Epiphone Dot 2010 Neck Profile
Discussion in 'Other Epiphones' started by Laurent73, Feb 22, 2017.
  1. Laurent73
    Laurent73 Junior Member
    11
    0
    Nov 22, 2016
    Hi, Is someone able to tell me if the Epiphone Dot 2010 (serial 10041502250 ) have a slim or a "fat" neck ? I read somewhere there are some with a fat neck ... Thanks !
  2. tzd
    tzd Senior Member
    5,535
    3,335
    Oct 21, 2011
    All Epiphone Dots that I have tried - Korean, Chinese, Indonesian - have necks that I would describe as fat/rounded. (I typically prefer to play guitars with slim necks).
  3. paruwi
    19,621
    25,918
    Dec 24, 2009
    90% of the available Epis have a '60s slim taper' type neckshape
    though it still can vary due to different sanding skills of the different employees in the different factories
    You can't tell the neckshape by the serial#
  4. LPMarshall Hack
    LPMarshall Hack Senior Member
    3,228
    3,719
    Dec 19, 2009
    So we got one for fat and one for slim. Next?
  5. Laurent73
    11
    0
    Nov 22, 2016
    Hi,
    Thank you for the usefull answers.
    I thought that the serial number can attest of the year of production (in this case 2010).
    And indeed the year can in some cases tell what is the neck profile, for instance the present production have this "fu..ing" slim taper neck ...
    Me i am looking for a neck that is a bit fat ...
  6. paruwi
    19,621
    25,918
    Dec 24, 2009
    What about a more helpful answer ?
    At least a try ?
  7. Laurent73
    11
    0
    Nov 22, 2016
    What about a more realistic answer ?
    Depending on were you live, you sometimes have to order thing online, and you cannnot try it. It is sad, but it is what it is...
  8. elephantrider
    elephantrider Senior Member
    2,430
    1,947
    Oct 23, 2015
    i've played 2 older dot's, and they both had a slim taper 60's
    neck type.
  9. 1all's Pub
    1all's Pub Senior Member
    3,140
    2,915
    May 26, 2015
    I haven't felt an Epi Dot or Epi 335 Pro whose neck I would describe at "fat" or "rounded". All have been of the 60s slim variety, with the typical Epi "D" shape to them.
  10. Victek
    Victek Senior Member
    1,289
    463
    Mar 4, 2013
    I used to own a Dot which I bought new about three or four years ago. I now have an Epi ES 335 Pro and I'd say the necks are about the same. The necks are on the fatter side compared with an Epi Sheraton and also my PRS SE CU24 which has a "thin wide" neck. On the other hand they are not as chunky as some Les Pauls I've played. Hope that helps a little. :)
  11. ptfreak
    ptfreak Junior Member
    18
    0
    Nov 1, 2009
    I have a 2010 Dot 335, and I would say fat as compared to my slimtaper Gibson LP from 2011.
    But not extremely fat though.
    J
  12. Laurent73
    11
    0
    Nov 22, 2016
    Ok, thank you, it sure helps ! ;-)
  13. oilslick
    oilslick Member
    50
    12
    Dec 31, 2012
    I had a 2009 left handed Dot that had the same feeling neck as my 04 Les Paul Standard which is a slim 60's.
