use the UF there, as you really would not want that joint to loosen if you ever applied heat and moisture to the nearby neck heel joint if you wanted to remove the neck later on.
  11. Flyin Z
    Flyin Z Member
    41
    1
    Jul 22, 2017
    I am pre- bending the plies and then clamping them into a form lined with cork. I think i am going with the unibond 800. Going to do one set with maple and one set with walnut.
  12. Skyjerk
    5,980
    7,138
    Feb 9, 2014
    I never clamp newbies. They holler too much
  13. Open_Book
    1,180
    683
    May 26, 2014
    Not in my dungeon... /cue Pulp Fiction theme
  14. Bill Hicklin
    Bill Hicklin Senior Member
    7,716
    10,743
    Nov 3, 2014
    That's what the ball gag is for.
    Skyjerk likes this.
  15. the great waldo
    the great waldo Senior Member
    206
    60
    Jan 6, 2010
    Titebond extend would be good in this situation although cascamite is good because of it's long set up time + it's waterproof and rock hard. I have heard that there can be storage problems with cascamite powder where it has a limited shelf life, maybe someone who's has had any problems with it would like to chirp in.
    Cheers
    Andrew
  16. Open_Book
    1,180
    683
    May 26, 2014
    When it comes to shelf-life Cascamite is no different to any other glue as long as you follow the manufacturers storage instructions. Its not rocket science. The internet has a bunch of people whining about Titebond going off.
