DIY Tube Overdrive
Discussion in 'Pedals' started by TeleDog, Dec 16, 2009.
  1. JackClark82
    JackClark82 Member
    64
    1
    Feb 4, 2009
    I'd be very greatfull if you could send me the diagram for the fat boost pedal also. cheers
  2. kluson
    kluson Senior Member
    1,977
    112
    Oct 28, 2007
    nice one TD
  3. TeleDog
    TeleDog V.I.P. Member
    8,913
    2,858
    Jan 6, 2009
    It could be the LED. Reverse the wires going to the LED, try again. Try that first.
    Does it work on bypass? If it does, then check the jumper wire. If that's secure, make sure the in and out from the circuit is correctly wired. If that doesn't work, post again, we'll figure it out.
    I had a problem with mine too, it was the LED. :D I tried again and that did it. When I rewired the pedal to be in its permanent box I just skipped the LED altogether.
    Oh, almost forgot, make sure that capacitor in the picture is not touching the back of the pot. :D
  4. TeleDog
    8,913
    2,858
    Jan 6, 2009
    Here's a boost pedal, no tube here. :shock:
  5. epilespaul2000
    epilespaul2000 Senior Member
    1,613
    16
    Oct 16, 2008
    Awesome man! :dude: I think I might order these parts and start to practice soldering.
    Do you know any places where I could read more about these so I can know what I'm doing? Thanks. :D
  6. epilespaul2000
    1,613
    16
    Oct 16, 2008
    Okay, question. Is this an OD with no tube or is it an actual boost pedal?
  7. TeleDog
    8,913
    2,858
    Jan 6, 2009
    It's a boost pedal with some tonal effects. But it's not a distortion/overdrive pedal. I got also the schematics for say, the Fuzz Face or the OCD, and this is nothing like it.
  8. epilespaul2000
    1,613
    16
    Oct 16, 2008
    Okay cool. Just checking. :thumb:
  9. JackClark82
    JackClark82 Member
    64
    1
    Feb 4, 2009
    Would you have any schematics you could post that would show how to change the tone stack from a single tone pot to mutiple pots for bass, mid , treble, or just bass and treble similar to the fat boost II and III or any other pedal. I just really enjoy being able to remove the high end when it's too sharp, and a little bass boost really helps on occasion. cheers, this is fantastic
  10. GibsonUSA
    GibsonUSA Member
    51
    1
    Aug 31, 2009
    hey just ordered my parts today. i used the same list as lukemacauly but got the box w/o pre-drilled holes and ordered 15 ft of wire. i already have the right sized drill bits for them and wanted to save money haha ( like 3 dollars ).
    still need to order the tube & socket from tubedepot but ill post pictures once the items come in and start putting it all together. thanks for the schematic and idea teledog! ill keep yall posted.
  11. siore
    siore Senior Member
    1,984
    124
    Jul 30, 2008
    Hey this thing sounds ok. :) I finished mine. :naughty: But it really is a booster, sounds like crap in front of a perfectly clean amp. Need to dirty it up a bit then switch it on with the volume on full.
    BTW, try searching for 'matsumin valvecaster'. We really need to give credit to where it's due. The 9V schematic started with that japanese dude. :dude: Also, try switching out that .047 input cap (the one on pin2) to a 0.010, it seems to give a tighter and clearer sound.
    There's another schematic around (real mctube II), but instead of starved plate design (9V powering the plates), he goes with full 140V on 'em using a pair of walwart adapter transformers. Like to try that one in the future.... but the valvecaster sounds great for me at the moment. :) Was a fun build too.
  12. GibsonUSA
    GibsonUSA Member
    51
    1
    Aug 31, 2009
    hey siore what tube did you use? i just ordered a JJ's 12AX7 and cant wait for it to come in ha. i imagine that tube is better than the one he used on the original. i think the tube would play a significant role in the tone
  13. TeleDog
    8,913
    2,858
    Jan 6, 2009
    You need to use 18V with this thing! lol..... It's the best way to drive it hard.
