Echo vs. Delay
Discussion in 'Pedals' started by Bluesyzep, Sep 4, 2010.
  1. Bluesyzep
    Bluesyzep Senior Member
    759
    76
    Dec 17, 2007
    Silly question maybe but what's the difference between an Echo and Delay pedal?
    Agave_Blue likes this.
  2. 4nd3h
    4nd3h Senior Member
    1,603
    130
    Dec 5, 2009
    The name 8)
  3. mart1964
    mart1964 Member
    30
    4
    Jan 22, 2010
    Generally - an "echo unit" will be analogue or designed to simulate a tape or bucket brigade style of echo (might also be called an "analog delay" pedal) In effect echo is usually 1 or maybe around 3 repeats which degrade in quality with each repeat. The echo's are often softer in tone than the dry signal and blend well into the background.
    I use the Memory Toy analog delay pedal. In fact except for very rhythmical stuff I tend to leave it on all the time as it acts like reverb but with more space and musicality.
    A delay is very similar in essence. Original signal is repeated. A delay will often mean a cleaner more defined repeat (ususally digital but not exclusively).
    That may well just be my interpretation - most likeley that echo is a more artsy name for a delay and that is all.
  4. Phoenix59
    Phoenix59 Senior Member
    2,291
    1,328
    Apr 19, 2010
    What'd you say?
    What'd you say?
    What'd you say?
    :D
  5. teemunknee
    teemunknee Senior Member
    1,937
    33
    Jan 2, 2010
    :laugh2::laugh2::laugh2:
  6. ehamady6
    ehamady6 Senior Member
    3,787
    551
    Sep 4, 2008
    They're the same, but if you're into extreme minutia then delay can mean a repeated, pristine reproduction of the original content whereas echo, such as in a cave, can bounce around and gradually diffuses.
  7. thijshegemann
    thijshegemann Senior Member
    314
    0
    Oct 7, 2009
    It's the same.
  8. Bluesyzep
    759
    76
    Dec 17, 2007
    Should probably have added reverb to the title as well. I keep the reverb at 10 on the Marshall and use an analog delay when needed. The consensus seems to be, not much difference. Thanks for the replies.:)
  9. Hamtone
    Hamtone Senior Member
    11,589
    4,397
    Aug 7, 2009
    Hold on, you have the reverb set on ten all the time?
  10. Bluesyzep
    759
    76
    Dec 17, 2007
    Yes. Mainly because my instructor cranked it up one day so I left it that way. Haven't heard a reason to change it. I keep the effect level between 3 and 4. Why not?:hmm:
  11. DoctorSkullington
    DoctorSkullington Senior Member
    783
    2
    Jun 11, 2010
    I prefer Echo, or as Mart said, analog delay.
    Isn't ping pong delay the same as slapback? Or is just a long delay time and very few repeats?
  12. Agave_Blue
    Agave_Blue Senior Member
    3,029
    104
    Nov 19, 2009
    Glad you asked. I've wondered the same thing.
  13. st.bede
    st.bede V.I.P. Member
    10,261
    5,318
    Jan 8, 2008
    to my limited knowledge, echo is just a very short delay time and the repeats should not feel like repeats but just like a sense of space (more or less)..
    the repeats can be clear of modulated or even have a high pass filter roll of the top end with each repeats...it really depend on what you are after....
    if I knew where my books were I could give you a precise time...it has to do with how the human ear hears the effect..
    for a long time I used echo instead of reverb, but lately I have been getting back into reverb...in a sense the two (echo and reverb) accomplish the same thing for guitars, which is to give a sense of space...
  14. Ricochet
    Ricochet Senior Member
    252
    25
    Jul 25, 2010
    The difference between an Echo-o-o and a delay-delay-delay is a delay-ay-ay can do echo-o-o-t-o-o.
  15. Hamtone
    11,589
    4,397
    Aug 7, 2009
    Depending on what you are playing, playing to wet will make your sound mushy.I play on a blackface fender which is known as one of the reverbs out there. I have it on 2 its just a little ambiance. I use 2 delays one gives a short slapback with about 2 repeats with the level down quite a bit. My other delay is set with a much longer delay which gives a much slower decay, think Dave gilmour.
    The difference between reverb and echo is this, echo repeats your signal like yelling into a cave, reverb on its own adds very short timed repeats which is kind of like changing the hardness of the cave walls. Softer has less ambiance harder adds more.
    Small doses is great and adds to your overall tone, to much males it mushy and undistinguished.
  16. Deftone
    Deftone Senior Member
    12,304
    9,565
    Feb 22, 2008
    I like a little bit of Echo for some stuff and long delay for different things.
  17. snaredrum
    snaredrum V.I.P. Member
    23,055
    13,764
    Feb 14, 2009
    but then analog echo is more like
    What'd you say?
    Wh*t'd Y** Sa*?
    W***'* **o s**?
    :thumb:
