Ernie Ball cobalt strings first impressions
Discussion in 'Tonefreaks' started by islandjimmy, Nov 5, 2017.
  1. scozz
    scozz Senior Member
    2,150
    931
    Sep 3, 2007
    I've never tried Erine Ball Colbalt strings, but I've been a EB string user, (9-46 hybrid) for 25 or 30 years!!
  2. moreles
    moreles Senior Member
    2,351
    940
    Apr 16, 2011
    I never noticed the fretwear concern mentioned here, but if true, that's an issue. I like Cobalts -- a lot. I find them articulate and consistent, and they hold tunings well. I like the feel very much, as they are not stiff, and play fluidly and comfortably. I love the tone, but I do not use high-output pickups, do not jack up my pickup, and I keep my guitar volume around 5-6 (cranking only now and then, for leads, etc.) so I do not get the breakup some describe (unless I turn it all up, of course). I like the strong fundamental with nice overtones you get from the Cobalts -- for me, it's a better tone than the more zingy, thin tone of regular strings. I use NYXL or Cobalts on all my electrics.
  3. fretout
    fretout Senior Member
    294
    169
    Jul 30, 2008
    I've been using EB Cobalts on all my guitars for years now. They seem a little stiffer and less slinky than the standard slinkys, but they feel more slinky as they're broken in.
    They are quite a bit louder both acoustically and through an amp, and the tone seems pretty balanced, with maybe more bass response than the normal slinkys.
    I haven't noticed any increased fretwear compared to the normal slinkys, but I guess it depends on your paying style. I muscle the strings around pretty hard, it my frets are still there, and don't show any different patterns than any of the other EBs.
    I will say that I absolutely hated the MB M-Steels, and they sounded dull and lifeless. I'm trying out a set of the new EB Paradigm strings, and they are nearly indestructible, and seems to stretch into tune much faster than any other EB strings.
    BTW, I played 10-52s, and switched to Power Slinkys, and I like them more, so, they're on everything.
  4. Dolebludger
    Dolebludger Premium Member
    11,949
    9,755
    Feb 11, 2009
    I have used EB Cobalts for a few years, and like the tone and feel. I personally have not noticed the fret wear issue, though I check for it regularly. But I don't dispute that some players have had this problem. I play with very low action and a light touch with 9-42s, and some players have a heavier touch. Also, there are many fret wire alloys, sizes, and shapes. If you like the sound and feel of EB Cobalts, try them and just watch for excessive fret wear. If you start seeing it, I recommend changing to DR Pure Blues.
  5. Dilver
    Dilver Senior Member
    525
    473
    Apr 26, 2011
    Too much friction and felt like they were going to chew up my frets. Did not like them at all and took em rght off
  6. Dolebludger
    11,949
    9,755
    Feb 11, 2009
    Dilver,
    I fully understand your problem with these strings, as they clearly are not for everyone. I have never used them except in 9-42 gauge, with very low action, and with the fret board (therefore the frets) nicely oiled. For those for whom EB Cobalts don't work, I recommend DR Pure Blues. Totally the opposite sort of strings, with pure nicle wraps and round cores on the wrapped strings, but with basically the same rich tone, if you crank down the bass and mids down a bit, and maybe crank the treble up a notch.
  7. tonemonster58
    tonemonster58 Senior Member
    320
    514
    Feb 15, 2012
    Skinny top Heavy bottom since they were introduced on all my electrics. They are really a cut above. A+++++
  8. elephantrider
    elephantrider Senior Member
    2,307
    1,733
    Oct 23, 2015
    eb 2215 10-52 on all of my electrics since i can remember.
  9. moreles
    2,351
    940
    Apr 16, 2011
    Even though the OP asked about Cobalts, half the posts just state what that individual uses. Huh? But to actually talk about Cobalts, which I gave used extensively, my impressions are the same as in the OP, though I think the OP goes way overboard as to matter of degree. "Whole diffrent guitar?" Uh -- not that much. But I did find some more clarity and responsiveness, and I, too, liked the feel a lot (though other posters have expressed real dislike for the feel of Cobalts). But for me, too, fret wear was the decider. I'm just not going to use something that appears to degrade fret life, when other good alternatives like NYXLs exist.
