Epiphone Les Paul FAQ
Discussion in 'Epiphone Les Pauls' started by Sinmastah, Jan 25, 2009.
  1. Jeffo46
    Jeffo46 Junior Member
    5
    2
    May 5, 2013
    Hi, I'm the newbie here from Rhode Island. I've been playing for 40 years and just recently made the switch from Strats to Les Pauls. I have a Epiphone Goth Les Paul Studio which I love ,with the exception of the stock bridge which was giving me tuning nightmares. I took that off and replaced it with a brand ,new ,Graph-Tech NV-2 bridge which you can get from Musician's Friend for $75.00. After installing that, my guitar now stays in perfect tune and also has more tone and sustain as well.
  2. DuffB
    DuffB Senior Member
    145
    36
    Mar 3, 2010
    The Gibson pickups are really nice, in general, in my opinion; but there is no reason why you can't get just as great results using Seymour Duncan's. I have both.
    One thing that I really, really like are the Seymour Duncan Alnico II Pro's. If this isn't history already, you could get a neck and bridge Alnico II Pro and put them in the neck and "middle" positions; then get a "bridge" Slash Alnico II Pro for the bridge. This would probably be an awesome set.
    Otherwise just put the Alnico II Pro neck version in the neck and middle positions and the Alnico II Pro bridge one in the bridge. Either way this would be a very cool sounding guitar.
    One more thing you could do is put a switch in to get a couple more pickup combinations, as in all three, bridge and neck, neck and middle, bridge and middle, etc. The stock switching is evidently a three way switch and you can only select one pickup at a time - doesn't make sense really, in my opinion.
    I think this is a really cool guitar though and I would want to do some mods to address the pickups and switching, and possibly the wiring components where necessary.
    It would be interesting to know what you decided on the pickups.
  3. paruwi
    20,048
    26,803
    Dec 24, 2009
    and what has it to do with this 'FAQ' thread ?
    2 people like this.
  4. walterh
    walterh Junior Member
    2
    0
    May 14, 2013
    This is a great thread. Thanks for all the info!
  5. paruwi
    20,048
    26,803
    Dec 24, 2009
    Epi never used photoflame
    4 people like this.
  6. RaSTuS26
    RaSTuS26 Senior Member
    3,064
    2,284
    Apr 16, 2011
    Easiest way to check for relief is to put a capo on the 1st fret, then fret on the fret one past the neck/body join (17th on an LP), there should be a gap of between 0.40mm and 0.50mm (0.016" and 0.020"), about the thickness of a business card, between the bottom of the string and the top of the fret at the half way point between these two fretted points (7th on an LP), check the low E, you can also check the high E to confirm, both E's should be the same.
    Some use feeler gauges or a ruler to check, but you should be able to get it close by eye. If there's no gap, the neck is either dead straight or has a back bow.
    To get more relief you loosen the truss-rod, which is counter clockwise as you look at it from the headstock end. Only do a 1/4 turn max each time you adjust and wait several hours for the neck to settle between adjustments.
    3 people like this.
  7. iakbil
    iakbil Junior Member
    27
    7
    May 23, 2014
    This is great information Sinmastah. Thank you so much for starting this thread. I am new here and keep on reading and re-reading all these wonderful discussions. People like you make the MLP a unique, fun, kind and learning place. By the way, I recently bought an Epi from a Forum Member and it was great and very pleasant experience :) Thank you again and take care
  8. DW4LesPaul
    DW4LesPaul Senior Member
    1,154
    234
    Feb 4, 2014
    If you go to the website under Specifications, it says "Body: mahogany, flame maple Top"
    The one I have is listed as Out of Production:
    It's a "Quilt top Pro."
    Top AAA quilt maple veneer
    So I see what you're saying.
    http://www.epiphone.com/Products/Les-Paul/Les-Paul-Standard-Quilt-Top-PRO.aspx
    From the comments section below on that page:
    "PLUS TOP" means that the pretty veneer is on a SOLID maple cap, not a laminate maple cap. This is a very good thing. It's not solid quilt/flame all the way through the top, like on a Gibson, but that quilt/flame sheet is on a solid Maple dished cap on the solid body.
  9. paruwi
    20,048
    26,803
    Dec 24, 2009
    and this 'flamed maple top' actually is a thin (real wood) veneer...
    and had been answered around a year ago....
  10. paruwi
    20,048
    26,803
    Dec 24, 2009
    The coments just are BS
    neither a solid maple top, nor a laminated maple top
    it is on a multiple piece asian mahogany bodied guitar !
  11. paruwi
    20,048
    26,803
    Dec 24, 2009
    This thread is for information - not for discussion
    Thanks
    1 person likes this.
  12. GraphX12
    GraphX12 Member
    58
    37
    Nov 25, 2014
    Sinmastah:
    Thank you so much for posting this. I'm a novice and intend to do some mods to my Epi Les Paul Standard and this really opened my eyes to what needs to be done and gives me a starting place on where to begin. Appreciate it!
  13. paruwi
    20,048
    26,803
    Dec 24, 2009
    No,
    and please read post #373 !
    thanks
  14. Poetmonk
    Poetmonk Member
    47
    46
    Feb 24, 2016
    I don't know if this was brought up, I didn't read all 13 pages, but the Epiphone Elite/Elitist Les Paul Plus is NOT a veneer. It's a solid book matched figured Maple cap. You might want to edit your OP.
  15. Capricorn1
    Capricorn1 Junior Member
    4
    1
    Apr 26, 2016
    My 2015 plus top pro plays and sounds great, However... I'm certain its chambered or weight relieved as it is ALOT lighter than my 80 lp deluxe. Is this true ? And does anyone else's new Epi seem kinda "neck heavy". Thx GB
  16. paruwi
    20,048
    26,803
    Dec 24, 2009
    Hi,
    welcome here @ MLP
    :wave:
    Epi LPs are not chambered / swiss cheesed / weight relieved
    except the Ultra series.....
  17. Capricorn1
    4
    1
    Apr 26, 2016
    My 2015 Plustop pro seems a bit "neck heavy"
    Anyone else finding this.
    Otherwise love it....its just way lighter than my 80 les paul deluxe...
  18. Capricorn1
    4
    1
    Apr 26, 2016
    Thanks for the info... I guess just lighter mahogany
  19. _sQuid
    _sQuid Junior Member
    9
    1
    Jun 2, 2016
    What are the standard capacitors used in Epi LPs?
    My 60s Trbibute Outfit doesn't have the Mallory capacitors (and the 2013 catalogue doesn't list the Mallories in the specs either) but I see some Outfits with the Mallories as listed in the Epiphone website. Is Epiphone inconsistent when it comes to electronics?
  20. Guitar Rod
    Guitar Rod Senior Member
    1,471
    775
    May 29, 2016
    CTS now makes short shaft metric pots. No boring. No need for new knobs.
