Entire threads saves in PDF
Discussion in 'Luthier's Corner' started by voices, Feb 26, 2012.
  1. JRo
    JRo Senior Member
    341
    109
    Oct 27, 2011
    I open your PDF and then Print it (to a file) using CutePdf Writer. Its basically just resaving the file but the compression seems to be better and the file size drops.
  2. b3john
    b3john Senior Member
    5,203
    3,792
    Jun 5, 2010
  3. voices
    voices Senior Member
    1,828
    642
    Dec 3, 2008
    i put a bunch more threads up.
    2 people like this.
  4. TKOjams
    TKOjams Senior Member
    10,059
    6,800
    Sep 12, 2009
    Great idea, thanks for including my work in the mix.:)
  5. jbrybar
    jbrybar Senior Member
    310
    166
    May 4, 2011
    I just found this thread. First I want to thank you for taking the time to do these. When I try to download the file I get a new tab pop up then it says "Problem loading page. Connection reset." What am I doing wrong? Thanks in advance.. :)
  6. voices
    1,828
    642
    Dec 3, 2008
    i'm not sure what the deal is with that website. i had a problem trying to download the files as well. it worked perfectly when i originally uploaded those pdfs.
    Anyone have any suggestions on where i can upload these files for easy access to all?
    i have 24 build threads in Zip files. the largest one is 1.01 gig.
    thanks
  7. denizdurdag
    denizdurdag Member
    57
    43
    Mar 10, 2010
    If you have a google account you can upload them on your google 'Drive'. Then you can make them public and share the links here.
    If you don't have a google account, I highly recommend to have one. Very useful for lots of things.
    And thanks for sharing :thumb:
  8. b3john
    5,203
    3,792
    Jun 5, 2010
    Dropbox.
    /thread
  9. kasu
    kasu Senior Member
    1,484
    1,783
    Mar 16, 2010
    Awesome, Thanks!!
  10. voices
    1,828
    642
    Dec 3, 2008
  11. Ole'Lefty
    Ole'Lefty Premium Member
    5,209
    1,724
    Oct 25, 2008
    So kind of you. If I click on the google access will I end up with any use issues? I don't want google taking over any more of my computer.
    A huge thank you and suggestion-at least one of Scott's (ex nihilo) builds. The timing od his builds, the Magnus connection along with Bartlett make both of them classics-his second one shows the growth in skill from the first and that is a lesson we all can use.
    Don't forget he had a heavenly coach too.
    1 person likes this.
  12. voices
    1,828
    642
    Dec 3, 2008
    2 people like this.
  13. jbrybar
    310
    166
    May 4, 2011
    Thanks again for sharing.. The drop box worked fine. I was able to download the zip file with no problems. It would be awesome if you could put the others up the same way.. :)
  14. jbrybar
    310
    166
    May 4, 2011
  15. voices
    1,828
    642
    Dec 3, 2008
    I really wanted to post a couple others, in particular that Les Paul build from the tele forum by Preeb(Gil Yaron) as well as a 335 build but the files ended up much to large for these free hosting sites. Maybe i can figure out somewhere else to put them.
    in the mean time, if you havent seen this build thread, you MUST join this forum and read the whole thread. It should be required reading for anyone wanting to learn how to build a Les Paul:
    1959 Les Paul Build - Telecaster Guitar Forum
    this one too:
    1959 ES-335TD proto build - Telecaster Guitar Forum
  16. mertzy
    mertzy Senior Member
    1,291
    764
    Mar 23, 2010
    Fletch's "68 ES-330 gets a Hummingbird Headstock" thread, here.
    This is a really cool repair thread with a lot of detail.
  17. harry vrt
    harry vrt Junior Member
    6
    5
    Oct 17, 2012
    Umm, you sent the link that leads to your folder on your acc on dropbox so if we aren't logged to your acc we can't see it, so maybe other host or direct links to every pdf on dropbox. Or I'm the only one who is being redirected to his own account ?
  18. Kmw
    Kmw Member
    91
    24
    Mar 29, 2013
    Same here, or login screen if I sign out of my account and then follow link.
  19. reborn old
    reborn old Senior Member
    2,561
    1,619
    Jul 24, 2010
    Your drop box link is not working for me either.
    Convenience of PDF's for these builds would be great !
    Thanks for PDF links ... if/when technical difficulties are worked out.