    The Valcaster is similar to this, but I got this thing from a DIY place, it's supposed to be used with higher voltage, like 18V for better results, although 12V is not a bad idea. Like everything tube related, a 9V battery works, but will starve the pedal.
    I've used this with a clean Marshall, it sounded awesome. I used it with a clean SS amp, sounded harsh as hell.
  14. siore
    siore Senior Member
    1,984
    124
    Jul 30, 2008
    @GibsonUSA
    Dude I used a Toshiba 12au7 (probably re-branded, dunno the tube's origin). For around $6, it sounds good!
    @TeleDog
    The layout you posted on page1 (first post) is a valvecaster, based on the cap, pots, and resistor values. :) This particular design is based on 9v operation. It is a starved plate design, but with the values chosen, it should be well within the tube's operating curves. BTW I also have an 18v power supply. How long do your tubes last with that? I understand that the '12' in the tube name stands for heater voltage spec. :cool:
    @0x00
    How did you cut the square shape in your enclosure? Working with metal enclosures is not exactly my strong suit. :eek:
  15. TeleDog
    8,913
    2,858
    Jan 6, 2009
    I've tried the pedal with both 9V and 18V, and 12AU7 and 12AX7. To me, the best sounding combination was the 18W with the 12AU7, followed by the 18W with the 12AX7. Amazingly enough, I still have the same chinese tube and it works fine. Actually, since the pedal doesn't have a real "off" switch (might be a good improvement here, a simple SPST) my tube gets warm even when I ain't using it, and it's still going.
    I found a design for a twin overdrive pedal, using the same 12AU7s, what I'm trying to do is change the design to allow for a 2-channel pedal or a two-stage gain, 3 way, all in one pedal. Real close to that now.
    I have a pedal that's a little strange if you will, not really a pedal but works like one. It's simply put the preamp stage of an EVJ in a box. I have not posted that here because it needs a transformer and also because you cannot run it with batteries, it needs to be plugged in and grounded.
    That one works great, I have it, but it's not the classic stuff you'll find in a pedal, it's quite big, actually, I'm not good at all at working with little tiny boards and stuffing everything there. lol
  16. GibsonUSA
    GibsonUSA Member
    51
    1
    Aug 31, 2009
    EDIT: sry i am noob. i can just put 2 9v in series to get an 18v. haha ill post pictures later
  17. GibsonUSA
    GibsonUSA Member
    51
    1
    Aug 31, 2009
    heres a pic of the box drilled and ready
    and my awesome clamp guy
    btw yall are right, 22 awg wire ftl ... need to get stranded wire
    heres a pic of the tube socket partially finished
  18. GibsonUSA
    GibsonUSA Member
    51
    1
    Aug 31, 2009
    hey so i wired everything up and no sound. I made sure that nothing was grounding out in the tube socket, but yet i have no power to the grid (but there is power to the heaters).... coming out of pin 6 one side of the cap has pwr while the other doesnt (or the wire connecting to the tone). any ideas?
  19. siore
    siore Senior Member
    1,984
    124
    Jul 30, 2008
    Check your connections bro. It's pretty much a simple circuit and I bet you can tap every connection with something like a chopstick to see if anything is loose. Also, the leads on the resistors/capacitor on your socket looks too long, so that something may be shorting to adjacent components (or ground) there? It's a good idea to keep 'em short.
    BTW, you mind sharing how you made holes on the enclosure for the tube socket? :cool: Are you gonna paint it?
  20. GibsonUSA
    GibsonUSA Member
    51
    1
    Aug 31, 2009
    yeah i one of my caps was bad and i am considering redoing all the connections to the tube socket, those long leads are reallly annoying. my first time doing this so learning as i go.
    to make the holes in the inclosure for the tube socket i had bought a set of titanium drill bits and was going to use a 1/2 inch bit, but my drill only holds a max of 3/8. so i just drilled at an angle, in circles, and any possible way till it fit.... oh and i chizzled the shit outta it haha.
    yeah i plan on painting it tomorrow or whenever i can get some funds to go get the paint haha. i plan on painting it white and adding vinyl tape offset. ill definitely post final pics.
