Drop-in replacement tuners for Epiphone ES-335 Pro Limited Edition
Discussion in 'Other Epiphones' started by Yeahno, May 29, 2016.
  1. DavidRamey
    DavidRamey Senior Member
    1,551
    1,558
    Dec 31, 2013
    If you change the bushings, make sure you support the top side of the peg head so you don't chip the peg head or the finish.
  2. northernguitarguy
    northernguitarguy SWeAT hOg
    27,352
    44,383
    Feb 22, 2009
    Did the new tuners help with the tuning problem?
  3. Yeahno
    Yeahno Junior Member
    13
    1
    May 29, 2016
    Yeah, I've been researching how to avoid chipping the finish. I'm going to try this approach. https://www.youtube.com/watch?v=TyE4wGjz1XY
  4. Yeahno
    13
    1
    May 29, 2016
    Heh. I'll let you know after I get the old bushings out without chipping the finish, ream the holes to accommodate the new ones, press the new bushings in without damaging anything or splitting the headstock, then fitting the tuners, re-stringing everything, letting the guitar settle for a few days, and finally, seeing if it stays in tune.
    It's a lot for a rookie.
  5. DavidRamey
    1,551
    1,558
    Dec 31, 2013
    The outside diameter of the bushings should be the same, isn't it the inside diameter that is different on your guitar?
  6. Yeahno
    13
    1
    May 29, 2016
    Without pulling an existing bushing, the technology of which I've only just figured out, I can't tell.
    What I can say is that the OD of the face that sits on the headstock is definitely different: .433" on the original, .440" on the Klusons. The Kluson bushing inside the headstock is .351" OD.
    Once I get an original bushing extracted, I'll know more.
  7. Yeahno
    13
    1
    May 29, 2016
    Bingo!
    So, drilled an 11.11mm hole in a 1" x 1" piece of 3/8" plywood, put the hole around the original 11mm bushing, pressed gently from the back with a bolt and the bushings eased themselves out, zero marks on the finish.
    I measured the existing bushing and the difference was .009", not enough to matter. Pressed the new bushings in with this little rig I built (see the photo), and I now have the new Klusons installed, no need to ream or modify anything.
    A set of new strings, a quick set up of the intonation and I'm back in business.
    Fingers crossed that this addresses the tuning issue.
    Thanks to everyone who chimed in on this!
  8. DavidRamey
    1,551
    1,558
    Dec 31, 2013
    Glad it worked out for you.
  9. Yeahno
    13
    1
    May 29, 2016
    Tuning is solid now!
  10. Chris Lee
    Chris Lee Junior Member
    3
    0
    Feb 10, 2017
  11. johnnymg
    johnnymg Senior Member
    417
    180
    Mar 21, 2012
    The tuning drift is MOST likely from a temperature change.
