DIY - Radius-sanding Blocks
Discussion in 'Luthier's Corner' started by opus1956, Mar 1, 2010.
  1. opus1956
    opus1956 Senior Member
    342
    158
    Oct 23, 2009
    Thought I'd share this cool way to build your own radius-sanding blocks. This is a 12" radius block.
    First, use a piece of MDF or plywood (whatever you have) and attach your router to one end. Mine is just as wide as the router and about 22" long.
    Then from the center of the router bit, mark the length of each radii you want to make. I marked my board at 9.5", 10", 12", 14", 16" and 20" so I can use this same board to make all these different radius-sanding blocks. Then drilled a 1/4" hole at each length. Make sure these holes are in the center of the board.
    Next take another piece of MDF and cut it to the width you want the sanding block to be, mine is 2-3/4" wide (StewMac sanding block width). Then mark the center line of the board and lines equal distance apart. Mine were 3" apart.
    Depending on how thick your MDF is will determine how many pieces you need to cut to make your sanding block. If you want an 8" sanding block and you're using 3/4" MDF, you'll need the board to be at least long enough to cut 11 pieces plus an extra 15". So for the 8" sanding block you'd want to start with a piece 2-3/4" wide and 48" long.
    Drill 1/4" holes at each of the 3" lengths starting 15" back from the edge of the board. Drill as many holes as pieces you going to cut plus an extra 5. I used a 1/4" straight cut bit in the router.
    Bolt the two pieces together at the 12" mark and make your first cut. Then unbolt it and move to the next hole to cut off another piece. So the bolt doesn't come loose as you pivot the router, I tighten two nuts against each other.
    After your pieces are cut, use double stick tape, line them up and stick them together.
    Then cut the block in half.
    Hang on to the piece you cut off w/ the convex radii...you'll use that later.
    Take the piece with the concave radii and glue it to a backing board. I used a piece of 1/4" MDF.
    mux164, Spotcheck Billy, LPBR and 2 others like this.
  2. opus1956
    342
    158
    Oct 23, 2009
    Then take 1/8" masonite and glue it to the radiused side of your sanding block. Use the leftover convex piece you just cut off as a caul to bend the masonite.
    Once it's all glued, clean up and smooth the edges...then you're ready to throw on some self-adhesive sandpaper.
    Enjoy!
    silverkw, Dr.K, jonas335 and 3 others like this.
  3. dougk
    dougk Senior Member
    4,628
    2,547
    Mar 10, 2009
    COOL!
    Thats a really great idea. I'd seriously consider trying to make one 16 or so long. I take my long blocks and screw them to the bench radius facing up. Then I can work the neck over the block (if its separate from the guitar). Seems to be easier for me for some reason.
    Anyways, absolutely brilliant idea!
  4. landsharkey
    landsharkey Senior Member
    768
    48
    Dec 16, 2008
    Yes, nice job. Here's a little different approach I used making a template first for an 18" long block-
    pinefd likes this.
  5. w666
    w666 Senior Member
    1,846
    375
    Nov 25, 2009
    Way cool....I wish I had thought of this!
    What I did was to use my Stewart Mac 12" sanding block to create a convex sanding block, and then used it to shape clamping cauls. Very labor intensive!
  6. Guitarsquirrel7
    Guitarsquirrel7 Senior Member
    1,605
    16
    Feb 18, 2009
    :applause:GENIUS!:applause:
  7. NateM
    NateM Senior Member
    388
    180
    Sep 20, 2009
    Nice trick!
    I used a bandsaw in place of the router for mine and pivoted the piece of wood I was using for the block through the blade. It worked pretty well though I didn't think of the masonite for the bottom.
  8. opus1956
    342
    158
    Oct 23, 2009
    Thanks...yeah, I need to make a 16" - 18" one next.
    Thanks for sharing your method!
    Thanks guys.
  9. slapshot
    slapshot Senior Member
    22,960
    23,639
    Aug 21, 2010
  10. Tardis
    Tardis Senior Member
    104
    31
    Jan 28, 2012
    Dude, I was not liking the idea of buying radiused blocks, but I could think of no alternitive. Thanks for sharing this with us, me Cheapo side really appreciates it :):)
  11. SteveBassett
    SteveBassett Junior Member
    1
    0
    Dec 8, 2012
    The initial router method is a brilliant approach. Good work. But you'll have to measure from the center of any given radius pivot hole to the FARTHEST EDGE of whatever diameter router bit you're using, NOT to the center of the router bit to get an accurate radius. Maybe that's what you meant?
    I'm going to try this same structural approach but on a band saw with a scroll blade. I've got a lot of blocks to make and suspect the router bit would overheat cutting that much MDF. I'll measure from the blade kerf to the pivot hole. I think I'll have Home Depot cut my strips of MDF first on that nice, big panel saw they have. I may just strip rip a whole 4x8 sheet!
    Thank you for sharing the excellent method.
  12. fatdaddypreacher
    5,484
    3,480
    Feb 5, 2011
    i can't believe someone else spent as much effort making a sanding block as i did. i made mine doing essentially the same thing that you did, only i used a radius cutting jig on a bandsaw. worked out fine, till i used it and found out i had a brain fart and set the jig for a 6" radius and ruined a perfectly fine piece of wenge.
    can't wait to see the effort you put forth in your builds.
  13. LPBR
    LPBR Senior Member
    1,203
    978
    Dec 1, 2011
    Unburing a very old post, I know, but I just found it. Anyway, I really don't think that the half width of a router bit will make any difference in this case. This is the kind of perfectionism that won't drive anywhere.
    :hmm:
  14. Freddy G
    Freddy G V.I.P. Member
    10,057
    19,485
    Mar 18, 2007
    Hey nice one!
    I made this 9 1/2" block about 20 years ago and it's still accurate and stable (albeit a bit beat up :D)
    The precision will indeed matter if you are using a matching radius caul to press the frets in. If hammering then no big deal if the radius is out a bit.
    1 person likes this.
  15. nicolasrivera
    nicolasrivera Senior Member
    19,572
    10,634
    Dec 3, 2008
    nice Opus, always wanted to know how it was done..... and it is bit of work to do to save $16 bucks.
  16. mountainwhimsy
    mountainwhimsy Senior Member
    580
    762
    Dec 20, 2011
    Nice trick. Though I just bought a pre-radiused and slotted fretboard, put sticky paper on it, then ran a hardwood blank back and forth over the top of the fretboard until it had the the pre-radiused profile. The cost was a little more for the pre-radiused fretboard, but I needed it anyway. About 5 minutes of total work.
    5 people like this.
  17. LPBR
    LPBR Senior Member
    1,203
    978
    Dec 1, 2011
    Very nice approach Tony! Sometimes we need to look out of the box!
  18. emoney
    emoney Senior Member
    6,936
    3,108
    Jan 31, 2010
    Me? I just spent $10.00 and bought one off Ebay. Took all of 9 seconds flat.
    3 people like this.
  19. scottop1972
    scottop1972 Premium Member
    949
    412
    Jul 8, 2013
    ^thats what i did! Buy it now!
  20. mux164
    mux164 Senior Member
    2,561
    1,773
    Sep 1, 2012
    great ideas, i just took my stop tail piece and traced it onto a cork sanding block then used the belt sander to get it to the line. then i use 40 grit up to 180
