Does Fender only use "hard rock maple"?
Discussion in 'Fender' started by Les Paul Newb, Jul 30, 2017.
  1. Les Paul Newb
    Les Paul Newb Senior Member
    965
    664
    Jul 3, 2012
    For their necks?
    I know hard/rock/sugar maple all reference the same species of tree, which is the tree you get maple syrup from.
    In adverts, I mostly just see "maple neck", not specifically stating hard and/or rock.
    Anyone know what they use, and if they changed it, when?
    I've seen other brands use terms like "eastern maple" or "big leaf maple" when referencing caps/tops, which I'm guessing is softer because it's not being used for necks, but I don't know.
  2. RayTorvalds
    RayTorvalds Senior Member
    1,066
    878
    Apr 29, 2015
    NECK WOODS
    Maple:
    As our primary wood we use Northern Hard Rock Maple selected for clean clear grain and minimal run-out. This wood has a bright tone with excellent sustain.
    As per http://edenhaus.com/woods.htm, a Fender licensed company. That is all I kind could find real quick. I hope that helps. :thumb:
    Your better bet will be just asking Fender, though. Good luck finding out :)
    Les Paul Newb and Blues Buzz like this.
  3. Les Paul Newb
    965
    664
    Jul 3, 2012
    Thanks man.
    RayTorvalds likes this.
  4. RayTorvalds
    1,066
    878
    Apr 29, 2015
    You're welcome :thumb:
  5. Phil W
    Phil W Senior Member
    819
    829
    Feb 2, 2012
    There. Fixed it for you.
  6. Benjammin
    Benjammin Senior Member
    19,301
    13,251
    Jul 4, 2009
    do they make necks for Fender? because many companies are licenced by Fender and make products that aren't Fender spec'd
  7. Les Paul Newb
    965
    664
    Jul 3, 2012
    Yeah idk about sustain.
    The difference is in strength.
    The Janka Hardness Test uses a .444" diameter steel ball and measures the force it takes to embed it into the wood at a certain depth. For hard rock maple, it is over 1400 ponds-force. For Big Leaf Maple it's about 800.
    Does that hardness make a tonal difference? I don't know. Probably nothing noticeable to the ear.
  8. RayTorvalds
    1,066
    878
    Apr 29, 2015
    Yes, they do.
  9. ToneasaurusRex
    ToneasaurusRex Silver Supporter
    3,366
    3,087
    Sep 30, 2010
    Big leaf maple is a Western species, isn't it?
    And I'm surprised to hear it's softer (marginally) (?) than sugar maple. I would've thought they were comparable.
