Epi VJ problem, help wanted
Discussion in 'The Squawk Box' started by Thumpalumpacus, Sep 24, 2017.
Tags:
  1. Thumpalumpacus
    Thumpalumpacus Senior Member
    71,926
    170,620
    Nov 28, 2010
    So I'm jamming on my VJ, volume is wide open, when out of nowhere the volume drops more than halfway. Cycle the power, no dice. Try it with another guitar and cable, no change. Change out both tunes, still less than half-power.
    Anyone here experience this? Any help is greatly appreciated.
  2. jimmyjames
    jimmyjames Senior Member
    2,024
    1,959
    Apr 22, 2013
    My VHT Special 6 did a similar trick once. I reflowed the solder joints to the tube sockets (tried cleaning pins and pin sockets first) and that sorted it. They're made down to a budget, maybe get a techie to go over everything quickly, or drain your caps and have a shot :thumb:
  3. northernguitarguy
    northernguitarguy SWeAT hOg
    26,100
    41,269
    Feb 22, 2009
    Sorry, Thump. That is a fun amp! I hope you find a solution.
    Thumpalumpacus likes this.
  4. Soul Tramp
    Soul Tramp Speaker Snob V.I.P. Member MLP Vendor
    5,970
    12,964
    Jul 19, 2012
    Thump, pull and re-seat all the tubes.
  5. northernguitarguy
    26,100
    41,269
    Feb 22, 2009
    I think he did? Tunes(sp)=tubes?
  6. Soul Tramp
    5,970
    12,964
    Jul 19, 2012
    Ops. Don't tweet when you're drunk and don't post too early in the morning. :yesway::)
  7. rabidhamster
    rabidhamster Senior Member
    5,568
    5,080
    Jun 4, 2008
    Is it a similar tone at half power, I.e. Distorted like full power
    Or just like the amp turned up half way at full blast
    My initial guess is a bypass cap shit the bed or lost ground, but I'll wait for your response
  8. Marshall & Moonshine
    Marshall & Moonshine Senior Member
    19,470
    31,316
    Jul 21, 2010
    Could it be a bad triode in the preamp Tube?
  9. Leña_Costoso
    Leña_Costoso Senior Member
    580
    497
    Aug 28, 2017
    Output transformer
  10. Marshall & Moonshine
    19,470
    31,316
    Jul 21, 2010
    Isn’t a VJ single-ended? I’d think that means a single primary winding and a single secondary winding.
    If either opens, that’s it—kaput.
    If it’s a turn-to-turn short, I’d think it would have to change the impedance just so to cause the OP’s problem, and if OT’s are like regular transformers elsewhere in the electrical world, those shorts don’t last long.
    I can always be wrong, but it sounds more like a resistor or cap, tube socket or tube.
    Thumpalumpacus, mdubya and DarrellV like this.
  11. Leña_Costoso
    580
    497
    Aug 28, 2017
    Yes it is single-ended so you are correct. Whoever I've had three or four Champs brought to me over the years including one I built that had very low output and the fault was always the output Transformer which is why I mentioned it.
  12. Leña_Costoso
    580
    497
    Aug 28, 2017
    More on that..... I can't remember checking because it's been a while but my memory tells me what we found was shorted secondaries that was shorted unto themselves. So instead of a full winding you got maybe an eighth of a winding and that gave great Havoc to the impedance and output
  13. Marshall & Moonshine
    19,470
    31,316
    Jul 21, 2010
    That’s the “turn-to-turn short” I mentioned earlier.
    I didn’t think it was a common thing. I’m an electrician aboard container ships and usually transformers of any kind tend to fail a bit more dramatically. They’re never “failING”....
    They FAIL.
    But I know it is “a thing”, just never seen it.
    Interesting.
  14. mdubya
    mdubya Senior Member
    15,501
    23,219
    Jan 25, 2010
    My Champ used to do that. Turned out to be a cracked tube socket.
    I've burnt a resistor before, too. But that took out a tube and the amp was dead until the resistor was replaced.
  15. Leña_Costoso
    580
    497
    Aug 28, 2017
    Back at a keyboard... and I'll add a bit more re the OT. When the one's I had "went", not only loss of volume but heavy distortion at any volume, even the slightest.
  16. THDNUT
    THDNUT Senior Member
    14,653
    20,054
    Feb 5, 2012
    Throw the amp away and get a new one. Those VJs are disposable aren't they?
    :D
    My VJ most certainly has an OT (and a choke too) because I installed the MM mod kit.
  17. irocdave12
    irocdave12 Senior Member
    1,832
    1,776
    Jun 22, 2011
    Most likely a bad solder joint particularly at the tube sockets. But other jr owners have had a problem with corrosion in the fuse holder or poor intermittent contact there so give that a check too
    Thumpalumpacus and mdubya like this.
  18. Thumpalumpacus
    71,926
    170,620
    Nov 28, 2010
    Thanks so much for all the input. While replacing the tubes I made sure to spray some electronics cleaner in the sockets and work the tubes. I didn't notice the sockets being cracked.
    I'm on my way to pick up a Tweaker 15 as a replacement. The VJ cost me $100 used, so I'll use it to learn a few things.
    I sure appreciate everyone's input (har-har), and will post back occasionally as I open this thing up and have questions or whatnot.
    Thanks again, y'all.
  19. rabidhamster
    5,568
    5,080
    Jun 4, 2008
    If you don't get to it before then, bring it to GuitArlington, thats a fine afternoon gathering project
    mdubya and Thumpalumpacus like this.
  20. Thumpalumpacus
    71,926
    170,620
    Nov 28, 2010
    Much as I'd love to go, I won't be able to; I'm taking 6 days off in early October and have to work those two days. But once I get some time I will take this thing apart and fix it myself if I can. I reckon I've got a year's use out of it, and will use it from here on out to start learning amp-tweaking.
    Not bad for $100, eh?
