Dumb questions...I want to add a 3 position mini toggle to a humbucker...
Discussion in 'Tonefreaks' started by old mark, Jun 27, 2017.
  1. old mark
    old mark Senior Member
    3,815
    3,474
    Aug 21, 2009
    I have a 1986 Carvin solid body guitar that has 2 of their humbuckers in it...I want to remove the neck pup, and add a 3 position mini toggle switch for the bridge humbucker...both coils on normal, both coils on out of phase, single coil only. I'm not sure if this is doable with the original pup...
    Any thoughts or experience? OR will I need a pickup designed to do this?I'm NO electrical guy.
    Thanks
  2. DarrellV
    15,429
    32,838
    Nov 1, 2016
    Might be the easiest way to go...
    Seymour Duncan for example makes pickups that are splitable, and they have wiring diagrams to show how to split and reverse phase them.
    Win/Win!
  3. old mark
    3,815
    3,474
    Aug 21, 2009
    Looking at a hot humbucker from Stew Mac, available with coil split already on it...I might just settle for that.
  4. darthphineas
    darthphineas Senior Member
    544
    168
    Oct 3, 2014
    dig around here a little for some possible solutions
    http://guitarelectronics.com/guitar-wiring-resources/
  5. carydad
    carydad Senior Member
    1,472
    364
    Nov 7, 2007
    A pickup out of phase with itself would be...odd. You can't even drop the volume on one coil to mellow out the opposition. I'd recommend serial(normal)/parallel/single by far.
    smk506 and old mark like this.
  6. Zoobiedood
    Zoobiedood Senior Member
    861
    294
    Sep 1, 2015
    You will need a 4 conductor pickup. A good idea which doesn't require you to add additional switches is the Triple Shot ring, which has small switches to select series/parallel and switch either coil or both.
  7. smk506
    smk506 Senior Member
    2,164
    2,991
    Jan 5, 2009
    The carvin I had came with 4 conducted pickups, I think all their buckers are IIRC.
    he triple shot is a good idea, but I think you have to clip the wires on the pickup fairly short don't you? May not be an issue.
    You will also probably need to identify the wires on the carvin pickups and seymore duncan pickups since I doubt they are the same colors. This is fairly easy with a bit of online sleuthing though.
    Also, I would listen to carydad. That's the best advice so far in the thread IMO.
  8. Zoobiedood
    861
    294
    Sep 1, 2015
    I don't clip the wires short, I just wind them and stick them in the pickup cavity. They fit. And yes, you have to figure out the wire colors on the Carvin and translate.
